2010 Prius OEM-quality Fog Light Kit Now Available!
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Danny, May 10, 2010.
  1. indiposh
    indiposh New Member
    Los Angeles
    I noticed that on one of mine, but realized that I hadn't pushed the housing in all the way on some of the bottom tabs.
  2. Fla Fla Flo Fly
    Fla Fla Flo Fly Junior Member
    38
    Illinois
    Okay. I noticed that on the pass side as well. The install is complete, and they look great! Took me about 3.5 hours. I got very nervous though when my wife started the car afterwards and it sounded like something rattling. Almost as though the wires were in the fan blades. Hasn't happened again though, so I think I'm safe....
  3. unkprius
    unkprius Member
    152
    I ziptied everything under the hood except the ground and hot wire. Way too cramped quarters and potential bolt/screw loosing area.
  4. zero610
    zero610 Junior Member
    Might be a stupid question, but can you set the fog light switch to "on" so each time you turn on the headlights, the fog lights will also come on without having to press the switch? Then you can turn them off by pressing the switch. Basically, if I want to drive with these on each time I have my headlights on, I don't want to have to press the switch.
    Thanks in advance.
  5. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    ^ yes if you wire per instructions.
  6. dds02400
    dds02400 New Member
    san ramon
    thanks Danny, just received today. They look great!
  7. Tideland Prius
    16,556
    Yep. Just leave the button depressed (assuming you've followed the PDF). Just note that they do not turn off with the high beams so be aware you'll have 6 forward-facing lights which is illegal is most, if not all, states.
  8. Zedknepplin
    Zedknepplin semper prius
    124
    65
    162
    Georgia
    I had looked into this but eventually ordered a Prius five. One dealer said they could not install them (when I was looking into a four with solar) and I found your site on a Google search while looking for them! Also, PriusChat Shop has best price! (Now if we can only get a deal on the mirrors!) - hint...
    I see the fog light kits on eBay for $180 and up! Some other Toyota dealers in the South offer it at $279 installed w/new car. My next mod will be side LED mirrors like CivicSky and after that the ScanGauge II tool. Thank you for the info and install guides! :rockon: I'm Going nuts waiting for my car on 4/11.:eek:
  9. DumbMike
    DumbMike Active Member
    560
    119
    Los Angeles
    I posted this before. Just thought it might be helpful to those in California. California's law is:
    24405. (a) Not more than four lamps of the following types showing
    to the front of a vehicle may be lighted at any one time:
    (1) Headlamps.
    (2) Auxiliary driving or passing lamps.
    (3) Fog lamps.
    (4) Warning lamps.
    (5) Spot lamps.
    (6) Gaseous discharge lamps specified in Section 25258.
    (b) For the purpose of this section each pair of a dual headlamp
    system shall be considered as one lamp.
    (c) Subdivision (a) does not apply to any authorized emergency
    vehicle.
    So, you can have the high beams and low beams (as they only count as one light) and the fog lamps all on. I don't know the law in the other states so you should look that up.
    Hope this helps.
    Mike
  10. mugen000
    mugen000 New Member
    Bay Area
    Anyone knows what model is the light blub for the fog light? I would like to change the light blub on the fog light. Thanks
  11. v35
    v35 New Member
    27
    So. Cal
    h11
  12. hotroddan
    hotroddan New Member
    ca
    how do you install them
  13. silica
    silica Junior Member
    44
    Phoenix
  14. Prius916
    Prius916 Junior Member
    Sacramento
    How long does this take to install?
  15. v35
    v35 New Member
    27
    So. Cal
    Just got my kit installed professionally in under an hour. Guys on here average 2-3 hours. I noticed that they are aimed kind of high for fog lights though..
  16. mugen000
    mugen000 New Member
    Bay Area
    Thanks V35, H11. I'm planning to buy a HID for my foglight
  17. Fla Fla Flo Fly
    38
    Illinois
    Took me just over 3 hours, but a lunch break was included :D
  18. voltoy
    voltoy Junior Member
    23
    Lincoln, CA
    Limited AWD-e
    2011 Fog Light Installation Update
    Just finished installing the OEM kit supplied here. There are a couple of things to note about the 2011 Prius. First the Fusebox is a little different, so the instructions are close but not exact. I mounted the relay just below the fusebox to a threaded insert in the body. Photos Attached. Total installation time was about 2 1/2 easy (took my time) hours.
  19. bagwell
    bagwell Active Member
    592
    49
    the woodlands, tx
    so I had an issue with mine after about 4 months....neither bulb would come on. The switch would illuminate and I could hear the relay clicking so I checked the bulbs. I disconnected 1 bulb from the socket and plugged it back and it worked.....1 put some silicone grease in the socket and and re-installed. Same thing on the other side. Note - there was no corrosion, it just seems like something with the connectors is not right....but they're working again...for now.
  20. bagwell
    592
    49
    the woodlands, tx
    I ordered HOEN xenon match bulbs...much whiter than the super yellow bulbs they came with and I didn't want to fart with another xenon kit for the fogs
    $36 shipped
    http://www.hoen-usa.com/fog.htm
