2010 Prius OEM-quality Fog Light Kit Now Available!
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Danny, May 10, 2010.
  1. Tideland Prius
    16,556
    PM Danny. It might be a program issue.
  2. grantb3
    grantb3 Junior Member
    60
    Orange County, CA
    Try a different browser.
  3. naudurivsm
    naudurivsm New Member
    27
    Fairfax, VA
  4. Paul58
    Paul58 Mileage Miser
    1,126
    125
    Atlanta
    I saw no loss...
  5. DumbMike
    DumbMike Active Member
    560
    119
    Los Angeles
    I see no logical way the fog lights could reduce the MPG by about 20%. I think you'd have to be towing another car or only driving uphill to have the MPG reduced by that amount. But I can understand some minimal MPG loss as the aerodynamics with the fog lights are slightly less than the "plug" used in place of the fog lights. There isn't much about proper precautions for this installation except something dumb like don't crack your front bumper.
    I didn't disconnect the battery. Not sure whether I should have done it. I don't recall the instructions requiring you to do that.
    I thought the only bad part about the installation was connecting the red wire to the brown wire on the ECU. Rather than use the connector they give you, buy some T-Tabs and make the connection with that.
    Dumb Mike
  6. naudurivsm
    27
    Fairfax, VA
    OK, just received the KIT today ( in fact just unpacked - looks great.
    Need to call the car audio/video guy for installation.
    I downloaded the installation instructions from priuschat.com shop.
    Any last minute thoughts / suggestion as best practices ?
  7. Paul58
    1,126
    125
    Atlanta
    Yeah, in the instruction you downloaded, they installed the switch upside down! Install it the right way so you don't look like a dummy...
  8. bagwell
    bagwell Active Member
    592
    49
    the woodlands, tx
    +1, no loss either
  9. GSW
    GSW PRIUS POWER
    537
    74
    Jacksonville
    Just bought the OEM Fog light kit from the Prius shop. Looks great can't wait to get it installed. :rockon:
  10. DumbMike
    560
    119
    Los Angeles
    I'm serious people. Go to your local electronics store and buy a set of T-Tabs. Use that instead of the red gizmo in the package used to connect the red and brown wires.
    Dumb Mike
  11. bagwell
    592
    49
    the woodlands, tx
    I did have an issue with the red wire taps
    at first I just snapped it closed --- later I had to go back in there and really mash it down with pliers....after that no issues.
  12. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    I had to use pliers on my tap also. I could not get enough pressure on the tap with my fingers alone. Once I used added pressure with the pliers I had no further issues either.
  13. GSW
    GSW PRIUS POWER
    537
    74
    Jacksonville
    COMPLAINT!
    The Priuschat shop shipped my fog lights in so fast, now I have to install them this weekend or my wife will get out her bull whip and leather undies. :mad: Hmmm... I'll install them next week.:p
    Seriously, Thanks Danny! :rockon:
  14. DumbMike
    560
    119
    Los Angeles
    I think we'll need pictures of this install.
    And take note of the few posts immediately prior to yours as you can see that they've had trouble with that one connector, but they stated their solution. Personally, I like the T-Tabs better. And to further my case, if you look at all of the connections made by Toyota, they use T-Tabs, too (a lot of them).
    Mike
  15. GSW
    GSW PRIUS POWER
    537
    74
    Jacksonville
    I will. Thanks Mike!
  16. summit123
    summit123 Junior Member
    96
    MA
    I was on a Mac when I attempted to order the lights. Went on a PC at work on IE and the order went through immediately. Very strange, but thanks for the suggestion.
  17. Paul58
    1,126
    125
    Atlanta
    I ordered from my MacBook, and had problems as well. Order went through but did not show up in my purchase history. Will have to remember to order via PC next time...
  18. vtht65
    vtht65 New Member
    Virginia
    Can this kit be used on a 2010 Level III??
  19. geminikanon
    geminikanon New Member
    26
    South Bay
    Just wondering, those of you who bought HID kits for Prius V with LED headlamps, what HID color temperature matches with the LED color?
    Would you say it's more like 5000K or 6000K?
    I'd appreciate your inputs.
  20. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Yes... any level.
