2010 Prius oil leak
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Riverhook, Aug 21, 2022.
  1. Riverhook
    Riverhook New Member
    Knoxville, TN
    Have an oil leak from this area somewhere. I'd say about 3 quarts between oil changes. I am also curious what that sensor is with the black base. And the black bolt that looks half screwed in?
    #1 Riverhook, Aug 21, 2022
  2. Tombukt2
    Tombukt2 Senior Member
    13,868
    2,520
    Durham NC
    Looks like an oil sensor The first picture I think is what's leaking isn't that the oil pressure sensor it's hard for me to tell with that close up My 2010 the oil pressure sensor was leaking pretty bad and see it running down the front of the motor
  3. Mendel Leisk
    42,361
    Can you clarify the point of view of that picture, say: you're looking from above, below, front or rear of the engine? Maybe take another picture, back a little further.
  4. OptimusPriustus
    OptimusPriustus Active Member
    338
    144
    Finland
    3 quarts is lot of oil. The place car is usually parked at should have large oil stain. Is there? My other car has similar looking ”oil moist” in couple places but just 0.5l is lost during 20000km. Probably that 0.5l get out from tailpipe:)
    #4 OptimusPriustus, Aug 22, 2022
  5. ASRDogman
    ASRDogman Senior Member
    8,067
    4,089
    I believe that is the oil pressure sensor. About $20-30, and fairly easy to change.
    Just clean out the connector with brake cleaner.
  6. Tideland Prius
    16,683
    Updated title to include the word "leak"
  7. bisco
    52,876
    how much of that are you burning?
