2010 prius-ok for winter driving?
Discussion in 'Gen 3 Prius Main Forum' started by geocran, May 2, 2010.
  1. geocran
    geocran New Member
    madison heights,MI
    I live in Michigan and the winter here is pretty nasty sometimes. I have been reading previous posts on winter driving, snow tires, problems with traction control, etc. I have two questions about winter driving and would appreciate any information. First, is it really necessary to buy snow tires for winter driving and second, have the problems with the traction control been fixed on the 2010 models? I would appreciate any updated information.
  2. john1701a
    john1701a Prius Guru
    12,796
    5,277
    57
    3 winters with a Classic model
    6 winters with an Iconic model
    1 winter with a 2010 model
    All in Minnesota.
    The 2010 has been the best of the bunch for me.
    You'll be pleased with even just the factory tires in basic winter conditions, which is what I used last year. For the heavy stuff, I used high-traction tires with my Iconic... but not observe the need for the 2010. For the really nasty driving (unplowed, deep, hilly), some find snow tires a worthy upgrade.
  3. adamace1
    adamace1 Senior Member
    1,403
    193
    Charlotte, NC
    I used to live in MI. I think it will do fine. I did drive mine through over 6inches of snow a few times and i was impressed on how it did. I liked the way the traction control system works. I have heard the 2010 are alot better then older ones.
    2 people like this.
    51,109
    boston gets pretty nasty. i've been driving the gen II for 5 winters. it's as good as any 2 wheel drive car i've ever had, and i've had a lot of them. factory tires only. gen III should be even better!
  5. ePrius
    ePrius Member
    162
    76
    With 2 monsterous northeastern blizzard this past winter, my prius took it like a champ. Drove perfectly fine in 7" of snow.
  6. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    In Alaska and I think it does GREAT![IMGLINK]http://priuschat.com/forums/attachments/gen-iii-2010-prius-accessories-modifications/19871d1257796987-got-snow-snow1.jpg[/IMGLINK]
  7. priuscreek
    priuscreek Junior Member
    I had no trouble driving in Minnesota snow this past winter. Actually the day I drove it home from dealer it was snowing pretty good.
  8. 2to4
    2to4 Wherever we end up
    67
    Southwest, Indiana
    Beautiful pic!
  9. chrisj428
    chrisj428 Active Member
    680
    144
    35
    Vernon Hills, IL
    I had no trouble this winter in Chicago. Used snow tires (have done since 1993).
  10. New_Yorker
    New_Yorker New Member
    517
    69
    Tires are always a compromise. The traction of snow tires on snow is far superior with any vehicle to the ordinary 'all season' tire.
    As far as the Prius goes, the car is not a snow plow, so the road surface can't have too much snow, but it handles well on a snow covered road, and cold weather is never a problem. As with most things about driving, the best or worst results depend almost totally on the quality of the Nut behind the steering wheel.
  11. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    I disagree. :D
    Last Tuesday I drove through 18in of unplowed spring snow (heavy wet snow). I had to dig out my door to get in, and about a minute of rocking back and forth with traction off, I was able to bolt out and maintain speed to get to the interstate.
    It snowed yesterday too, but it wasn't too bad...
  12. treet007
    treet007 Member
    102
    Ireland
    2019 Prius
    In Raleigh NC, where it snows and ice-over periodically during winters (and that we have very little snow-removal equipment), my 2010 Prius III should do fine. I do plan to change the current Yokohamas with Goodyear TripleTred for additional traction (yes, I know it will reduce my MPG a little, but read on...)
    I also have a Gen I, and I changed the tires to Goodyear Integra since the OEM Potenzas were horrible ... they even slipped on dry pavement. I ended up in a single-car accident, which was exacerbated due to these tires, and after I changed the tires, I have had no issues. Despite what Toyota dealer told me in "voiding the [Gen I] warranty if I don't use the Potenzas", I still got 42-48 MPG during spring-fall and 38-44 MPG during the winters (most likely due to engine warmups) with the Goodyear brands. I also watched the overall vehicle's weight not to exceed the tires' loading capacity (Gen I had XL tires). The Yokohamas are a lot better than the Potenzas, but I still plan to change the tires to the Goodyear brand before winter hits. Call it personal risk avoidance for me :)
  13. smurfpotter624
    smurfpotter624 Junior Member
    29
    17
    Grand Rapids, MI
    I'm from Grand Rapids, MI. My 2010 handled the snow just fine this year. I still have the stock tires. We did take one trip up to Cheboygan at Xmas time and we didn't have any trouble. It handled better than my previous car, for sure, a 99 Buick Century Limited.
  14. flbntz
    flbntz My First Toyota
    48
    Elizabethtown, PA
    We had snow the first week I got my Prius III, 2010. It went better than I expected it to. It didn't feel very heavy, but I guess because the batteries are above the back wheels, and the engine is above the front wheels, it was actually pretty good in the snow. I think the wieght distribution is something like 62% rear, and 48% front.
  15. bisco
    51,109
    i would garage for the winter and break out the vette!:D
  16. peirhead
    peirhead Junior Member
    48
    PEI Canada
    The prius is great in the snow, Traction and stability control work really well in the deep fluffy stuff as well as on Ice.
    I would recommend snow tires, and remember your A/S tire will last much longer if you're only using them april - Dec so you're really not out much extra$
