2010 Prius Optima Battery
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by kknguyen1168, Mar 8, 2013.
  1. kknguyen1168
    kknguyen1168 Member
    453
    35
    san diego
    hi All
    I am going to buy Optimal battery for my 2010 Prius, however, I see 2 choice anybody out there see the different please let me know because I am lost!!!
    1. Optima Batteries 8171-767 Yellow Grp S46b24r 450cca for ~190.00 dollars
    2. Optima Batteries 8071-167 D51 YellowTop Dual Purpose Battery~ 150.00 dollars
    do you guy know which one best for our 2010 Prius?
    V/r
    Khoi nguyen
  2. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    The Optima DS46B24R is the ideal Prius battery of those two as it has JIS posts and a 'reversed' orientation that puts the negative post near the body and isolates the positive post.
    Optima DS46B24R Optima battery direct fit replacement for Prius 2004 + & Plug-in Prius with Instructions
    The Optima D51 is less than ideal on two counts, SAE posts will need a conversion kit for the wiring, and not being reversed, the positive post will be close to the metal ground, and the cables will be too short. There is a D51R which solves the position half of that.
    Installation Kit for Optima battery in Prius
    OptimaJim and TsKarma like this.
