2010 Prius P0A80 code "Check Hybrid System" with all lights on.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by alleneatsapples, Jan 29, 2021.
  1. alleneatsapples
    alleneatsapples Junior Member
    Kauai
    Hello everyone, this is my first post and hopefully my last!
    I just bought a used 2010 Prius III Gen. with about 120,000 miles on it. I bought it knowing that there is a "Check Hybrid System" with a P0A80 code. The previous owner informed me that the hybrid battery was replaced with a Green Bean refurbished battery. It has been tested and has around 60% capacity, which is considered "fair". I have a Carista OBD2 with the app to clear the code. The "Check Hybrid System" clears, but the P0A80 code says it is "Permanent". Everything seems to work fine for about 30 miles or so until the "Check Hybrid System" comes on again.
    Any ideas would be greatly appreciated. I am on a budget and I am willing to play wack a mole with the cells if I have to. From my understanding, this code could mean a number of things. Since the hybrid battery is still in "fair" condition, I do believe that it is something else. The battery does not drain completely and seems to maintain a charge after clearing the code. Any suggestions would be greatly apprecieated!
    Thanks everyone! I look forward to fixing this problem and eventually selling it for a good price.
  2. PriusCamper
    PriusCamper Senior Member
    13,476
    5,443
    Pacific Northwest, USA
    Please use Dr. Prius app so we can see some screenshots of the battery monitor, as well the error codes before they cleared and we can help advise. Perhaps it's an easier fix than a rebuild?
    Also, have you contacted GreenBean to get a sense of where they are with warranty on it? If that's an option swapping the pack out with a replacement one is the easiest fix.
  3. AzusaPrius
    AzusaPrius Senior Member
    2,258
    953
    Ask the previous owner to contact green bean and do the transfer or ownership.
    That way you can get the battery replaced and installed by them.
    Then and only then will it have a warranty.
    The permanent code is there because the battery was bad hence why he got a green bean battery.
    You have to drive it and eventually the code will go away.
    Drive it around and look to find declines to coast down and press lightly on the breaks to charge it up faster.
    If you have to reset to codes when it pops up and coontinue to do so until the battery is charged good.
    Who knows how long the previous owner let it sit during this pandemic.
    #3 AzusaPrius, Jan 30, 2021
  4. honestrepairs
    honestrepairs New Member
    Hillsborough, NJ
    2010 Prius code P0A08 shows and check hybrid system on dash what is this code for
    #4 honestrepairs, Jan 30, 2021
  5. bisco
    52,914
    at how many miles, and what date was the gb battery installed?
  6. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    o_O
  7. alleneatsapples
    Kauai
    The Green Bean battery was installed around 100,000 miles. It currently has 122,000 miles.
  8. bisco
    52,914
    hybrid battery replacement
    see 'newpriusbatteries.com'
  9. bisco
    52,914
    you need to have a chat with gb
