2010 Prius panel below glove box
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Lightning Racer, Jan 9, 2016.
  1. Lightning Racer
    Lightning Racer Active Member
    239
    321
    Anchorage, Alaska
    In my new/used Prius, this panel is attached on the top end by black duct tape. Can someone take a look at this on their Prius and tell me how it's supposed to be attached? This might not be worth fixing, since I only noticed it when looking at the cabin air filter. But if the panel is the problem (broken tabs or something like that) and cheap, I might add it to my order from toyota parts cheap.
  2. mrlebop
    mrlebop Member
    136
    68
    Here's a few photos of mine... No duct tape.
    #2 mrlebop, Jan 9, 2016
  3. mrbigh
    3,686
    699
    Long Island, NY
    I do not think that the OP is referring tho this one, but I might be wrong
  4. Lightning Racer
    239
    321
    Anchorage, Alaska
  5. mrbigh
    3,686
    699
    Long Island, NY
    Under my criteria after owning 4 Prii from 2004 'til today, there are 2 glove boxes on the hatchback, an upper and lower oner.
    I can't even imagine who can take the trouble to put a piece of tape in order to fasten one of this storage container as a means of a fix.
  6. bisco
    52,803
    o/p, that looks correct. i can see how some folks might have trouble figuring it out. well done!(y)
    Lightning Racer likes this.
  7. Lightning Racer
    239
    321
    Anchorage, Alaska
    Ha Ha, the original owner seems fastener challenged. The fuse box under the hood was not snapped closed correctly. The cabin air filter cover was not snapped closed correctly. And a clip from the lowest part of the front of a wheel well to the front bumper cover was loose because the clip was on the wrong side.
    #7 Lightning Racer, Jan 10, 2016
  8. mrbigh
    3,686
    699
    Long Island, NY
    Anything and everything can happen in Alaska
