2010 Prius Photos - 102 of them!
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Danny, Jan 12, 2009.
  1. KMO
    KMO Senior Member
    2,015
    742
    Finland
    2023 Prius Prime
    Looking at the numbers, it seems pretty likely that the columns are
    Tyres | ? | Expected proportion of vehicles | Mode | Europe | Old EPA | Current EPA
    590L and 690N are the codes for the new and old Prius.
  2. Submarine Dude
    Submarine Dude Junior Member
    73
    Glendale, AZ
    I have concerns over the placement of the speedometer display. Looks from the photos like it's in the middle of the dash rather than directly in front of the driver as it is now. This means that the driver will have to take eyes off the road to see it (look down/right).
  3. JSH
    JSH Senior Member
    2,605
    140
    PDX
    Toyota is starting production of the 2010 Prius in April and expects to have vehicles in Dealer showrooms by May. The Insight and Prius should be in dealerships within a month of each other.
    Honda picked 22-April to start selling the Insight because the 22nd is Earth Day.
  4. mcsj
    mcsj Member
    125
    Earth
    So it looks like no LCD screen for models without park assist and/or backup camera
  5. GeNeSiS
    GeNeSiS New Member
    Ontario Canada
    I'm not a big fan of this either. What was wrong with the way it is now?
  6. carz89
    carz89 I study nuclear science...
    444
    47
    San Diego
    Actually, the ratio represents 0.4%, not 4%. Basically, no difference at all. The table must be bad data, because there's no way that the ECO and POWER modes would result in essentially the same MPG.
  7. JSH
    JSH Senior Member
    2,605
    140
    PDX
    I would expect all the modes to show similar mileage in EPA testing. My understanding of ECO is that is slows the throttle response to smooth the drivers inputs. ECO would have little effect in a EPA test where the throttle is computer controlled.
  8. fredthepostman
    422
    boothwyn pa
    I read on the Toyota web site that the price list will be released shortly before the cars arrive in the dealerships. I am hoping I can afford a little more than the base model. I would love the moon roof with the solar panel but I have a feeling it will be packaged in the higher end models.
  9. KMO
    KMO Senior Member
    2,015
    742
    Finland
    2023 Prius Prime
    The chart is showing EU/ECE testing, and the issue there is more that all the acceleration in the test is very slow - slow enough that the mode selection won't make much of a difference. It won't be seeing any need to restrain the throttle response.
  10. JSH
    JSH Senior Member
    2,605
    140
    PDX
    I got the Insight and Prius confused. The Insight has an ECON button:
    "An "ECON" mode button (green, of course) makes it easier to score higher and improve fuel economy. Engaging it desensitizes the throttle pedal, re-optimizes the CVT and IMA control programs for thrift, increases the time that the air-conditioning compressor is disengaged and makes the cruise control less aggressive in sustaining speed. In short, the Insight becomes more sluggish."
    Looking at the Toyota Press Release is says the ECO Mode "helps the driver achieve their best mileage." No mention of how it does this.
    "There is also a Power Mode, which increases sensitivity to throttle input for a sportier feel"
  11. ronhowell
    ronhowell Active Member
    681
    32
    Cypress, CA.
    That difference is 0.42%, not 4.2%!
  12. jprates
    jprates https://ecomove.pt
    387
    42
    Moita, Portugal
    2017 Prius PHV
    I'm pretty sure those are not current Prius CE numbers on that last line (690N).
    In that table the City consumption for City is always better on all lines in those columns. In Europe the city cycle is always worse than the others.
    Official numbers presently are 5/4.2/4.3 for Urban/Extra-Urban/Mixed test cycles.
    That first column could never be higher in MPG than the other two for the EC MPG values.
  13. Rybold
    Rybold globally warmed member
    2,760
    322
    Southern California
    A friend of mine has a 1999 Honda and another friend has a 2001 Volvo. The Honda has "power" and "winter" buttons next to the gear shift, and the Volvo has "power" and "economy" buttons next to the gear shift. With both vehicles, the "power" button delays upshifts and is quicker to downshift. The opposite modes upshift sooner and delay downshifts (unless the accelerator is stomped on (emergency)). Considering your quote above about "Power Mode," it sounds like the new Prius AND Insight do the same thing as previous vehicles. "It has long been known that..." :)
  14. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Hobbit, just go to the Toyota site if you want to see the high res.
  15. hill
    8,978
    Whew! That was exhausting, I'll post better/more after a good nite's snooze:
    But as many there said, "needless to say" . . . it was great.
    Back to work, for a 3 day work week.
  16. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    I grabbed the hi-res versions, I was just wondering why so many
    different variants were floating around by midday Monday. Like
    someone actually put work into it...
    _H*
  17. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
    Sorry to be late...
    2nd: tyres
    3rd: number of vehicles sale
    4th: expected proportion of vehicles sale
    5th: mode
    6th: raw data
    7th: current label data (adjusted to old EPA?)
    8th: simple label data (adjusted to new EPA?)
    Ken@Japan
  18. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    302
    Northwest VT
    2018 Prius Prime
    Tells you something about the aerodynamics of the Echo I guess.
  19. Tideland Prius
    16,631
    They're at the base of the dash, by the windshield (a la Gen 6 Camry)
    It's still there but in the monochrome MFD.
    not sure. I hope they have Casual Voice Recognition
    That's the PARK button, not the IPA button. The IPA button is below the POWER button.
    The cloth is monotone. The only way to get a two-tone interior is to get Misty Grey.
  20. MSantos
    MSantos EcoAccelerometry
    589
    260
    Canada, Winnipeg
    2024 Prius Prime
    XSE Premium
    We spent a good part of the day at the Auto Show (just before we arrived in time for the PDC Prius event) and we had a good chat with the Prius Chief Engineer as well. Among the many questions we asked him (MG RPM and EV at a higher speed, etc) we queried him on the Eco mode on what it truly does.
    He stated (And I have him on HD video) that the Eco button causes a 15% reduction of power on the ICE in order to accomplish the desired FE effect.
    I've been posting some of the videos on Youtube which includes footage from the auto show as well as footage captured at the Tuesday PDC event.
    Cheers;
    MSantos
