2010 Prius Preview, L.A. WOW it was FUN!!
Discussion in 'Gen 2 Prius Main Forum' started by KK6PD, Mar 1, 2009.
  1. bwilson4web
    16,537
    Hi Ron,
    It looks like the width of MG2 stator laminations has shrunk. This suggests they may have stronger rotor fields. The higher output voltage from the inverter suggests they are using more windings and thus lower current. This will reduce (I**2)*R losses and will save ohmic heating.
    Can you estimate the wire gauge between the original and the new one?
    Were you able to spot any levers or actuators that might shift or change internal planetary gears?
  2. ronhowell
    ronhowell Active Member
    681
    32
    Cypress, CA.
    I agree with all of your comments in the first paragraph Bob. The laminations have definitely shrunk w/r/t the G2 Prius setup, and the resistive power losses will obviously be reduced at the same power levels due to the higher operating voltage and lower current.
    I did not try to estimate whether or not they had reduced the wire gauge, but I am sure they ran the trade-offs on weight saving and power losses to determine the optimum gauge.
    No levers or shift mechanisms appeared to exist on the PSD. I am intrigued however by the gear ratios that lie concealed within this much more compact unit than exists in the G2 drive. Given the fact that MG2 and MG1 apparently operate at higher limit speeds in G3, yet the ICE operates at relatively lower speed, I am guessing the sun gear is larger, the planetary carrier gears are smaller and the tooth count on the internal output gear of MG2 is lower; to what extent in each case we will learn eventually.
    OTOH, maybe Toyota has invented some new magic altogether! :)
  3. subarutoo
    subarutoo New Member
    1,213
    23
    Chatsworth, CA
    It was a nice beach day, afterall, lots to do in LA on a sunny warm Sunday. By the way, thanks to whoever turned in my lost cell phone. It must have dropped off while I was trying on cars. Thanks again, whoever it was.
  4. subarutoo
    1,213
    23
    Chatsworth, CA
    We have an Outback wagon, and the new cargo area is at least as big as the Subaru, especially, considering how the Sube's seats don't completely fold out of the way. The extreme rear, past the wheel wells seems to be improved spacewise. I carry my road bike in both the Subaru, and our Prius from time to time, and the room seems about the same, the new one looks even better. keep in mind the sloping roof, but the carpeted false floor is removeable giving you an additional 5-6 inches in the prius, still true in the 2010. It looks like you have to fold the head rests down on the rear seat to lower the new prius seat backs.
  5. ronhowell
    681
    32
    Cypress, CA.
    Yes, but the indentations appeared to me to be more curvaceous than the creases in the G2 roofline, with better blending into the overall roof shape.
  6. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    Any thoughts on what the lack of indentations will do for the solar roof version for stability or CD?
  7. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    Frontal area will be larger since the roof will be flat (view from the front).
  8. gussom1
    gussom1 New Member
    36
    SFV
    May daughter and I attended the show and we both had a great time. I wish the test drive was longer. I was embrassed that my daughter won the tee shirt. She knew more about the new features of car then I did.
    We both wish to thank everyone for a great time. We learned a lot about al of the improvements that are coming and when my 05 gets old we will get another Prius. The car just gets better very year. We also have a 07.
    The way the food was great too and everybody was very helpful and fun to talk to.
    Thanks again
    Larry and Rachel
  9. Tideland Prius
    16,681
    Probably just lead to more turbulence around the leading edges of the roof as the air isn't channelled down the centre of the roof.
  10. Qlara
    Qlara New Member
    488
    The 2010 Prius is awefully like a SCION xD, except the drivetrain.
  11. Prius Team
    Prius Team Toyota Marketing USA
    681
    1,817
    CA
    Actually, a great point to keep in mind for Prius Connection SF....for those invited...please bear in mind that many of your fellow enthusiasts have not been able to secure spots for this event. By RSVP'ing that you intend to come, we really do hope that you won't change your mind based on a simple thing like weather. It's a shame to leave a spot open that one of your fellow forum frequenters would have traded an arm to have...just something to keep in mind for this coming weekend. Thanks.
  12. ronhowell
    681
    32
    Cypress, CA.
    I have to disagree. To me these channels have more to do with internal passenger headroom than they do with any affect on external air flow. They are far too shallow to have much aerodynamic influence. And the boundary layer is turbulent well before the leading edge of the roofline.
  13. fuzzy1
    10,712
    Thanks for the feedback. The Canadian and Euro specs posted since my question suggest that the cargo weight rating is actually higher than my '97 Suby. The sloping roof isn't a problem, as I don't use that volume for travel -- too much flying missile risk in a collision. The bikes fit into my little Accord, so no question they will fit in this too.
    So it ought to fully replace our Suby as a road trip car (except when chain checkpoints are possible), something the 2010 Insight doesn't appear quite big enough to do. But Suby will stay, for cargo hauling and winter, it is the Accord that will be replaced.
  14. Tideland Prius
    16,681
    Err, and how exactly does it increase headroom?? The inside looks like a normal car to me and the centre is curved up whereas on the outside, the edges of the roof are curved up.
  15. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Sorry, you're mistaken. they are for aerodynamics and help direct airflow. The interior of the roof is smooth, not riged like the exterior and, thus, is only as high as the lowest point of the roof.
  16. ronhowell
    681
    32
    Cypress, CA.
    Hmmm ... it appears on reflection you may be right, since the center section of the roofline is ~3/4" higher than the edges on my 2008. Although it doesn't appear so when viewed from the side. They could be forming channels for controlling the vortices coming off the forward roof pillars.
    Would love to see the full-scale wind-tunnel flow visualization tests Toyota must have performed, in tweaking the external profile to get the Cd down to 0.25.
  17. Manksgloob
    Manksgloob Member
    243
    So what's a good amount to tip the valet attendant?
  18. bshef
    bshef Active Member
    510
    76
    OC So. Calif.
    I offered a tip but they refused...telling me it was already taken care of!
  19. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    Me too, I offered the guy a 10 spot, he said "No thank you Sir, it's been taken care of
    It was quite the class event, I thought!
  20. HTMLSpinnr
    5,341
    920
    251
    The invites mention vallet parking is paid for and Prius Team has mentioned in the past that it's entirely taken care of. Enjoy the parking - the attendants in LA knew exactly to ask where the FOB was, etc. Totally different from 5 years ago where we had to attach instructions to the keys!
