2010 Prius problem
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by syberbear, Aug 21, 2013.
  1. syberbear
    syberbear New Member
    Twice in the last 6 months, car would NOT start.
    'RoadSide' assist used 'jumper' cables connected under the hood
    and when 'connected, car started and runs fine.
    Checkout the starter battery with electronic battery tester,
    and battery was fine with 12.61 V and 425 CCA, etc.
    Can anyone tell me what the problem is?
  2. frodoz737
    frodoz737 Top Wrench
    4,790
    2,553
    33
    Your battery may still test, but based on year model and two dead battery events, I would buy a new one before it gives up the ghost. I have a 2010 with 55K miles and have been monitoring mine more closely.
    52,731
    ditto. 2010 was a bad year for batteries.
  4. syberbear
  5. syberbear
    Thanx.
    It is certainly difficult to understand.
    Happened to go to 'Baxter Auto Parts' in Portland, OR
    where I am occassional customer, and the 'electronics' /'battery' guy
    used what appeared to be a sophisticated computerized
    tester into which he programmed the CCA and other
    'rated' info for the battery, and it showed excellent functioning condition.
    I will consider getting a new battery ( $158 for 'AGM' type ).
    It is appropriate replacement, but I'm still concerned whether
    it is a 'latent'/'intermittent' problem like a faulty solid state relay
    or 'gate switch' or whatever in the computerized hybrid system.
    I visited the 'dealer' for questions, and since the 'computer display' was fine,
    and the car is running perfectly, I didn't have the time to get involved
    with a diagnostic 'discovery process' at the time.
    I can't recall, and I'll check - - - but do you know off-hand if there is a
    'mileage limit' on the computerized hybrid system WARRANTY?
    since you have encountered similar problem. I only have about 40K miles.
  6. garglo
    garglo Member
    99
    45
    Port St Lucie, FL
    2020 Prius Prime
    I would check and clean the ground wire connection to the car body.
  7. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    Your hybrid system warranty depends on what state the car was originally sold ("delivered") in. If the state was compliant with the California Air Resources Board at the time you get a longer warranty. I believe it's good for 8 years and 100,000 miles if from a non-CARB state.
  8. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    That being said, this doesn't sound like a likely hybrid system failure.
  9. syberbear
    Thanx to all responses. Very helpful.
    Something in the back of my mind made me think the
    computerized hybrid system had the 100K miles warranty.
    I'll plan to stop by the dealer and see if they will do an
    accurate 'diagnoses' . Will pass on any info to all on this thread.
    By the way, the 'starter-battery' and the 'ground-wire'
    look 'brand new' and clean. I'll double check the grd wire this morning.
    Battery terminals look clean and fine and new with no evidence
    of corrosion as expected in the clean dry mounting area at the far rear
    passenger side corner under rear deck 'cover' panels.
    New question: Is there any 'unknown' power 'bleed' when the
    car is just sitting for two days other than the blinking 'display'
    indicator ?
  10. Paul R. Haller
    285
    43
    Walnut Creek
    In my 06 it ran and tested fine but if I turned on the radio for 10 minutes it was dead and would not start the car. I had to wait for it to work again or get a jump. I bought a new battery from elearn aid in 2010. Since then, I have had no troubles.
    -Paul R. Haller-
  11. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Since you do not list any location, it is hard for us to know what your car's warranty might be.
    Your 12 v battery has/had a manufacturer's warranty, not from Toyota.
    It is 'early' for the 12 volt battery to be worn out, but it can fail any time.
    Incorrectly jumping your Prius is a multiple thousand dollar error, so do not wait too long.
  12. Paul R. Haller
    285
    43
    Walnut Creek
    All modern cars have some small miliamp draw even with the key off. I've never actually metered the Prius. Average for radio presets, clock, PCMs, ECMs, etc, are about 50-100 miliamps. I have, with a new battery, left the car at the airport for over 3 weeks with not an issue. I, however, never tried that with my bad battery. All the battery does in the prius is boot up the ECM and PCM and start/run software. Once the car is on, all accessories are run through the invertor. I do not remember the sequence for the gen 3 prius but in gen 2 you could monitor the battery output in a dignostic screen in off, on, and run, modes. Perhaps someone here remembers the way to access the 3rd gen voltage diagnostic screen.
    -Paul R. Haller
