2010 Prius random misfire
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Nick Not Mechanic, Mar 24, 2023.
  1. Nick Not Mechanic
    Nick Not Mechanic New Member
    Nashville TN
    Hello, my girlfriend's 2010 Prius (116k miles) is running very rough. I know this is a long post, but any help is appreciated.
    It initially was throwing a misfire in cylinder 4 and an EGR fault (unfortunately I did not note down the exact code). So I swapped the ignition coil and spark plug with cylinder 1 and the issue did not follow. I then concluded it was the EGR system. So I replaced the EGR valve with a new one, and cleaned out the manifold, connecting pipe, and the EGR cooler. After this, the car was now throwing codes for Cylinders 1 & 3 and "Open EGR Circuit". So I checked the resistance of the wiring from the ECM to the EGR and all were in spec. I did the same for voltage and the same story. The CEL would return every time I reset and the car would run rough so I decided to try the very unlikely chance it was the ECM. Got a used one off eBay and installed it in the car. The EGR code did not return, but now it is throwing the random cylinder misfire P0300 and cylinders 1 & 2, but it changes randomly.
    I have checked the insides of the Cylinders with a borescope and from what I could tell they looked fine. The car is not burning oil or coolant, but I checked the coolant for exhaust gases using an AutoZone tester and the color did not change from dark blue. So I don't believe it is a blown head gasket. I blocked the downstream side of the EGR valve as the Car Care Cut mentions in his video and the car is still running rough for the most part (at low speeds it will run fine for short bursts). There is a slight rotten egg smell to the car after running it, which makes me believe it could be the catalytic converter, but I thought that it would throw a specific code? Any help would be greatly appreciated as I am kind of at a loss.
    52,891
    did the plugs look okay? they should be changed at 120k anyway with dealer only oem
  3. Nick Not Mechanic
    Nashville TN
    Yes, the plugs looked good, but I did also replace them just to be sure.
  4. Priipriii
    Priipriii Member
    231
    67
    I have the exact same problem, but just a different cylinder. Hopefully someone here can shed some light
  5. AzusaPrius
    AzusaPrius Senior Member
    2,258
    952
    Try cleaning the MAF sensor and then disconnect the 12v for 3-5 minutes.
  6. Nick Not Mechanic
    Nashville TN
    I had cleaned it out at the start, but I did not disconnect the battery at all. I will give that a try though!
  7. Nick Not Mechanic
    Nashville TN
    Cleaned the MAF and still got the same issue.
  8. Tbkilb01
    Tbkilb01 Active Member
    218
    187
    Louisiana
    Did you check for Spark at coils?
  9. Nick Not Mechanic
    Nashville TN
    Sorry for the delay, but I believe I have finally figured out what was wrong. I was not getting a code for the catalytic converter, but since the car started to misfire quite suddenly I think the O2 sensors never got enough data to throw a code. To test this theory, I drove the car around my block so that it would heat up and took the temperature of the exhaust manifold outlet and the outlet of the catalytic converter. The upstream temperature was just below 600°F while the outlet of the Cat was ~100°F. This leads me to believe that the Cat is all but completely clogged. This makes sense as the car was slightly curbed right before it began to misfire.
    I will be ordering a cheap Ebay Cat since I am in Tennesse and I plan on selling the car soon anyways. Unless anyone has a reason why I should opt for a more expensive Cat? Any tips are appreciated.
  10. bisco
    52,891
    don't forget to put the old cat up for auction
    Nick Not Mechanic and Tbkilb01 like this.
  11. douglasjre
    douglasjre Senior Member
    2,250
    751
    Null, NL
    Clogged cat doesn't cause random misfires and an eBay cat is going to create a new p0420 code
    Tbkilb01 likes this.
  12. Nick Not Mechanic
    Nashville TN
    If clogged enough, would it not cause back pressure in the cylinders? Which would make it run ultra-lean causing a misfire?
  13. douglasjre
    2,250
    751
    Null, NL
    Doubtful.
    Pull cat and inspect before you go ordering one.
    Blow air thru intake manifold EGR circuits (there are 4)
    Mark your coil packs w numbers.
    Got screenshots of techstream data?
  14. Nick Not Mechanic
    Nashville TN
    I will definitely pull the cat before ordering a new one. Unfortunately, I will not be able to do this until this weekend as I will be traveling.
    The intake manifold I have taken off and cleaned twice now. The first time it was rather dirty, but not fully blocked for any of the ports. After cleaning it there was no build-up at all even after some test drives.
    For the Coil packs, I bought a new one as well as a new spark plug and swapped cylinders which did not change anything. I was hoping the issue would follow, but it threw the same codes.
    I do not have Tech Stream, but am trying to get it. Even the lite version seems a bit pricy, do you know if any of the free versions work? I am quite skeptical of them.
  15. Mendel Leisk
    42,376
    Then there's likely nothing wrong with your current coils.
    douglasjre and Nick Not Mechanic like this.
  16. ChapmanF
    19,058
    Sometimes people give themselves unnecessary sticker shock by looking at certain bundled Techstream offerings and thinking that's the price of Techstream.
    To run Techstream, you need a Windows laptop, which you might already have, and a J2534 dongle to plug in to the car, which you have to buy, but there are lots of choices at various prices, and the Techstream software (simply download), and an activation you buy to make the software work.
    You can buy activations two days at a time for $65, or a full year at a time for $1295. If you run a shop and will use it a lot, you might spring for the $1295 for a year, but for a typical DIYer the $65 for two days of use will be fine, and a sight less than the cost of going to a dealer for them to plug in their copy of Techstream and tell you what it said.
    The J2534 dongles can cost anywhere from around $20 to around $500 or more. The one that Toyota tests and recommends, and will actually help you with if something doesn't work, is around $500. The ones around $20 are counterfeits of another one that was already cheap before it got counterfeited, and they mostly work but often with some issues, and in the middle range around $80 to $170 or so are some reportedly solid choices.
    When you see the price of a bundle like "Techstream Lite", that's just a combination of the Toyota-approved dongle (around $500) and the year-long Techstream activation (normally $1295), which would normally add to around $1800 but is discounted as a bundle to, I think, $1495. It really only makes sense if the $500 dongle and the year activation are what you want.
    There are also hacked versions of Techstream that might possibly forget to ask you for an activation, so you save the $65 per two days, but that's another topic. Anyway, you still need to provide a Windows laptop and buy a dongle.
  17. Nick Not Mechanic
    Nashville TN
    Thanks for the info! I didn't even see the daily activation fees. I am just DIYer and highly doubt I would use it again so the two-day key would be perfect.
    Right now my plan is to remove the CAT and confirm that it is indeed blocked. I will likely start the car and see if performance improves with the exhaust system removed. If it does not then I will reinstall the exhaust system and use TechStream to see what's going on. I would do this before but am quite confident the CAT is clogged as mentioned above.
  18. ChapmanF
    19,058
    Oh, if you have the car for a while you'll certainly use it again, but two-day increments will be fine, you won't need to keep it live all year.
  19. Nick Not Mechanic
    Nashville TN
    Oh, I am sure I actually would use it again quite quickly, but right now the plan is to sell the car in less than 4 months lol.
  20. douglasjre
    2,250
    751
    Null, NL
    I got my cable for around $50 with the Xhorse driver which is the best one. I got my software for about $12 on fleabay.
    What does the subscription offer?
