2010 Prius random misfire
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Nick Not Mechanic, Mar 24, 2023.
  1. ChapmanF
    19,002
    Legitimacy and peace of mind, mostly.
    When you get the 'alternative' downloads of Techstream that 'forget' to check your subscription, you're getting software that has been tweaked by the kinds of folks who put tweaked software up for you to download. The 'doesn't check for subscription' tweak is the one you know about. You takes your chances that they haven't included another thing or two they might like to do on your computer while they're at it.
    Also with untweaked Techstream and a paid subscription, you have the option of calling support if you're having trouble with it. And if you have a network connection, you can use the handy features where it will link you straight from trouble codes into the online repair manual, check whether your ECU firmware versions are current, and so on.
    Nick Not Mechanic and douglasjre like this.
  2. veegish
    veegish Junior Member
    Spanish Fork, Utah
    Could you PM me with a little more detail on what you got? That sounds like just the setup for me!
  3. ChapmanF
    19,002
    One little detail: XHorse was the actual name of the company that made the original, non-counterfeit, Mini-VCI dongle and its driver.
    So of course it is also what all the counterfeit Mini-VCIs and drivers claim to be. That's how counterfeiting works. So if a driver that says XHorse is the best one, then they're all the best one, but they might not all be the same. ;)
    douglasjre likes this.
  4. douglasjre
    douglasjre Senior Member
    2,250
    751
    Null, NL
    Fleabay has loads of them
  5. Nick Not Mechanic
    Nick Not Mechanic New Member
    Nashville TN
    Ok, sorry for the hiatus, but I have been gone for work so I haven't been able to work on the car. Anyway, I was finally able to get the exhaust off and check the catalytic converter. Looked very clogged, but I have no idea what a clear one would look like so the real test was starting the car with the exhaust system off. Though loud, the car ran great for the 30 seconds I let it idle!!!! There wasn't any misfiring that I could hear.
    Now I will buy a cheap aftermarket CAT and figure out a way to plug off the coolant lines. If anyone has a suggestion on replacements I am all ears (and not in Cali, Colorado, nor New York :) ). Right now I am thinking worst a case scenario the car with throw code P0420, but I have read a decent amount of reviews of aftermarket ones that claim to not throw the code. They can't put anything on the internet that isn't true so they must not throw the code! ;)
  6. douglasjre
    2,250
    751
    Null, NL
    Send pix of cat internals
  7. Nick Not Mechanic
    Nashville TN
  8. Nick Not Mechanic
    Nashville TN
    Not sure if this helps. Before I had taken it off I had sprayed seafoam into the O2 sensor port in the exhaust manifold which is probably why it looks relatively clean.
  9. douglasjre
    2,250
    751
    Null, NL
    I'm confused by the statement I circled in the photo below
  10. douglasjre
    2,250
    751
    Null, NL
    Please provide the photograph of your tech stream fault codes
  11. Nick Not Mechanic
    Nashville TN
    Yeah, I will be honest I have no idea why I put that. I'm not sure what I was looking at, but when I first took it off, I remember thinking it looked dirty then going back the next morning and realizing it was pretty clean.
    I was holding off on Techstream since I don't believe I will ever need it again (I realize I might end up regretting that). I thought the two tests showing the exhaust manifold significantly hotter than the downstream side of the cat, along with the issue going away with the cat back off would be sufficient proof that it is indeed the Cat that is failing. Is my logic/conclusion off? I do understand that this is definitely not how one would go about working on a customer's car, but as this is my personal car I am more laxed.
  12. Paladain55
    Paladain55 Active Member
    414
    172
    The South
    Did you try also just unplugging the electrical connector on the EGR valve and seeing if the misfires go away? This is how we diagnose EGR issues now locally. A lot of the time people clean the EGR system incorrectly and the misfires get worse, and if we unplug the egr valve and it goes away, we diagnose it as it was cleaned unevenly so the egr flow to the individual cylinders is all out of wack.
  13. Nick Not Mechanic
    Nashville TN
    I did, I ran it with the EGR valve unplugged and blocked. As well as unplugged and open.
    Paladain55 likes this.
