2010 Prius rattle after idle
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by LNDheart, Oct 6, 2016.
  1. LNDheart
    LNDheart Junior Member
    Sarasota, Fl
    I thought maybe it was the throttle body (just had cleaned) which was in dire need of cleaning but I still have a rattle after I've been idling for awhile and I give it some gas. Doesn't seem to happen when I go above 30 and stay at the same mph but the minute I slow down or come to a stop sign, as soon as I give it gas again I get the rattle/putter!! Seems to occur allot on hotter days as well. Any insight would be super!! Thanks!
    Oh I also have a rough idle when it's recharging my battery, connection?!?
    wheelz1980 likes this.
  2. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    your egr system is clogged up
    LNDheart likes this.
  3. liskipper
    liskipper Member
    374
    79
    Long Island, NY
    There is a free extended warranty offered by Toyota for a defective EGR valve.
  4. LNDheart
    Sarasota, Fl
    There is!?! Excellent!! So just give my local Toyota a call and let them know my EGR valve is malfunctioning?
  5. LNDheart
    Sarasota, Fl
    Thank you both so much also!! I was at my wits end with what it could be!
  6. Mendel Leisk
    42,302
    Don't go in expecting an all positive experience at the dealership. They will very likely want a "diagnosis charge" to ascertain the problem, and could end up: no trouble code, therefore no problem.
    Just expect the worst, then maybe you'll be pleasantly surprised, lol.
  7. LNDheart
    Sarasota, Fl
    Oh man, yeah my dealership charges $99 off the bat :/ is it an actual recall or just something they have seen allot of therefore are fixing free of charge?
  8. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    The recall notice states that you have to have the P0401 code and have it verified.
    Some on here reported this and the dealer only replacing the valve. This still leaves the cleaning aspect:).
    Do you have any lights on the dash when the rattle occurs? How many miles on your Prius?
  9. LNDheart
    Sarasota, Fl
    Nope no lights unfortunately, and we're just over 100,000.
    Raytheeagle likes this.
  10. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    What maintenance outside of the manual has been done? Checked the PCV valve? Any oil consumption? Have you ever used any fuel injector cleaner? What type of gas do you buy (top tier, or whatever is available)?Ever clean the egr pipe?
    Keep the answers coming:).
  11. LNDheart
    Sarasota, Fl
    Outside of the throttle body getting cleaned this week nothing outside of routine maintenance. I really haven't notice an increase in oil consumption, my gas mileage hasn't been up to par but I attributed that to the throttle body. My mechanic said fuel injector cleaner doesn't work so no lol:) I did buy the cheapest gas this week (wawa) which I figured had something to do with it being more noticeable this week. But this seems to happen regardless of where I buy. So sounds like I should check with Toyota to see what they can resolve and if they want to charge me go to my local mechanic who will charge me 1/4 of what the dealership would:)
  12. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    Sounds like your intake manifold and egr system might be clogging or have restrictions.
    But it sounds like your mechanic is providing "excellent" advice and service.
    All the best(y)
  13. Darth_Eric
    Darth_Eric Junior Member
    San antonio, texas
    Have the same issue. How much would a egr valve cleaning cost at dealership or mechanic generally?
  14. Mendel Leisk
    42,302
    A dealership typical won’t clean, only do parts replacement. The parts alone would be about a grand, and likely at least 3 hour’s labour on top of that. It’s basically ridiculous to go that route; none of those parts, with possible exception of the EGR valve, need replacement.
    Independent mechanics knowledgeable and willing to do a thorough cleaning are few and far between. Tampa Hybrids in Florida and Hybrid Pit stop (in LA?) are the only ones I’ve heard of.
    it’s good you’ve posted your location; a PriusChat member local to you might be willing to help out. If you can DIY and just need a bit of help and tips, that’s the best scenario.
    The DIY cost is basically a days labour, a few cleaning products, access to fairly standards tools. Maybe also replacement of the intake manifold gaskets, depending on the miles.
    see first two links in my signature; on a phone turn it landscape to see signature.
    #14 Mendel Leisk, Jun 6, 2023
