2010 Prius Rattle/Knock Help
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Vince R., Jun 26, 2018.
  1. Vince R.
    Vince R. New Member
    SoCal
    My 2010 Prius with 165k miles started to rattle/knock when accelerating about a month ago. Since then, every time the ICE starts it rattles. I have no CEL but have had pending codes of P0302. The engine does not use oil (changed every 7500mi or less), nor does it loose coolant. I have cleaned the MAF, EGR valve, tube, cooler, intake manifold, and throttle body. I have replaced the plugs and PCV valve. Conducted spark test (good), compression test (good), Tested the EGR (20.8 ohm), MAF (1.76KOhm @ 85 degrees F), Injectors (13.3 to 13.5 ohm at 90 degrees F), Coil voltage is good. Swapped coil 2 with coil 4 and no pending codes to tell if the problem followed coil 2.
    Any help diagnosing my problem would be greatly appreciated.
    Thank You!!!
    BTW - I posted this in another thread and it got lost in the shuffle.
  2. cnc97
    cnc97 Senior Member
    1,422
    1,535
    38
    Evansville, IN
    This is likely the same knock that plagues the 2010 MY. PCV hose has filled manifold below throttle body with the PCV vapors. They cool and turn to liquid. On ICE start, they get sucked into engine. Resulting in a knock for a few seconds. Clean out manifold. Add catch can to PCV hose. The knock will go away. Mine has been silent for 3300 miles. My Prius has 213k on it.
    mjoo likes this.
  3. cnc97
    cnc97 Senior Member
    1,422
    1,535
    38
    Evansville, IN
    Also, if available buy ethanol free gasoline. I am getting consistent 60 mpg in town since my change to E0.
  4. Vince R.
    Vince R. New Member
    SoCal
    Thank You for the info....looks like a catch can is in my future.
  5. Vince R.
    Vince R. New Member
    SoCal
    Thank You, I didn’t think of non-ethanol gas. I will search for that in my area. I am in So-Cal so it may be difficult. Thanks again!!
  6. Arnel Santiago
    Arnel Santiago New Member
    Daly City
    You did a lot of troubleshooting prior. Did the oil catch can work? Looks like replacing the PCV is not enough.
  7. Tcortez
    Tcortez Junior Member
    25
    42
    Lancaster
    Did you ever fix the car
  8. Tcortez
    25
    42
    Lancaster
    Did you ever get the car fixed , I’m having the same issues.
  9. Tcortez
    25
    42
    Lancaster
    0B5B9F76-584A-47C5-A2CF-EE9064E0B21E.jpeg I found my issue , I bought a cheap iPhone boroscope and found cylinder #2 has coolant in it. I guess I have a blown head gasket, the car has 220,000 miles , I went to Autozone and bought some K seal, the car runs great when running , I’ve been losing a little bit of coolant every night. Time to sell this car.
    mikey_t likes this.
  10. wheezyglider
    wheezyglider Active Member
    247
    178
    SF Bay Area
    Ouch that hurts. Clear diagnosis though - thanks for posting that picture. I also scoped mine and they look waaaay dirtier at 135,000 miles. No coolant for me, just carbon. If you get it rebuilt let us know the cost and results. But I wouldn't blame you for moving on.
  11. FnRedPrius
    FnRedPrius Active Member
    100
    121
    Pilot, NC
    The Kseal will migrate to the cat converter and screw that up (I've heard). I've seen bunches of Gen 4 engines on FleaBay and help is everywhere.
  12. Tcortez
    25
    42
    Lancaster
    So far no start up knocking since pouring in K Seal in the coolant container. I’ll keep you guys posted , I’ve been monitoring my coolant temps and it looks good with a scanner , temp around 196 f going up the freeway, My car doesn’t over heat and not losing coolant anymore. Since I bought the car 4 years ago used it’s been a good car and has never left me stranded , the only change I have done is replace the 12 volt battery. Since pouring in the k seal I have no white smoke coming out during start up. I have also installed a oil catch can. I’m actually thinking of replacing the head gasket , I see a diy head gasket replacement on YouTube.
    Raytheeagle and The Critic like this.
  13. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    Can you post a link to the boroscope that you used? The photo quality looks awesome compared to the one I have on my Autel.
    Raytheeagle likes this.
  14. Tcortez
    25
    42
    Lancaster
    This is The boroscope I used
    RMB, Raytheeagle and The Critic like this.
  15. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,522
    Bay Area, California
    2019 Prius Prime
    That’s what I have:).
    Compliments of @Pedal Logic ;).
    Works great(y).
    RMB likes this.
  16. cnc97
    cnc97 Senior Member
    1,422
    1,535
    38
    Evansville, IN
    I can’t see the link to the borescope. WAAAA! LoL
  17. Raytheeagle
    11,267
    15,522
    2019 Prius Prime
    It’s a Depstech:).
    The Critic likes this.
  18. cnc97
    cnc97 Senior Member
    1,422
    1,535
    38
    Evansville, IN
    I need that. There’s my next impulse buy!
  19. spiralhelix
    spiralhelix Active Member
    255
    217
    Illinois
    Ha, I got that same one last year to see drain clogs! Unfortunately it’s not great for drains :(. I was thinking I need a 3D printed device to keep it out of the liquid and help with pipe bends. Sorry, /endofthreadjacking
    -Spiral
  20. Raytheeagle
    11,267
    15,522
    2019 Prius Prime
    I’ve used it a handful of times and it’s great :).
    Pairs well with an iPhone ;).
    Nice addition to the tool box(y).
