2010 Prius - Rear Window Defrost Inop
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Eric Smallwood, Dec 20, 2025.
  1. Eric Smallwood
    Eric Smallwood Junior Member
    Lawrenceburg, IN
    When pushing the button, no light. Not working at all. Any ideas?
  2. Tideland Prius
    16,683
    Do the mirrors heated up? That way you can tell if it's the switch itself or the rear defroster wires.
  3. Tombukt2
    Tombukt2 Senior Member
    13,875
    2,521
    Durham NC
    He wire or lug disconnected so y cause no light I don't believe . Just no heat . Usually in my stuff the adhesive has loosened at one of two lugs on back glass . Atom adhesives is the glue . Course on a gen3 i do not know . 8 have this lug issue right now on two gen2 on site mirrors work back glass no we have MFD no ligh I think on hen2
  4. Eric Smallwood
    Lawrenceburg, IN
    Wow, I wish I could understand what you are trying to say. Try using Google translate.
  5. Tombukt2
    13,875
    2,521
    Durham NC
    The little Chrome piece came off or is loose not transmitting electricity to make the heat atom cement is the glue . D on can show this used correctly see if trying to undo connectors at rear glass leave you with chrome lug in hand instead of plug.? If so now use the Atom cement to return it to glass plug it up tomorrow
  6. Eric Smallwood
    Lawrenceburg, IN
    After I pulled all of the plastic trim off of the rear hatch and verified all connections were sound, I swapped out the control panel from another Prius and it fixed the problem. Apparently, the Rear Window defog switch was shot. This is the 2nd panel I have had to replace. The last one was so dim, you could barely see it.
    Brian1954 likes this.
  7. ChapmanF
    19,059
    With access to a scan tool supporting active tests, it's also possible to use the scan tool to command the rear defogger on. If that works, and pressing the button doesn't, then you'd immediately suspect the button, or communication from the control panel to the A/C amplifier. Or, if it didn't work that way either, you'd move on to suspecting the amplifier or downstream.
