2010 Prius Recall Software Update Experiences
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Danny, Feb 10, 2010.
  1. mad-dog-one
    mad-dog-one Prius Enthusiast
    1,181
    421
    Whereabouts Unknown
    As opposed to they plugged it in, my car began to smoke, flames erupted, the fire department arrived ... my insurance agent said my policy was out of date because of a technical glitch ... no more worries about the brakes. I certainly hope my experience is boring. :confused:
  2. Airbalancer
    Airbalancer Active Member
    892
    73
    Cobourg, On, Canada
    :rolleyes:
  3. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    I brought my car to the dealer this morning (no appointment) and got it back this afternoon. Pretty painless. On the drive home I didn't notice any difference in brake feel, although the Corolla loaner's acceleration felt like a rocket ship in comparison! :p
  4. cireecnop1
    cireecnop1 New Member
    338
    Pueblo, CO
    I agree that the legal end of it could potentially be "bad" but I am comfortable with the way the car brakes , although I have experienced the momentary loss of brake power its not something that isnt solved by applying firmer pressure on the pedal.
    I read the posts on the Prius software update and one of the answers just has me concerned;
    Q6. Can Toyota provide in-depth technical details on the software update?
    A6. The precise technical details are not available. The result of the software change is to shorten the ABS braking force delay and to lower the pedal pressure required to stop. The result is shorter stopping distance and a more positive braking feel.
    to me this sounds like the pedal will become more sensitive when braking, I like how the brakes work now, its easy to have the car regen rather than slow down with the mechanical brakes.
    my 2cents, thanks for listening
    :p
  5. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    My butt dyno suggests a slight change in responsiveness and a change in the balance of friction and regen. I plan to do a bit more driving tonight with less traffic to vet this out for certain.
    Update - hard to say if regen/friction ratio changed after-all - at the speeds I was testing, it was hard to say for sure, though it seemed that < 40mph, to get more into the full charge range on the HSI, it felt like there was some friction in the balance.
    What has change is the pedal sensitivity, and probably for the better. The transition from regen assisted braking to pure friction does seem a bit more transparent as well.
    I also tested ABS in two scenarios. Mixed surface (dirt/asphalt split on light braking) - I felt a slight reduction in force AS EXPECTED as the ABS did it's job maintaining traction on the slipperier side.
    The second ABS scenario was a "slam the brakes at 35mph" test. Definitely responsive, and startlingly quick in how quickly the car stopped (me and a full tank of gas as cargo). It caused the center armrest in the rear to fly down...
    Earlier tonight, I did note that modulating from a higher speed stop (50mph) toward the end for smoothness was a bit different, and a bit jerkier at first as I got used to the slightly different feel.
    Edit: One thing worth noting - my car has an April 2009 build date (within < 2000 cars of the lowest VIN for the plant) - it's entirely possible that the other two previous software versions may have changed braking feel from the start, thus some newer owners may not experience any change.
  6. HTMLSpinnr
    5,341
    920
    251
    I just downloaded the procedure from TIS - it is indeed IG-ON.
    The process also requires the use of the battery booster (GR8 Battery Diagnostic Station) in power supply mode to maintain 13.5 volts while flash programming.
    The process uses two different calibration files - one for 15" wheel vehicles (F152647106), and another for 17" wheel vehicles (F152647126). It would seem that there were actually 3 different calibrations prior to this - 15" was F152647103, F152647104, or F152647105 and 17" was F152647123, F152647124, or F152647125. This certainly would validate any assertion that Toyota is indeed continuously updating software within production.
  7. meannotgreen
    meannotgreen New Member
    33
    UK
    Has anyone noticed from all the reports in the forums whether the problem only occurs on models with one type of wheel or is it across the board?
  8. freedean
    freedean Junior Member
    Fort Lee, NJ
    Four Touring
    I believe the problem is across the board. I have the 17" wheels and have experienced the braking issue. Thanks for your detailed reports, HTMLSpinnr. I just called my dealer (Parkway Toyota in Northern NJ) and they said they won't be able to do the update until next week at the earliest.
  9. mbarrows
    mbarrows Illini Bird
    210
    17
    Frankfort, Illinois
    We have a Level V and have experienced this once. No big deal at all but I'm taking the car in Saturday for the A0B recall fix.
  10. mbarrows
    210
    17
    Frankfort, Illinois
    Does the use of the battery booster (GR8 Battery Station) require disconnecting the 12 volt battery prior to hooking up the booster? If so, do you lose anything in memory (such as preset radio stations, etc.)? Is it essential that the Service Technician do this or just recommended? I don't know if I should say something to be sure they follow the directions or if they'll just be insulted; I worry too much! :confused::unsure::noidea:
  11. HTMLSpinnr
    5,341
    920
    251
    No battery disconnect - just keeping overall system voltage at 13.5v (normal operating vehicle on is 13.5-14v as well. Without the boost, a weak battery could sag below 12V, causing the ECU programming to fail.
  12. duanerw
    duanerw senior member
    140
    lexington ky
    2013 Prius v wagon
    2010 prius flas has been done.
    I just returned from my dealership from having my 2010 prius flashed.I was there less than a half hour.
    This is my twelfth toyota and have no thoughts about it being my last.this was my first recall.
  13. NASCAR Mike
    NASCAR Mike Senior Member
    83
    Richmond VA
    Re: 2010 prius flas has been done.
    Is this a permanent update (ie memory is flashed) or do I need to worry about losing the update if my 12V battery dies for some reason.
  14. mmichaell
    mmichaell Member
    241
    chicago
    permanent. also the flash should not reset any of your settings (trip mileage, time, etc.) either.
  15. Danny
    Danny Admin/Founder
    7,093
    2,122
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    Here's my video in case anyone missed it:
  16. new2hybrid
    new2hybrid New Member
    35
    Delmarva
    There were some good points brought up. I was wondering if it was mandatory as well, and didn't even think about insurance! My insurance premium went down when I bought my Prius (previously had a Corolla).
    Rick, it sounds like you have a great dealership there. Much of my family relocated to the Phoenix area. Would be tempted to move just for a good dealership :)
    Off the topic a bit, when you get your tires aligned according to the maintenance schedule, it doesn't state if you need to get an alignment too. I haven't had service yet (just had it 2 months) but am shocked by the expense of an oil change. When researching before I purchased I got the impression it was less to maintain.
    Thank you! BTW, it's been great in the snow!
    Karen
  17. HTMLSpinnr
    5,341
    920
    251
    OT - Alignment was because I requested it (slight edge feathering). It was within spec. If you feel there's an alignment concern, warranty will cover an alignment check/adjustment within 1 year/12,000 miles. You'd be smart to take advantage of that if there's a legitimate concern.
  18. DeadPhish
    DeadPhish Senior Member
    2,010
    353
    Outer Banks of NC.. Retired to play golf and poker
    It does require synthetic oil which is more expensive but shortly you'll be getting a notice in the mail that instead of doing your oil changes every 6 months / 5000 miles that you only have to do them every 12 months / 10,000 miles. And, Toyota will be sending you a coupon for a free oil change.
  19. hiremichaelreid
    hiremichaelreid New Member
    451
    Ottawa/Aylmer, Canada
    I
    My experience here in Canada, area of Ottawa, is that I can't schedule an appointment for this recall work yet.
    Toyota Canada officially announced this recall on Tuesday, 3 days ago. This morning I called my closest dealer and was told they knew nothing about it, didn't have the "parts" yet, etc.
    I called Toyota Canada, was told that dealer was wrong, and was given a case # and a name to call at that dealership. I called two other local dealers and was given the same story as at the first, although the best dealer guessed they would have the needed info next Wednesday.
    Toyota Canada rep incorrectly told me the loss of braking was about 1 millisecond. (It's 700-800 I believe.) She also said this affected 300 some odd cars in Canada. ( TOYOTA CANADA : News & Events > News says 3273).
    My wife has had the car just over 6 months (among first in Canada) and only noticed this problem last week for the first time.
    Update as I type: First dealer just called back and said they got the info this afternoon and made an appointment with me for Monday. I'd guess we'll be among the first in Canada to get this update. I presume the software is the same as in the US but who knows ?
  20. kgall
    kgall Active Member
    984
    152
    Olympic Peninsula, WA
    Called up Caldwell Toyota (Conway Ark) at 2:30 this afternoon. Got the car in about 4. Took about 40 minutes and they also changed the annoying repeated reverse beep to a single beep.
    Only negative--apparently the dealers aren't being given a software update to change the oil change reminder from 5K to 10 K miles. Oh, well.
