2010 Prius sideswipe accident now when trying to start it says check hybrid systems
Discussion in 'Gen 3 Prius Main Forum' started by Jeremy Robertson, Nov 30, 2022.
  1. Jeremy Robertson
    Jeremy Robertson New Member
    Arkansas
    I lost control during a rainstorm and sideswiped another vehicle. Airbags deployed and front bumper came off. Try to start and it says check hybrid systems. Is it the airbags or some wires cut during the bumper falling off
    52,558
    probably the airbags, but there may be other damage
  3. Jeremy Robertson
    Arkansas
    i looked into replacing the air bags so i could drive it anyway. is it possible that the fuel cutoff needs to be reset? does a 2010 prius have 1? and if so where would it be located
    thanks for the help
  4. nicoj36
    nicoj36 Active Member
    518
    162
    Do you have an OBD reader? Scan the car with Dr Prius app to actually see the issue
  5. Jeremy Robertson
    Arkansas
    k
  6. Jeremy Robertson
    Arkansas
    Sorry. Thought I had answered but ..yes I do and I downloaded the app. Having the car towed here tomorrow. It's currently all the way across town. Hard to get transportation to get me there
    I will give it a shot. Thank you
  7. Miggsy
    Miggsy New Member
    Saint Louis
    Hey, did you ever figure out what was wrong with it?
  8. black_jmyntrn
    black_jmyntrn Senior Member
    1,729
    410
    2013 Prius Plug-in
    when airbags deploy... you need to have a new srs module thats under the center console replaced or reprogrammed in order to drive the vehicle. After my accident, I bought a used one and now working to clear the original module and keep it in the car with me in case something happens again and the bags deploy, ill be able to swap the module and continue driving.
  9. A.J
    A.J Junior Member
    59
    Worldwide
    Does the airbag module stop the combustion engine from starting? My hybrid engine starts to ready and drives, but combustion engine doesn't, still has Check Hybrid Engine on the screen. Could it be caused by the Airbag srs module due to the crash?
  10. bisco
    52,558
    time to scan the trouble codes
  11. black_jmyntrn
    1,729
    410
    2013 Prius Plug-in
    Yes, this is why once i get around to getting what i need to reset the old unit.. I plan to keep it in the car incase an accident where air bags deploy occurs, I won't need to have the vehicle towed.
  12. A.J
    A.J Junior Member
    59
    Worldwide
    Thanks, my VCI cable for Techstream arrived, i cleared the code via the PC software and the engine started.
    I guess Dr Prius and Carista or Car Scanner couldn't clear it. Because each time i clear with those, it comes back instantly. But Techstream cleared it and engine started.
    NOTE: Only steering and knee airbag got deployed
  13. black_jmyntrn
    1,729
    410
    2013 Prius Plug-in
    do you mind sharing which cable you purchased?
    did you have to replace any crash sensors?
