2010 prius sluggish acceleration in hot weather
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by ATlam, Jun 23, 2017.
  1. ATlam
    ATlam Member
    66
    57
    San jose
    the last few days my car has been sluggish, we just had a heatwave in california and it was in the 100s outside ( probably more inside the car) and the car's acceleration has been sluggish the first 10 minutes of driving, I have AC on full blast when starting. When I press the gas pedal, the car would hesitate like it has very little power, then some power kicked in, and then it hesitate again. It stopped once it picked up some speed.
    Other than the last few days, my car been running very well and the acceleration is very smooth and responsive, my mom drove the car and even commented on how great it runs.
    I recently had spark plugs and coolants changed, car has about 225k miles on it. Is this normal for the prius?
    52,880
    yes, the computers protect the battery in the heat. at 225k, it's probably somewhat weak to begin with.
    make sure the intake grille is clear, and the cooling fan is clean, and keep the a/c on high.
    try to park in the shade, or keep the sun from beating in the hatch. use sunshades, and tinting.
    ATlam likes this.
  3. ATlam
    ATlam Member
    66
    57
    San jose
    thank you for the fast reply, I'm glad to hear that, I'm planning to keep this car as long as I can!
    52,880
    batteries that rack up a lot of mileage like taxi's, instead of sitting around a lot, tend to do better. all the best!(y)
    ATlam likes this.
  5. JC91006
    16,937
    8,647
    I'm not sure if you're using ECO mode, but when it's really hot outside and your AC is blasting, don't use ECO mode
    Raytheeagle and bisco like this.
  6. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    What maintenance have you done on your Prius? Anything on the intake side? At 225k miles, there could be some carbon deposits on the intake. Do you have a lot of elevation changes on your commute?
    We have a 2010 Prius II with 157 k miles on it and going strong. I drive over Willow Pass on Highway 4 everyday and even in the recent heat wave, did well going up the pass with the AC on;).
    Do you drive in PWR mode a lot, or is it eco or normal mode?
  7. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    the dreaded egr cooler
  8. ATlam
    ATlam Member
    66
    57
    San jose
    I recently had the EGR valve replaced by dealer with warranty, is the EGR cooler part of that?
    dealer replaced parts number are 0400458137 and 2568537010. (thank god the light came on like a month before the TSB warranty expired)
    I drive in normal mode, the car drove fine today without the heat wave. I was just worrying if something in the car wasn't working right
    edit: looks like the second part number is the EGR cooler, so it has been replaced.
    #8 ATlam, Jun 24, 2017
  9. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    The second part number is the egr-to-cooler gasket. The first p/n is the EGR.
    VS985 4G ?
    Raytheeagle likes this.
