2010 Prius Solar Panel
Discussion in 'Gen 3 Prius Main Forum' started by SDP40F501, Jan 13, 2009.
  1. RobH
    RobH Senior Member
    2,376
    988
    70
    Sunnyvale, California
    So what would it take to add an aftermarket solar panel to a current model Prius? Seems like an 80 watt flexible panel, a couple of diodes, and a switch would do it. Does the 2010 setup use a separate ventilation fan, or just the standard A/C fan?
  2. carz89
    carz89 I study nuclear science...
    444
    47
    San Diego
    Why are we both compromising? I think they should have covered the entire roof with solar panels, and covered the entire interior ceiling with flexible LCD panels. You could select any overhead scenery you wanted (like the walls in Bill Gate's home), or have them flash random colors like the Cash Cab! ;)
    GG707 likes this.
  3. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
    I'm second to Pat, parking in the shade.
    Under the perfect shade, the max interior temp goes to the ambient temp, say 35C or whatever.
    Under the direct sun at the same ambient temp, the interior temp becomes more, say 55C or whatever even using the solar ventilation.
    It drives the standard A/C fan.
    Ken@Japan
  4. patsparks
    10,664
    567
    Adelaide South Australia
    If we had shaded parking along roadsides with solar panels on the shades feeding into the grid and the poles that hold them up would be a perfect mounting point for a EV recharge station.
  5. spwolf
    spwolf Senior Member
    3,156
    440
    Eastern Europe
    not really... for 4 months around here, we have 45C-50C in the shade, and it is much, much, much hotter inside the vehicle than outside.
    if you leave your car in the sun, of course it is worse, you wont be able to touch steering wheel for 10-15 minutes.
  6. Stefx
    Stefx Member
    336
    If it's 45-50 in the shade, no amount of fan ventilation would make it cooler in the car. The car cabin temperature would be the same as the ambient air temperature.
  7. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    Exactly, the point of Solar is to be AMBIENT, whereas without, you're significantly ABOVE ambient due to solar gain from the glass and other factors.
  8. spwolf
    3,156
    440
    Eastern Europe
    thats just not true. Interior temperature in the car does not equal ambient temperature during hot summers around here. And besides, you can not leave your car in the shade at all times, only when i get lucky with parking spaces.
  9. Stefx
    Stefx Member
    336
    what I am saying is that fan ventilations can't make a car cabin temp cooler than outside air temp OAT.
    With infinite fan ventilation, at best, the cabin would be the same temp as OAT, it's an asymptotic curve.
  10. patsparks
    10,664
    567
    Currently 38.8 C and that's a cool day this week so I know it can get hot in a car in the sun.
    I'd still like to see remote AC without the solar panel. That would be a very low cost addition.
  11. RobH
    RobH Senior Member
    2,376
    988
    70
    That's called a remote start.
  12. patsparks
    10,664
    567
    No it isn't Rob, it's called remote airconditioning. Remote AC is part of the Prius 2010 with sunroof package.
    It doesn't run any other system while it runs the AC from the battery.
  13. RobH
    RobH Senior Member
    2,376
    988
    70
    Ok, but you can add a remote start to a 2004-2009 Prius. Isolating the A/C function from "Ready" mode is something only Toyota knows how to do.
    I went looking for a solar panel to add to my 2006, and it doesn't look good. Flexible panels seem to be thin film technology, and they're about 5% efficient. Rigid panels are available at about 16% efficiency. 80 watts of a 5% panel won't fit on the roof. 80 watts of a 16% panel has plenty of space, but would amount to an airfoil on the roof. Prices are also ridiculous. Flexible panels run $20/watt, while rigid ones are about $5/watt.
    It appears that you have to use a rigid crystalline cell in order get enough power from the available space. And you probably don't want the glass cover that is normally used with them. So the Toyota solar panel uses unique packaging that you can't currently buy off the shelf.
    Apparently the alarm button on the keyfob has been replaced with the A/C button? And I would assume (hope?) that they increased the range to something like 1500 feet? I wonder if the increased range 2010 remote will work with 2004-2009 cars?
  14. patsparks
    10,664
    567
    We don't have an alarm button here, we live in such a nice society that Toyota know it isn't necessary here.
    I have plenty of room on my roof for solar panels, on my house roof. I expect a Prius will last 25 years on average but that is just half of how long I expect a solar panel to last. I'll get more out of a solar panel on my house so that's where I'll put mine. My house roof always faces north too!!
  15. RobH
    RobH Senior Member
    2,376
    988
    70
    Couldn't even tell you if the alarm button on my fob works. If it had better range, it would be useful for finding my car in a crowded parking lot. As is, it's useless.
    I've got 24 solar panels on my roof at home already. They do absolutely nothing to cool my car when it's baking in the sun at the shopping mall parking lot.
    One of the things I've done on a hot day is to leave the car in Ready mode with the A/C ON. I set the brake, shift to Park, turn off the MFD, and put a card on the dash to block the speedometer display. Then get out and lock the car with a mechanical key. It's really nice to get back to the car and enjoy the cool, instead of going from too hot air to even worse inside the car.
    The solar panel driven ventilation and remote A/C would be a much better solution. And I'd be willing to use it more often.
  16. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    It will work from 30 yards...
  17. spwolf
    3,156
    440
    Eastern Europe
    good one man, good one :).
  18. HTMLSpinnr
    5,341
    920
    251
    I'd hate to see my MPG figures after leaving my car for a couple hours like this :-(.
  19. Gakubuchi
    Gakubuchi New Member
    68
    Catalonia
    Just one question. The remote A/C works only in hot situations? I mean, what happens if the outside temperature is lower than the one you have presetted in the A/C? It will heat up the vehicle?
  20. patsparks
    10,664
    567
    More often than the panels on the roof of your house?
    Will you use the solar panels on the car roof for the 25+ years your panels on your house are guaranteed for?
    Could the remote AC be offered without the solar panels?
    Would remote AC and window shades work almost as well?
