2010 Prius-Sounds Like a Fan Running
Discussion in 'Gen 3 Prius Main Forum' started by Yaesu, Oct 24, 2018.
  1. Yaesu
    Yaesu Member
    111
    34
    Kentucky
    2010 Prius, 67,000 miles. One year old 12-volt battery.
    I was in the garage and heard what sounds like a small fan turn on somewhere in the vehicle. I opened the hood, doors, and hatch, but can't isolate the source of the sound. I put my ear to the louvered drive battery vent next to the back seat, but no sound or air was coming from it. I looked and listened for more than five minutes.
    Ambient temperature 81 degrees. Vehicle hadn't been run for several hours. The FOB is about twenty feet away from the vehicle.
    Any suggestions as to where the noise is being produced? And is it normal?
    52,855
    evap check, normal
  3. Yaesu
    Yaesu Member
    111
    34
    Kentucky
    Any further explanation? Where is the fan, where is the evap., and what is the purpose of both?
    52,855
    the fan is somewhere toward the rear, the evap is part of the pollution control system. sorry, that's all i know
  5. ChapmanF
    19,025
    There is a whole "evaporative emission control system" that is there to make sure the vapor that evaporates from your fuel is kept in the car and used in the engine, instead of escaping into the air. Most of the related parts are under the body in the rear near the fuel tank, though some are also under the hood. Every so often, when the car has been off for a while, it will do a self test to verify that it is still airtight. There's a little vacuum/pressure pump back near the fuel tank that does the test. If the pressure doesn't hold, you will get a warning on your dash and a code about a fuel system leak. If you don't, everything is good.
    I've never heard mine in action, but you can read all about it in the manual.
    -Chap
  6. Yaesu
    Yaesu Member
    111
    34
    Kentucky
    Thanks for the replies. I appreciate the information. I will check the manual.
    Raytheeagle likes this.
  7. High Mileage
    High Mileage Active Member
    136
    238
    2018 Prius Prime
    Yaesu, as chapman said this sounds like the evaporative emissions pump running to test the integrity of the evaporative emissions system. I have encountered this several times going into the garage at times after the car was parked for several hours. I believe if you open the drivers door it will cancel the test, one way to know if this is indeed what you are hearing. The pump is part of the evaporative canister that is mounted under the vehicle just behind the fuel tank. This test is ran after the vehicle has sat for X number of hours, the fuel tank level is between X amount and X amount, the ambient temperature is above X degrees and below X degrees. The X has to do with parameters that I do not know, but must be met for the test to be ran.
    m.wynn likes this.
  8. Yaesu
    Yaesu Member
    111
    34
    Kentucky
    That makes sense, because the fan doesn't run very often.
  9. m.wynn
    m.wynn Senior Member
    684
    1,230
    Queensbury, NY
    ...and for anyone wanting to catch this evap self-check in the act, it happens at ~5 hours post shutdown. Put your head down by the driver side rear wheel well and you'll be a believer. I'm a garage tinkerer and have heard this pump buzz for it's several minute cycle many times on both my deceased 2010 and now my 2014. It's an odd thing for sure when you first experience it.
    Bay Stater and Raytheeagle like this.
