2010 Prius Spark Plug Change
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by RobRig, Oct 13, 2020.
  1. RobRig
    RobRig Junior Member
    Richmond, VA
    I changed my spark plugs due to a cold-start rough running engine and just put up a video on YouTube for those of you who my be interested. Removing the engine compartment panels can be found on videos posted by others on YouTube. I made the video after researching and seeing some of the problems/ questions other had regarding this job .
  2. pjksr02
    pjksr02 Active Member
    534
    227
    Connecticut
    Uh oh. Ever cleaned your EGR cooler and intake manifold? How many miles on the car?
    Raytheeagle and Mendel Leisk like this.
  3. Siward
    Siward Active Member
    314
    128
    Toronto
    How long of a socket extension did you use? I have a lockable 6" extension that I want to use, but I don't know if it is long enough.
  4. Boffin
    Boffin Member
    43
    66
    Maryland
    200K? You really need to bite the bullet and do the EGR / Intake manifold clean out.
    NutzAboutBolts has done it all:
    The EGR system is the weakest point on these cars. Ignore it and you'll have the fun of dumping the car or replacing the head gasket.
    #4 Boffin, Oct 15, 2020
  5. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Where did 200K come from?
  6. Boffin
    Boffin Member
    43
    66
    Maryland
    Grit, the OP mentioned it in his video.
  7. Mendel Leisk
    42,343
    I think you're good, but it's been a while. To be sure, pick up an additional 3". The latter's a very useful length, you'll need it for other applications.
    If your spark plug socket has a rubber insert to grip the plug, tape the joints between extension(s) and socket. Particularly after torquing the new plug; there's a risk the socket will stay on the plug when you pull the extension out.
    RobRig and Paul E. Highway like this.
