2010 prius spark plug tube seal replacment
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by hardish, Mar 16, 2019.
  1. hardish
    hardish Junior Member
    2001 Prius
    Replaced spark plugs and found some oil in #4 plug. Any instructions on how to change the tube seal?
  2. Mendel Leisk
    42,323
    Do you mean seal of the tube to the cylinder head?
    I was just reading about that, in one of my cylinder head refurb pdfs, repair manual excerpt. It specs the sealant and instruction for tapping it in.
    Can post in a bit.
  3. Mendel Leisk
    42,323
    It's in this, page 15 (of 20):
    ThePrius11 and wvs2003 like this.
  4. wvs2003
    wvs2003 Junior Member
    @hardish , did your sparkplugs look like mine shown in below pics?
    I am not sure if i have this tube seal problem which leads to oil on the plug. I am not even sure if the residue on my spark plug's thread is oil. I thought the oil came from having oil coming from PCV valve, PCV hose, into Air Intake Manifold, and then into engine.
    160081_20190120_172707.jpg 160082_20190120_172824.jpg 160083_20190120_172905.jpg
  5. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    Most likely, you have a leaking spark plug tube seals. There are 4 seals inside the valve cover which block oil from entering the tube. They are a pain in the butt to change.
    I have a set of 4 leftover from my engine overhaul gasket kit if you want them. Mine were not leaking (and they are easily accessible later on) so I elected to not change them.
    Raytheeagle likes this.
