2010 Prius stereo difference between II and IV
Discussion in 'Gen 3 Prius Audio and Electronics' started by ImAnOilburner2, Oct 24, 2021.
  1. ImAnOilburner2
    ImAnOilburner2 Junior Member
    Central Alabama
    Unfortunately my daughter lost her 2010 Prius II in an accident. I was able to recover the JVC stereo headunit that I had installed. I also grabbed the camera I put in but not the cable as I had done too good of a job routing it from front to back.
    We replaced the car with a 2010 Prius IV with nav. She would like her JVC installed as Carplay is better than factory nav to her. Is there anything different like amps/speakers etc? And can the factory camera be used with the JVC?
    Thank you!
  2. AzusaPrius
    AzusaPrius Senior Member
    2,255
    942
    She now has a premium system with more than four speakers, the rear camera will most likely not work.
    Try crutchfield.com you can enter your car details and see what harnesses they have available.
    I have the same IV and happen to like the stock system.
    I use waze on my phone when needed.
  3. AzusaPrius
    2,255
    942
    Found this on the Metra website so you can still use the stock reverse camera with an aftermarket radio. Screenshot_2021-11-14-09-54-42-1.jpeg
