2010 Prius stopped on busy street!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Mamalucy, Oct 14, 2025.
  1. Mamalucy
    Mamalucy Junior Member
    22
    Culver City, CA
    Am original owner, car has been babied 123,500 miles, regular maintenance by Toyota certified mechanic. For past week "check engine" light came on. I was driving to mechanic when the car suddenly stopped in the road with "Check Hybrid system" yellow triangle light flashing. Lucky it didn't stop on freeway! Got a tow to mechanic, who thinks it's a bad electric water pump, wants to replace it & thinks inverter will recharge. Thinks hybrid is OK.
    My question here is what else could happen with a almost 16 y/o Prius that I should be aware of. My mechanic says it should last another 10 years, but if replacement parts are expensive, might be better to get a newer car?
    Thank you for any advice.
    52,837
    the hybrid battery, brake actuator, egr circuit and head gasket are your 4 likely big expenses.
    1) hybrid battery: 3-4k
    2) brake actuator 3-4k
    3) egr cleaning 1K
    4) head gasket 2-3k or if the whole engine blows, as much as 8-10k.
    is it burning any oil?
    Mamalucy and Brian1954 like this.
  3. Mendel Leisk
    42,332
    Has it had brake or transaxle fluid changes? Periodic brake service?
    Ever cleaned the EGR system?
    Mamalucy likes this.
  4. Mamalucy
    22
    Culver City, CA
  5. Mamalucy
    22
    Culver City, CA
    Thanks for your feedback! It's had regular maintenance, and has been problem free until this.
  6. Mamalucy
    22
    Culver City, CA
  7. Mamalucy
    22
    Culver City, CA
    Thanks for your replies. It has been a wonderful car overall. Problem was bad water pump, and I delayed a month taking it in, since check engine light turned off intermittently.
    bisco and Brian1954 like this.
  8. Mamalucy
    22
    Culver City, CA
    Thanks for responding. Sounds very expensive.
  9. Mamalucy
    22
    Culver City, CA
