2010 Prius switched motor with 2013 Lexus
Discussion in 'Gen 3 Prius Technical Discussion' started by Phil Yaden, Nov 2, 2024.
  1. Phil Yaden
    Phil Yaden Junior Member
    22
    johnson
    Started ran perfect for a couple seconds. Now get a cam sensor and MAF code and IAT. Do I need to install the old ones?
  2. rjparker
    rjparker Tu Humilde Sirviente
    11,133
    6,982
    Texas Hill Country
    If it “ran” for ten seconds or less it probably did not start the engine. The electric motor revs the engine at high speed and it sounds like a start.
    I would check connections, grounds and pcv hose first. Be careful of too many start attempts discharging the hv battery.
    Brian1954 likes this.
  3. Eddie25
    Eddie25 Active Member
    503
    213
    MI
    post the actual codes
