2010 prius taxi blew its transmision
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by socratesthecabdriver, Apr 18, 2013.
  1. socratesthecabdriver
    283
    31
    greece
    i personally have no problems . but a whole lot of the other taxis i know do. other than that i never get better than 6.1 liters the past 60000km and a sound that comes out the right side front end that i cant describe over the keyboard and have to get checked at my next service . but then again i only have 141000km which really means nothing because i know 2 guys that had the hybrid batt dead on them before 120000 and 95000 km a lady that when turns her taxi on she doesn't get info on her dashboard until the car warms up and that is also at 120000km another that lost some sort of a hybrid battery part at the back that burnt out steering columns yata yata yata I JUST NEVER SEEM TO FIND MENTIONING S OF THESE SORTS OF PROBLEMS ON-LINE
  2. Former Member 68813
    3,524
    983
    US
    If I understand correctly, Socrates' cab is doing fine, isn't it?
  3. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    The other thing I regret to have found with this forum is that if you criticize the Prius in any way whatsoever, then you're making it all up and have an agenda. I have been pleased with my fuel economy but it has not been a reliable car and the replacement parts are much much more expensive than the same for a Ford Mondeo or Vauxhall Insignia.[/quote]
    I'm not so much defending Prius as trying to get my head around whether Toyota would deliberately make cheaper versions for Europe. It may be cheaper to make some under spec parts but Economies of scale suggest that this wouldn't happen. Take into consideration the design costs. Tooling costs etc. It may in fact not be cheaper to have two strands of parts manufacture. I'm not saying it can't and won't happen, just that it might not be truly economic.
    I've had a long love affair with the SV21 Camry. My daughters are driving two that I've rescued and made road worthy. The one thing I've always found, for instance, is that whether you have the highest spec Camry or the lowest they always have the same wiring loom. This means that you can buy the lowest spec Camry and then simply plug in all the bits Toyota only puts in the high spec cars. The same with mechanicals.
    I used to own Type III Volksies. I had a 1968 model station wagon. It had drum brakes all round. I bought the disk brakes off a 1971 model and they bolted straight on. I'm just saying that varying design is expensive and most car manufacturers prefer everything made to the same standard where economies of scale can kick in to make parts cheaper.
    As to Prius. Sure there are some annoying features. Particularly 12 volt battery life. and I have no problem accepting that some owners are having less than satisfactory reliability.
    I would be interested to find out which factories make the European Prius also.
    51,896
    new york cabbies are forced to drive hybrids, so if they have major problems, they will have to try a different make i guess.
  5. R1CH13
    R1CH13 Member
    Michigan
    I think you should go get a different vehicle. You and your neighbor or Taxi fleet are not worthy enough to be driving a Prius. If you are driving in extreme condition the trans-axle fluid needs to be flushed every 50,000 miles. The transmission blew because you never flushed the fluid. The fluid is used to lubricate the engine components. It's like motor oil, after so many miles it stops lubricating which means you need to change it or problems will occur.
    edthefox5 likes this.
  6. Feri
    Feri Active Member
    761
    144
    That's a very offensive and unnecessary statement.
    Besides which your trans axle oil changes go against Toyota's recommendations. You cannot claim that trans axle problems are due to not changing oil when YOU recommend. In fact it's been my observation over 47 years of vehicle ownership, that not following manufacturer's recommendations and service advice is the prime cause of vehicles aging prematurely.
    Personally I think you should apologise.
    socratesthecabdriver likes this.
  7. socratesthecabdriver
    283
    31
    greece
    gosh i never knew that thank you so much god bless you
  8. Feri
    Feri Active Member
    761
    144
    Is that a big lolly in your cheek?
  9. socratesthecabdriver
    283
    31
    greece
    maybe we should only have positive postings on this site ,,,something like they do in fascist or dictatorship run counties . every body with prius problems of this site !!!!!!! xaxaxaaaaa
  10. socratesthecabdriver
    283
    31
    greece
    i know . it only really sounded like that . but i really think you made out what i really said ! embed it
  11. bisco
    51,896
    so you're saying, if you ever start a taxi company, and you live in greece, and you want more than 160,000 miles out of the transaxle, don't use prius. thanks for the heads up man!(y)
  12. FranklinS
    FranklinS Ach crivens ye scunners!
    190
    94
    Eugene, OR
  13. socratesthecabdriver
    283
    31
    greece
    you are a kafros !!!!!!!!
  14. KiwiAl
    KiwiAl Junior Member
    146
    New Zealand
    Anyone here know what an Internet Troll is? :ROFLMAO:
  15. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Usually someone who is a new member and resurrects old, negative threads?
  16. KiwiAl
    146
    New Zealand
    Maybe, but if you're referring to me, Nah! Maybe that was a bad way to start my membership, but couldn't help noticing how seriously many people took this thread. I have had some experience with 'net Trolls, and they usually start with vague, ambiguous and provocative statements, but the picture NEVER gets any clearer. This one has all the hallmarks.
    In my experience, once you identify them as a troll, they know the game is up and go away, but that seemed to be a long time coming in this thread.
    See: wikipedia --- Troll_(Internet)
    Anyway, I look forward to learning more about your bad experiences with Prius, and to tell you more about what I know from NZ. You'll be interested to know that we have hundreds of (mostly JDM) Prius taxis over here, but it's a new craze and I'm not sure how they are going / will last. I have more, but need to start a new thread.
    Cheers,
    Al
  17. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    What has been so unreliable in your car? Mine has been spectacular so far. And what parts have been expensive?
    And what's so annoying about the 12 volt battery? My OEM 12 volt lasted 5 1/2 years. I pay attention to the dash. It warned me quite clearly it was getting low. Drove to the store and bought a new one. People on this site complaining about there 12 usually have left a light on or went away for a long time.
    AS far as transmissions the Prius is somewhat special in that it has exposed albeit bulletproof coated motor windings. The winding coatings can be compromised by overheating by pulling a big load and or worn out abrasive fluid. Trans fluid should be replaced at least every 50,000 miles and so should the Inverter coolant. I change both of mine out every 30,000 miles and do a UOA too. That costs me $ 90 every 3 years for both.
  18. Feri
    Feri Active Member
    761
    144
    The first statement you quote is not mine it's a quote form another post that didn't behave. And yes I did mention the annoyingly undersized battery. Yes it does it's prime function of booting up the ECU adequately but there is no margin for human error. A battery should be able to power a cabin light for 12 hours and still start the car. Drivers are human and will make mistakes.
    Toyota has a history of using just adequate 12 volt batteries and in every Toyota I've owned I have installed a larger capacity battery when the OEM died.
    Don't get the impression I am dissatisfied with my Prius, I am not and I have stuck with Toyota for forty years for very good reasons. Most of them are called mechanical reliability. However no manufacturer is perfect.
