2010 prius temp light comes on rarely
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by lsun22, Dec 18, 2022.
  1. lsun22
    lsun22 Junior Member
    16
    sacramento
    Hi all, got a 2010 with 186k miles but replaced motor at 90k miles due to excessive oil burn due to cylinders being expanded causing a gap in the piston seals.
    Recently on the freeway I had the temp light come on (left off the gas immediately), the light lit for a second or two, then it blinked for a second or two and went away. Went to dealer, did coolant flush, and inverter coolant flush, inverter filter change, throttle bottle cleaning, mas filter change, oil change. And now about a week later it happened again.
    During the service I asked them about possible causes, thermostat, water pumps, etc and they said since everything is so digital, it would throw a code if it was going bad and they read no codes.
    Any suggestions about cause?
    Thanks
  2. Tombukt2
    Tombukt2 Senior Member
    13,861
    2,519
    Durham NC
    Your water pump is probably starting to fail If you had nothing to do on a weekend you could drain the coolant unbolt the water pump unbolt the impeller inside the water pump pull it out and match it up to pictures I could send you where the plastic wrap on the impeller is all cracking and fubar it barely can rotate and it's bore so when the pump is coming on it's never able to reach speeds it needs to to move the water to properly cool it or what have you I have pictures they're paying to post here It seems pretty standard for these electric water pumps to look like this internally You can feel the resistance and can imagine what applying power would do chunk chunk chunk barely able to turn and it's bore disastrous You can even plug the water pump back up to the car while you're holding it in your hand have your buddy start the car You can see the voltage and hear the pump feel it in your hand trying to run and it'll chunk chunk chunk. Good luck usually when this starts rather than doing a whole bunch of work You methodically do a few things at a time and inspections are key. Taking it to folks to work on it gets a whole lot of opinions with you eyeballs and a couple hands and you don't get to see any of it because their signs on the garage wall keeping you out I can't be kept in the dark like that so I mess with it at home in my driveway or whatever so I can see and know. Not be told any old thing by some kid in the service department.
  3. ChapmanF
    19,025
    What year engine was put in and from where?
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Did those morons at the shop even LOOK to see if the fans were running ?
    And to see if a "WalMart" plastic bag is stuck in the radiator ??
    They did manage to suck a fair amount out of your wallet based only on a wild guess......on things that usually have nothing to do with over heating.
    I agree that the most likely culprit is the water pump........but that is a wild guess too.
    NOTE: ALL things that go bad and fail do NOT produce a trouble code right up front.
  5. mr_guy_mann
    mr_guy_mann Senior Member
    4,118
    2,014
    NJ-USA
    You can have all kinds of problems with the cooling system that won't necessarily set codes (until things get real bad).
    I would inspect the car:
    Is the radiator or A/C condenser fins clogged with dirt or leaf debris. Are the fins intact or are they corroded. I would run the car while monitoring the engine coolant temperature sensor. Does the ECT go up then "level off" when the thermostat opens - & at the correct temperature. What does it do at highway speeds. Do the radiator fans work. Does the heater put out hot air when it should. Does the car lose any coolant.
    These are all "mechanical" tests that should be done to verify proper cooling function. Since overheat at high load can be an early indicator of head gasket failure, I would get the car hot, then pressure test the cooling system and leave it pressurized overnight. The next day I would pull the spark plugs and inspect the cylinders with a videoscope for any coolant.
  6. ASRDogman
    ASRDogman Senior Member
    8,066
    4,086
    First, go back to the dealership and get your money back.
    They did NOT fix your problem.
    Likely a water pump empeller. If you have techstream, or something similar, you can test
    the water pump and see if it is working properly.
    There is no inverter filter, there is no mas filter. You should ask them to show you those, and where
    the are on the car. Then again, get your money back.
    Grit likes this.
  7. CR94
    CR94 Senior Member
    2,830
    1,243
    Northwestern S.C.
    It's amazing how many dealers can replace or clean non-existent parts.
    Tombukt2 likes this.
  8. lsun22
    16
    sacramento
    yeah i suggested the to dealer if it could be the water pump.... but they're like "nope, it'll throw a code if it was failing...." i'm was skeptical but the guy seemed pretty sure. he was also the service department manager too....
  9. lsun22
    16
    sacramento
    actually, they didn't replace it the entire engine with a different assembled engine, but instead they replaced the short block and other various things so i guess it was more of an engine rebuild than an engine replacement. i would assume they used all new parts in the rebuild. i don't really understand the technical aspect of it...
  10. lsun22
    16
    sacramento
    i mean it was all maintannce things that needed to be done anyways. apparently, i never replaced any of my coolant. but yeah, it didn't seem like they did much to try and figure out what the problem was. i suggested the water pump, but the guy was like, nope, it'll throw a code if it's failing..... i think he was the service manage too...
  11. lsun22
    16
    sacramento
    can you break it down into laymans terms what i should do, what you said is kind of over me. i don't really do much own maintenance, except replace the brake pads.....
  12. sam spade 2
    7,035
    2,804
    2017 Prius c
    Service "managers" and "advisors" usually are NOT mechanics.
    I put them right up there with used car salespersons.
    In this case, what he told you was NOT necessarily right.
    It depends on exactly HOW it fails.
  13. Tombukt2
    13,861
    2,519
    Durham NC
    One day when you're out fooling around with the car from a morning start up it doesn't have to be freezing cold but a first start You can actually put your hand on the water pump believe it or not and feel the motor running If you can afford to borrow tech for a few minutes you can see the water pump RPMs on a screen then you can run the water pump in tech the Toyota software and make it go fast and slow and on a funky water pump with the impeller plastic cracking and all that when you try to speed the water pump up if your hand is on it while you're doing this you can feel the pieces of plastic rubbing on the bore it dpons in feels like an unbalanced thing spinning . Then when you remove the water pump undo the extra 4 bolts on the back side and lift the rotor or impeller out of its bore and you see all this damage then you stick it back in said before and you try to turn it by hand and realize you need a small pair of pliers you realize the trouble the electricity is having making all this work. Then when you get a new pump before you bolt it all up you can plug it in lay it on the frame rail or have your assistant start the car and see the water pump spinning then again you can hook up tech make it spin fast and slow and you will hear feel and see the difference so you'll never have to see it again.
  14. lsun22
    16
    sacramento
    Just posting an update. The technical advice here was a bit beyond me. So I went back to the dealer and they inspected it more and found debris or whatever in the radiator/condenser and had to replace the whole thing. I asked about flushing, they said that wouldnt help. Well they gave me a good rate so I went ahead and did the service. Hopefully all will be well now.
    ASRDogman likes this.
  15. lsun22
    16
    sacramento
    They didnt do an "engine swap" perse. They basically replaced all the major components of the engine ie the short block and whatnot. So I guess that's more of a rebuild?
  16. rjparker
    rjparker Tu Humilde Sirviente
    11,104
    6,967
    Texas Hill Country
    A problem with Priuschat advice is everyone assumes the op has all the tools, scanners and experience needed to diy. In this case "wild guess" was the closest to useful info since no one went with a clogged radiator. Radiators are rarely a problem if the proper coolant had been used and no head gasket sealer had been added in the past. Guessing based on past experience sometimes works - its a probability game.
    A new short block (see diagram below) from a dealer generally includes a rebuilt head, complete gasket set and cleaning of other parts. Its an engine out job and is as close to a new engine you can get. I imagine that cost $5k-$8k and should have eliminated oil burning.
    Essentially you have a 96k mile engine which should be good for another 100k miles if the recent overheating did not get severe. I use a $35 P10 scanner (link here) to watch my coolant temp.
    New Genuine Toyota Short Block 1.8L 2ZRFXE with crank & pistons assembled from factory:
    Short block is at least $2100 for the assembly alone.
    #16 rjparker, Apr 12, 2023
    jzchen likes this.
  17. ASRDogman
    8,066
    4,086
    The short block does not include the head. The long block does...
  18. rjparker
    11,104
    6,967
    Texas Hill Country
    But the dealer will rebuild the head
  19. ASRDogman
    8,066
    4,086
    Okay, But a short block still does not include the head.
    And if the are going to rebuild it, it's probably cheaper to just get the long block.
    So less labor, and time, and possibly screwing up the timing chain....
    And if the head is not warped, no extra money spent.
    CR94 likes this.
  20. MikeDee
    MikeDee Senior Member
    1,581
    597
    San Francisco Bay Area
    How long should an OEM water pump last?
    CR94 likes this.
