2010 Prius touring mpg
Discussion in 'Gen 3 Prius Fuel Economy' started by Raylingbengal, Jul 29, 2018.
  1. yeldogt
    yeldogt Active Member
    810
    313
    NE
    ML _- typing with big thumbs !
    We don't have the technology package. I don't believe the technology package was available on the fours .. the dealer had to search for a base five on both occasions. I did not want the hub caps -- and wanted the LED's .. so, it was worth the extra cost. We still have both
  2. Mendel Leisk
    42,345
    Yeah I recall walking around an (indoor) lot, all these Prius with 15" rims and covers, and it was "No Sir, I don't like it".
    Still, I like the 15" wheel size, better for mpg, cushier ride, replacement tires cheaper. Just wish they'd drop-kick the wheel covers. 2012 Plug-In Prius managed to have some nice bare rims in 15".
  3. Mr. Prius
    Mr. Prius Junior Member
    82
    24
    I have a 2010 base edition that is now getting about 43 MPG. This after getting new Bridgestone Ecopia 422 tires (which is what I had b4), new brakes rotors and pads, a newer 12v battery, and new air filter. I used to get 50 mpg when new. Same hypermiling driving style. I just think the HV battery doesn’t hold a charge as well as it used to after 8+ years and 115,000 miles and it borrows energy from the combustible engine moreso than it used to . I don’t work as well as I used to either!
    #23 Mr. Prius, Sep 3, 2018
  4. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    Your egr circuit probably also needs a good cleanse;).
    Tackle that and recondition the hv battery and you’ll be back around 50 mpg would be my bet(y).
    Mr. Prius likes this.
  5. Mr. Prius
    82
    24
    Thanks Ray! I think Nutz about Bolts has a video on the EGR cleaning. Do you have a link or some info regarding the reconditioning of the battery?
    Raytheeagle likes this.
  6. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    @jeff652 is a member here and runs http://www.hybridautomotive.com
    I have their setup and share it with 2 other members here in our geographical area:).
    Once the harness is installed, the reconditioning process is easy ;).
    Hope that helps (y).
  7. Mendel Leisk
    42,345
    The leaf was just stuck on there, one time when my wife rolled it into the garage, on a rainy/windy day, so I snapped a picture.
    davecook89t, fuzzy1 and Raytheeagle like this.
  8. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Doing the caliper brake pin lub at @Raytheeagle garage, he found a leaf stuck on one of the brake pads on my prius. Was having brake squeaks at the time, but it wasn't the leaf causing the squeak :LOL:
    Raytheeagle and Mendel Leisk like this.
  9. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    At least you got your torque wrench back ;).
    Now to get the Go Jo back:whistle:?
  10. Mr. Prius
    82
    24
    Just an update (which may help others), since replacing the brakes/rotors and replacing the engine air filter and cabin air filter, my MPG has gone from 43 to 54 MPG! Not sure which had the biggest impact as I did them all at about the same. I suspect the breaks may have been a big problem as the caliper pins were all seized on both rears
  11. Mendel Leisk
    42,345
    I'd concur: probably brake drag. A well used engine air filter almost improves mpg: reduces air capacity slightly.
    #31 Mendel Leisk, Oct 16, 2018
  12. OBJ
    OBJ Member
    62
    27
    Stouffville, Ontario, Canada
    I get 43 MPG if I only drive short distances in the city otherwise I get 54 MPG mixed city and hwy.
  13. Gardener2010Prius4
    Gardener2010Prius4 Junior Member
    25
    Boise, ID
    47.6 MPG in my recently purchased 2010 Prius IV with 62,000 miles. Measured using odometer reading and gallons consumed rather depending on the built-in gas consumption display. Still a rookie Prius driver who is learning how to optimize gas consumption using driving techniques featured on Prius Chat.
  14. Mr. Prius
    82
    24
    So I just finished vacationing with a Mustang GT rental and this is how a Prius-type driver did for the week:
    iPhone ?
    RMB, Raytheeagle and Mendel Leisk like this.
