2010 Prius Trim 5 engine revving on it's own
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by PaulMarshall, Dec 7, 2020.
  1. PaulMarshall
    PaulMarshall Junior Member
    35
    Paducah KY
    It has been doing it frequently the last week. I hear it a lot when I come off the freeway, my foot will be on the brake... nowhere near gas pedal. I've even put it in park at traffic light at when it's doing it and taken foot off all pedals... still does it. Other times the ICE will never shut off even though I'm at full bars on traction battery. when it's doing this it will have a rough loping sound like a cylinder is missing. I do door dash for a living till covid is over, if I go sit in a parking lot and turn the car off for 10 to 15 minutes it starts acting normal again for a while. I just happened to get lucky enough to be getting out of the car last night to get an external video where you can hear the engine idling at around 2500rpm. Usually it's harder to hear on previous videos I tried to capture it on, due to the it being muffled because I was in the car (muffled by cabin insulation). any suggestions? My initial thoughts are ECU malfunctioning. No check engine light or anything have ever lit up though.
    I have techstream cable and software just need to round up a laptop that will run windows 7.
    Any suggestions as to where to start looking?
    Video attached of 1 of the two (over rev). I haven't gotten a video yet of when it's sounds like a cylinder isn't firing.
  2. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Start by being sure that your 12 V battery and it's connections are good. I mean really sure.
    Then.....what you are describing often is an early warning sign that there is problem developing with the HV hybrid battery or it's internal connections.
  3. PaulMarshall
    35
    Paducah KY
    I should have mentioned that. The 12V battery was just changed out 3 months ago. The only one in stock locally was the house brand of O'Reilly's battery line. I'll double check the connectors, but I'm pretty sure that shouldn't be the problem.
  4. PaulMarshall
    35
    Paducah KY
    And eeep on the second part. It's a 10 year old car, but low miles (bought it last year with 74k miles). It was a short daily commute driver in downtown Nashville TN.
    My first prius was a second gen 04 prius and it made it to 240k miles and lasted till 2018. I managed to find a guy within 100 miles of me who rebuilds batteries for second gen's with new buss bars, new cells for the failed ones and balanced the cells. The rebuilt traction battery on my 04 was working great, until some jackhat pulled out straight in front of me and totaled that one.
    That'll totally suck if it's the traction battery at only 100k miles.
  5. bisco
    52,814
    consider the egr circuit as well, you should change your model year.
  6. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    Check 12v battery voltage even if it's new
  7. sam spade 2
    7,035
    2,804
    2017 Prius c
    Worth repeating.
    Even NEW batteries can be bad sometimes.
    3 year old batteries can certainly be bad, especially if it wasn't fully charged to start with OR it had been sitting in the warehouse for a few years before you got it.
  8. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    That would mean troubleshooting the easy stuff first, overachievers would never buy into that.
  9. sam spade 2
    7,035
    2,804
    2017 Prius c
    Sure. That's one word for it.
    :ROFLMAO:
  10. AzusaPrius
    AzusaPrius Senior Member
    2,254
    942
    Im willing to bet that once he gets an old laptop and pulls codes that it is the hybrid traction battery.
    Get an obd2 bluetooth reader and the Dr. Prius App.
    Sounds like the engine is trying to keep it charged because it is draining too fast and is weak and will sure throw a code very soon.
    It is not even hot outside to cause that and you have the same issue as with weak batteries.
