2010 Prius trip and display buttons not working.
Discussion in 'Gen 3 Prius Main Forum' started by alextesl, Apr 25, 2023.
  1. alextesl
    alextesl New Member
    Nixa
    I didn't replace anything and these are the only two buttons that don't work aside from the horn. Which is another problem I have. I don't know where to start and what to do.
    52,863
    possibly the clock spring. hold the button down and move the wheel from lock to lock, to see if it works in any position.
    Johnny Cakes likes this.
  3. alextesl
    alextesl New Member
    Nixa
    Sadly that didn't work. Maybe a blown fuse?
  4. Tbkilb01
    Tbkilb01 Active Member
    218
    187
    Louisiana
    Happened in my 2010 a few years ago. I cleaned it with an overly applied amount of cleaner...it stopped working after that... tough repair ... I Did not repair since car was wrecked.
    #4 Tbkilb01, May 10, 2023
  5. ChapmanF
    19,035
    The combination of trip/disp and horn not working does sound a lot like the spiral cable ("clock spring") as bisco suggested.
    The test bisco mentioned is more specific than it is sensitive. If you had found the buttons worked in some wheel positions and not others, it would be a pretty sure thing it's the spiral cable. However, the absence of that result doesn't prove it's not the spiral cable, especially when the clinical picture still sounds pretty much like it is.
    It does matter a bit whether your car has the "Touch Tracer" feature or not. See this post for why.
  6. ASRDogman
    ASRDogman Senior Member
    8,067
    4,089
    Check the connectors, and ground wires...
  7. alexk345
    alexk345 Junior Member
    46
    india
    i have same problem with my 2010 prius. I am searching for a solution in this forum 2 years. Not one person has an answer.
  8. Charlene Varela
    Charlene Varela Junior Member
    Help! I changed the clock Spring on my 2010 Prius and the right buttons on the steering wheel still
    don’t work. Any other suggestions would be appreciated.
  9. Rickt86
    Rickt86 Junior Member
    24
    Usa
    If you buy replacement buttons, get OEM for the audio controls. The after market stuff doesn't work worth squat and mine actually caused smoking in the clock spring which cooked the clock spring.
    The audio controls aren't hard to replace, many you tube videos.
    Pull 12v battery power
    Remove trims on left and right side of wheel where cruise control is and opposite
    Use screw driver to pop air bag off by pressing release in area you just removed trim, reference you tube videos
    Then it's just four screws holding on the audio control panels, buy from eBay a steering wheel or OEM panel from a junk yard, don't buy new unless it's OEM. After market is junk, won't work with trace feature and in my case the right side buttons never worked for top display, only temp would change. Then it smoked and cooked my clock spring.
    I replaced my clock spring, very easy, 19mm bolt, remove air bag and wires prior to bolt. Mark position of bolt and get everything dead center straight prior. Remove wheel, unclip everything with clock spring, repair replace. It's on YouTube. It's not complex.
    Best of luck
  10. Carl Hillier
    Carl Hillier New Member
    I have the same problem. I have replaced the clock spring twice but the problem remains the same (only trip and disp button are not working)
    Any suggestions would be appreciated.
  11. Fantasticpow
    Fantasticpow New Member
    I am here for that same reason. I have a Toyota Prius 2013 bought used, All the buttons on the steering wheel works, except Display/Trip. I did a diagnostic test on these button, all the button where "Mode" is works, as for the right where Temperature up/down works, but only the Disp/Trp button that fail detection from diagnostic.
    I also been searching the web and notice many other owners had this same very issue relating to Disp/Trip. I'm beginning to think its not just some wiring issue, but something left unprogrammed correctly into the system.
