2010 Prius V base - is the square green plug GPS?
Discussion in 'Prius v Accessories and Modifications' started by Krall, Oct 4, 2018.
  1. Krall
    Krall Member
    122
    37
    NY
    Hi everyone,
    I'm swapping out my head unit and see that there's a small, square green plug with 1 pin that looks like it's for a GPS antenna. I bought the car used so I'm not sure if it had GPS from the factory. Can anyone tell me if this is indeed a GPS antenna wire and if there's an adapter for it to plug into a aftermarket radio?
    The plug looks very similar to the one one the back of my Pioneer unit but it physically is off a bit to fit.
    Thanks for the help!
  2. Offline
    Offline Active Member
    637
    230
    Lenexa, Kansas
    This forum is for the Prius v which wasn't introduced until 2012. The Prius v is the largest Prius and is somewhat like a small station wagon. I think you want the regular Prius forum for your model year which is at Gen 3 (2010-2015) Toyota Prius Forums | PriusChat
