2010 Prius V GPS
Discussion in 'Gen 3 Prius Audio and Electronics' started by FlyBoy5, Dec 1, 2015.
  1. FlyBoy5
    FlyBoy5 New Member
    Westerville
    Four Touring
    Toyota performed some updates a year ago and now it displays services at freeway intersections. How do I turn them off when not wanted?
    Thanks
  2. macman408
    macman408 Electron Guidance Counselor
    1,179
    368
    Not sure exactly what you're seeing, but here's one guess:
    Touch "Show on Map" at the bottom, just to the right of the + zoom button, and deselect "POI Icons". Those let you have certain points of interest (like gas stations) show up on the map.
    Another possibility is that you're looking at the "freeway exit information" screen - the left half shows the map, the right half shows the next 3 freeway exits, plus the POIs for the next exit. They don't list any way to turn those POI icons off, but maybe if you go to "Show on Map" then "Change POI" and deselect all the options they will go away?
    If that's not it, then maybe a picture would help.
  3. Tideland Prius
    16,678
    Go back to Single Map Mode?
    Either by voice command "Single Map"
    Or on the map screen,
    press the upload_2015-12-2_15-37-43.png icon and
    press "Single Map"
