2010 Prius w/ NexCell Lithium Throwing Codes
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by addyspriusIV, Feb 23, 2025.
  1. addyspriusIV
    addyspriusIV Junior Member
    Northeast USA
    Hi everyone!
    First, y'all are wildly supportive and thank you for all the information provided so far. I've read through posts that I won't link because frankly, I'm too stressed about this decision to go through a long post. I can edit with details later if folks want more data. I live in the Northeast.
    --Short Version--
    2010 Prius w/ NexCell Battery V2 (16k 1yr 7mo) throwing P0A80 code every ~5 - 10 min now; was a gradual decline and now trying to decide next steps.
    --Long Version--
    I have a 2010 Prius with 96k miles that was dealer serviced until 80k when I bought it. Since the car was driven so few miles per year, the hybrid battery wasn't doing so great but it was definitely working fine and we got 49 - 57 MPG depending on driving conditions. One week we went on vacation and when we got back the battery significantly decreased in local/EV driving ability. I checked Dr.Prius and it's lifespan went from 62% to 43%.
    I had an opportunity to buy a used NexCell battery from a fellow PriusChat member who is a Toyota Master Technician with the hybrid certification. We met up and he swapped the cells - great experience. He told me the NexCell Lithium had 10k miles and 1 yr on it and with my rose colored glasses I thought it was a great buy. When I used it for the 6k miles/7 months I've had it, it's been great.
    Now the car consistently has the red triangle and even when I reset it, it will throw P0A80 even after 5 minutes of driving. The first time it threw the code was in 12F weather so I reset it and figured it was the cold since I'd read about it before. The reset helped for 2 weeks, then 1, then 1 again, then 3 days, and now it's 5 - 10 minute. Dr.Prius does recommend clearing the code then resetting the 12V so I did that yesterday and took it for a 1.5h test drive and no code came up with mixed highway (65mph) and local (30 - 40mph). I read yesterday that driving the Prius with the Check Hybrid Battery warning on is not great - it wasn't in limp mode and my wife and I drove it around with that warning for about 4 hours total over the course of a week. I'm worried this will happen again and while I am handy, I am also an anxious person so picking a solution is worth more to me than mulling it over until it's too late.
    --Question/Ask--
    Now I'm trying to decide the FAQ:
    • How much time do I have before I need to swap so I don't kill the engine?
    • Swap back to original NiMH and just drive it until it throws its own code
      • Prolong/MaxxVolt (I don't want to DIY a charger/discharger) to try to restore it?
    • Cylindrical Cells
    • Remanufactured NiMH
    • Sodium-Ion
    • Toyota Shop Swap
    • Who do I go to for these options?
  2. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    Third planet from the Sun
    Is the battery warranty valid when resold? It was used for a short period of time.
    52,883
    Start by calling your jack at nexcell, i think it’s a common problem and hopefully he’ll take care of you
  4. addyspriusIV
    Northeast USA
    Unfortunately I believe this effort was discontinued when I got the battery.
    I couldn't find a number on their website sodiumhybrid @ contact-dr-prius so I emailed them again. The last time I emailed them was Jan 9th but I never got a reply. The code clearing worked until now, I guess! I think it might be a cell that needs to be balanced but I'm not sure how to do it without a tool. I know there are tons of posts here on how to balance but I have other priorities I want to take care of besides taking on the new hobby of rebalancing batteries.
    If anyone is in the Northeast and winning to do it to my NiMH cells I will happily negotiate a reasonable rate while I can still use the NexCell!
  5. jacktheripper
    jacktheripper Senior Member
    284
    561
    Hi @addyspriusIV ,
    I would recommend to upgrade to the new sodium-ion battery design specifically for extreme temperature, operating temperature in between -40F to 140F, feel free to email [email protected]
    Best Regards,
    Jack
  6. addyspriusIV
    Northeast USA
    Thanks Jack! I sent over a request with some pictures.
  7. Brian1954
    Brian1954 Senior Member
    2,694
    1,077
    South Central PA, USA
    The cheapest solution is,
    Contact the person that you bought the Nexcell battery from and ask him to put the original NiMH battery back in.
    Grit and addyspriusIV like this.
  8. Brian1954
    2,694
    1,077
    The warranty is not transferable to a new owner.
    Grit likes this.
  9. ASRDogman
    ASRDogman Senior Member
    8,069
    4,090
    What is the condition of your 12v battery? How old is it, and what is the voltage reading?
    A weak 12v battery will give the hybrid system issues….
    A 5amp or less AGM charger on it over night should give it a full charge.
    That would be the easiest and least expensive way to start.
    You could also remove the hybrid battery cover and check the condition of the bus bar connections.
    They could be corroded and need cleaning. And it would give you a change to measure each block
    independently. And if it’s out of balance, Jack has a cable to put on the blocks to balance them out.
  10. DirkAshburn
    DirkAshburn Member
    161
    66
    Virginia
    So wait, instead of troubleshooting the issue the answer from jack is replace the whole thing with the newer version??
  11. dnlshrn
    dnlshrn Junior Member
    San Jose, CA
    mudder and Grit like this.
  12. AzusaPrius
    AzusaPrius Senior Member
    2,258
    952
    Please tell us how many companies let you transfer warranty like that without paperwork.
    This was a second hand purchase and Jack is still allowing an upgrade without him being the original purchaser.
    Lithium was a version now there is a Sodium version.
    I would say upgrade to the Sodium version versus taking a complete loss and buying something else, at least you get some type of credit towards the new Sodium battery.
  13. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Planned obsolescence.
    mudder likes this.
  14. addyspriusIV
    Northeast USA
    I ended up chatting with Jack and sending some screenshots. He confirmed my suspicions - one of the blades has a voltage difference of > 0.2 sometimes up to > 0.7 during EV only load. Since I also live in <30 F temp environments and I got the battery when the temps were in the 70s F I didn't get a chance to see the issue. The other blades seem to be balanced and doing fine though. The compromised blade also has a IR that is much higher than the others - 27 vs 16 - 19. Maybe if I can find another blade I can swap it out but it doesn't change the fact that I am driving in less than ideal conditions for the battery to operate in.
    I also found out after reaching out to the seller that I'm actually the THIRD owner of this battery so the 10k miles may actually be higher as that is what the 2nd owner put on it. Justifiably this means that I am not eligible for the out of warranty swap.
    Since my Prius only has 97k miles, I'm going to swap in the original NiMH and drive until that throws a code and just buy a new OEM one and call it a day. Thank you everyone for your support. Is there a way to close this thread?
    bisco, Brian1954 and ASRDogman like this.
  15. bisco
    52,883
    Perhaps the issue is not solvable
    mudder, Grit and Brian1954 like this.
  16. rjparker
    rjparker Tu Humilde Sirviente
    11,128
    6,982
    Texas Hill Country
    You did the right thing by complaining in public.
    Fool me once, shame on you. Fool me twice, shame on me.
    Don't be fooled; go oem and don't worry about the short lived, no bms product. Remember the customers were the problem when all of the lithium faults started happening; until there was another version to sell.
    #16 rjparker, Feb 25, 2025
  17. ASRDogman
    8,069
    4,090
    Lithium does not do well in cold weather.
    Perhaps invest in the Prolong system and run the complete cycles of 3 discharges and 4 charges.
    For the oem pack.
    Maybe if you do some searching you can find a good used block.
  18. AzusaPrius
    2,258
    952
    Lol rjbarker yea thank god he talked about his used lithium battery he bought second hand, that has no warranty because of that.
    Also thank god we have you to cheerlead anything you can come up with about said products, even though you personally have never dealt with or purchased any of said products.
    You must feel very accomplished for all the great things you have done for the community here.
    I can only imagine how good of a person you are in real life.
    You truely deserve the karma to match what you put out into the world.
    Just wish you had more hands on with the issues here versus just jumping into the issue without any experience with products.
  19. bisco
    52,883
    And yet, my pip lithium battery was fine in cold weather for 12 years
  20. Brian1954
    2,694
    1,077
    I believe that grid charging a Nexcell Lithium battery is not recommended by Jack.
