2010 Prius; Whole-vehicle shudder, P0304, seems unrelated
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by TheLandYacht, Mar 9, 2021.
  1. wheezyglider
    wheezyglider Active Member
    247
    178
    SF Bay Area
    Definitely confirms that uneven blockage of those EGR ports on the intake manifold can lead to misfire codes (if there was any doubt).
    And good thing your test drive was hard enough to activate use of EGR, if you just drove it around the block that wouldn't have warmed it enough to meet the EGR pre-requisites.
    Also, you're not at all the first guy on here to have "cleaned everything" but missed those little EGR ports. It's good catch @Mendel Leisk !
  2. TheLandYacht
    TheLandYacht Member
    132
    69
    Kingsland, Texas
    Not only did I missed those little EGR ports, I missed them even AFTER @Mendel Leisk pointed it out...I had to be shown (in a video) that the damn things were clogged up.
    On another note, it confused everyone...even the mechanic that's been wrenching longer than I've been alive...that it was misfiring ONLY when it was up-to-temp, which apparently is contrary to just about everything mechanics know about how misfires happen.
    Turned out that a local mobile mechanic found the answer (after a shop mechanic already fixed it) of how to rule out the EGR entirely...just unplug the EGR Valve...if that solves the problem, then something in the EGR circuit is causing it.
    The confusing part for ME was...3 of the 4 EGR ports were clogged, which caused the FOURTH cylinder (unclogged) to misfire. Until it was explained to me, too much EGR gas in that cylinder, not enough oxygen = instant misfire by the dozens.
    Glad we got it figured out tho.
  3. wheezyglider
    247
    178
    SF Bay Area
    I first noticed that idea in a video by @Ragingfit. He was dealing with EGR on these forums like 5 years ago, and we're still learning...
  4. TheLandYacht
    TheLandYacht Member
    132
    69
    Kingsland, Texas
    First (40 mile) commute to work behind me, no hiccups and not a single misfire that I noticed. I was glancing down at this every minute or two the whole trip & it didn't budge.
    ASRDogman likes this.
  5. ASRDogman
    ASRDogman Senior Member
    7,596
    3,916
    Every piece of the system is important. :)
    TheLandYacht likes this.
  6. TheLandYacht
    TheLandYacht Member
    132
    69
    Kingsland, Texas
    3 daily commutes (almost) complete, that's 3 80-mile round-trips...240 miles & not a single misfire. I'm tentatively calling this issue fixed.
    Bonus, my gas mileage has gone up by what looks like 4mph (or about 10%) according to dash & TorquePro. I'll do another 5-tank-average over the next few weeks to see if real-world ##'s are the same.
  7. Mendel Leisk
    41,463
    Everybody likes a quick fix. Rough running can be “cured” by a simple disconnect, why not...
    the Exhaust Gas Recirculation disconnect is tantamount to “completely plugged”, and everything that comes with that.
  8. ChapmanF
    18,213
    That's a slightly-too-hasty conclusion, because of the fact that the engine control module can tell that you have unplugged the valve, and that causes it to also change other engine parameters like ignition timing. A good illustration of the way "I did X and that tells me Y" reasoning can fail for someone who hasn't first made sure to learn everything X does.
    ... with, again, the difference that the disconnect is detectable by the ECM, which can do things to compensate.
  9. TheLandYacht
    TheLandYacht Member
    132
    69
    Kingsland, Texas
    But it does at least allow you to test-for-fault in the short-term.
    I don't think the above was suggesting unplugging the EGR valve as a long-term fix.
  10. ChapmanF
    18,213
    I think Mendel's response was more to the idea of a long-term fix.
    My response was simply to the short-term diagnostic interpretation. You have to remember not to think "now I know the engine runs better without EGR", because it's really "now I know the engine runs better without EGR, with the ignition timing retarded, and the other changes the ECM makes to compensate for my unplugging the EGR, which it knows I did".
  11. Mendel Leisk
    41,463
    @Ragingfit left his Exhaust Gas Recirculation system (on the Prius v in video series) disconnected for around 50k miles IIRC. I really appreciate his videos and transplant info, but think that disconnect is what fragged the engine.
  12. TheLandYacht
    TheLandYacht Member
    132
    69
    Kingsland, Texas
    So...would finding a dead EGR valve (failed "closed"), or killing yours in such a way that it fails "closed" change that result?
  13. ChapmanF
    18,213
    Which one of us are you asking, and what result are you asking about?
    If you have a valve that appears electrically 'present', but doesn't open, that'll have the same effect as a completely clogged system and without the other engine-protecting precautions that the ECM takes if it knows that the valve is unplugged.
  14. TheLandYacht
    TheLandYacht Member
    132
    69
    Kingsland, Texas
    The changes to timing/etc that result from unplugging it. And the fragging that motor he mentions.
    Not that I would do so. If I were going to take it apart far enough to get to the EGR (and found it non-functional), I'd just replace the damn thing...they aren't that expensive.
    My only real problem with this Toyota so far is the inavailability of parts...and the scarcity of Prius-knowledgeable mechanics...in my area. Both are a minimum of 75 miles away for anything complex.
  15. wheezyglider
    247
    178
    SF Bay Area
    Have we lost sight of earth? The quick EGR unplug test isn't going to hurt your engine in the real world, and in the vast majority of cases if it "solves" your problem, then there really is an EGR related issue. Likewise, the solution is (90+%) of the time a full EGR clean. In practice it seems a small percentage of time the valve does need replacing. This cigar really is a cigar, folks!
    Ragingfit likes this.
  16. TheLandYacht
    TheLandYacht Member
    132
    69
    Kingsland, Texas
    Yes and no.
    In my case, I knew it wasn't a full-egr problem for a couple of reasons...one of which only made sense once it was explained to me.
    1. We had just cleaned the entire EGR circuit (just somehow completely missed those little 1/4" ports in the intake) less than 5k miles before.
    2. It was only effecting one cylinder, the rest were 0-misfires.
    BTW, that cooler was 100% clogged when I took it off to clean it, not a speck of airflow (or in this case, water-flow while I was cleaning it). By the time I was done, it was spick&span!
  17. ChapmanF
    18,213
    Well, part of that is why I'm not completely persuaded by Mendel that the disconnected valve "fragged" that engine. The ECM can tell right away that the valve is electrically unplugged, and the fail-safe adjustments it resorts to then are precisely to protect the engine from adverse effects of not having EGR.
    If you do something sneakier, and sabotage the EGR flow without making the valve look unplugged, then you'll just have no EGR flow and no protective measures.
    If you block the flow completely enough, the ECM will eventually catch on anyway, when it sees the manifold pressure not rising when it does its routine add-EGR-while-decelerating test. Once it catches on and reports P0401, it will be applying the same protective measures from then on. But it only does that test on some kind of schedule and only when you're decelerating under certain conditions, and it has to see the failure in two separate trips, so that might not happen for a while. (Then if somebody clears the code, it could be a while again before it gets re-detected.)
