2010 Prius will not start after sitting for 6 days in snow
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by TrvlArrngr, Jan 8, 2018.
  1. TrvlArrngr
    TrvlArrngr Member
    33
    26
    My 2010 Prius sat in my driveway for 6 days because of a freak snow storm at the beach. It was working just fine. I have about 175k miles on it. Mostly highway. Engine would not start so a neighbor suggested replacing the 12V battery. He took me to Autozone and we got one and put it in. Still had every warning light lit after replacing it. The engine will still not go on and it takes a while to even turn off the power for accessories. Start button is green but nothing happens. Try to turn it off and have to wait about 5 mins before the button works again to shut it down. Should I have it towed to a Toyota dealer? or is there something I can try from home? Thanks so much!
  2. davecook89t
    davecook89t Senior Member
    1,076
    810
    Washington State, Florida
    Four Touring
    As has been mentioned before, a new off the shelf 12V battery is not necessarily a fully charged 12V battery. The symptoms you describe still point to a weak 12V battery. Autozone should have a Multi Meter capable of measuring voltage at the under the hood jump points for $20 or so. Your first step in solving this should be to confirm that you are getting 12.5V or more at the jump points. If that checks out, you will need to have the codes read, probably at your Toyota dealer.
    51,082
    is the dash lighting up? any warning lights?
  4. padroo
    padroo Senior Member
    2,763
    2,251
    I would take the new battery back and have them test it. A battery can have a good voltage reading and still not put out the CCA (Cold Cranking Amps) needed to start a car in cold weather. Check your connections both at the battery and follow both leads as far as you can and check you have good connections.
    One of these can help you determine battery voltage.
    http://www.amazon.com/Car-Charger-Smartphone-Temperature-Fahrenheit/dp/B00SWGWILI/ref=sr_1_3?ie=UTF8&qid=1515460912&sr=8-3&keywords=car+voltage+meter
    Just plug it into your cigarette lighter or power port.
    jack black likes this.
  5. ChapmanF
    17,256
    The "cranking amps" needed to start a Prius are around 30, if I recall correctly from some datalogging done by PC member hobbit. In cold weather, though ... 30.
    -Chap
  6. rjparker
    rjparker Tu Humilde Sirviente
    9,564
    5,872
    Texas Hill Country
    The 12v battery does not actually start the car, your high voltage (HV) battery does that. The 12v runs the computers and network, including a computer and contactor in the HV battery which must function to achieve "Ready" state. It's possible the HV battery is reading too low but perhaps that will change when it warms some. I have heard of people who simply try to "Ready" the car several times and then it "starts" by going to "Ready". However, taking it to a dealer is probably the only way to determine the issue. Even with a special purpose code reader, you are likely to find many codes, most of which are meaningless until the primary cause is found.
    PS: This thread is actually in the wrong section of Priuschat.
    Here's a good enough meter for $3.97 from Harbor Freight and even has a backlight
    Item #92020
    Digital Multimeter - 7 Function, w/ Backlight
    #6 rjparker, Jan 8, 2018
    TrvlArrngr and Raytheeagle like this.
  7. davecook89t
    1,076
    810
    Four Touring
    I agree that you need to check your connections, particularly from the battery's negative terminal to ground.
    It is my understanding that CCA are not that important for Prius batteries, since the 12V does nothing more that fire up the computers. The HV battery starts the engine. It is true that all batteries lose power in the cold, but a Prius 12V battery should be less susceptible to cold problems than would batteries in cars that have a regular starter. The posts you will find relating to 12V issues in this forum all reference voltage measurements rather than CCA. I believe voltage at the jump points is all you need to measure.
    padroo likes this.
  8. rjparker
    9,564
    5,872
    Texas Hill Country
    While not a solution, this video is well worth your time to actually understand the significant electrical components and their relationships in a gen2 2004-2009 Prius. The college prof explaining this uses real parts and has other videos with even more detail.
    TrvlArrngr likes this.
  9. TrvlArrngr
    TrvlArrngr Member
    33
    26
    The car does not run at all so cannot bring it to be sure the voltage is high enough. all the lights and radio work great. Should I have a neighbor jump the new battery? I am 50 minutes from a Toyota dealer. It will be a long tow. I am a single woman and my kids that live nearby went on a trip and will not return until next week. Open to suggestions. Tried doing the 3x start button thing - that did not work. Thanks everyone.
  10. jack black
    jack black Active Member
    225
    142
    I
    Be warned if you jump incorrectly, it's $$$$. Find someone who knows about cars and knows how to use a multimeter (shouldn't they teach that at junior high?).
  11. TrvlArrngr
    TrvlArrngr Member
    33
    26
    They might teach it but I have 2 neighbors in the winter one set in the 80's and one set in thei 70's. I may need to have it towed to be sure it's right.
  12. jack black
    225
    142
    I
    you didn't say if it was the original battery. if it was, it was probably bad. now, replacement should have fixed it, except you have to cycle on/off start button twice before it works. now, if the replacement battery is bad and/or it was installed incorrectly, it won't work, hence the advice to use multimeter.
    PS: now I see radio works, check if headlights work too. maybe you need cycling on/off a few times?
  13. davecook89t
    1,076
    810
    Four Touring
    A neighbor who is available and willing to help is nice to have. You need to be very careful when trying to jump start a Prius from another car. One false move can result in very costly damage to the Prius' electronics. Most people would recommend turning the other car off before attempting to jump the Prius, because very little current is needed to fire up the Prius' computers and an excess from the other car's alternator will at the very least blow the fusible link (about $100 from the dealer), and at worst fry the inverter (about $4,000 from the dealer). If you or your neighbor know the proper procedure for hooking up the 2 batteries in parallel, and are careful not to short the cables against themselves or any other part of the car, you can attempt to jump start your car, but that may not solve the real problem anyway.
    I'm guessing it is still cold where you are located. If all the lights and accessories on your car seem to work normally, the problem may be that your High Voltage battery does not have enough power to crank the engine. The cold will reduce the power available to that battery as well. When you last were able to observe the HV battery's State of Charge on the Multi-Function Display, how many bars were showing? Given that your car is now about 8 years old with the mileage it has, a HV battery failure may be a possibility. If that battery has become discharged, it is really only your Toyota dealer's special charging equipment that can bring it back to life, and that is dependent upon the individual cells remaining in a balanced condition. I hope for your sake it is not the HV battery that is at fault, but I believe that is a possibility that needs to be considered, especially if the engine still will not start even with a jump.
    If you tell us where you are located, possibly one of the more knowledgeable members on this forum may be able to come by and help you read the codes the car is throwing to get a better idea of what is wrong.
  14. TrvlArrngr
    TrvlArrngr Member
    33
    26
    I have been turning it off and on while holding the brake down - is that what you mean? Nothing happens. All the lights are still lit and still says check hybrid system. I probably did need a new 12V since it was the original as you said above. My other problem is i have to drive 40 mins to a harbor freight or another parts store. Once I have the codes will I be able to understand them?
  15. Prodigyplace
    12,398
    11,676
    Central Virginia
    If they have a code reader, it may not be able to read the Prius-specific codes for the Hybrid system. Many third party readers cannot. The dealer's Toyota Techstream software can read them along with any detail codes.
  16. rjparker
    9,564
    5,872
    Texas Hill Country
    So you have a new 12v battery, have no one around who has a voltmeter (lots of old people have them and know how to use them), and the Toyota dealer is a long ways away. A voltmeter from Harbor Freight or any Walmart or Auto Supply store will only tell you the voltage of the 12v battery. It should be at least 13.5vdc, if not a jump might help. Jump directly to the battery since you know where it is but be careful as a wrong connection can ruin the car.
    You need a very special code reader to read the Prius codes. Even then it won't fix it.
    Check your car insurance for towing options, many have towing as part of the deal. Call them. If not, call around to tow truck drivers. Negotiate with them if possible to take the car to the dealer. Any tow truck driver will be able to jump it and will try that first.
    scona likes this.
  17. jack black
    225
    142
    I
    is there a chance your neighbor initially hooked it up incorrectly, realized the mistake and switched back?
    if so, it'll be expensive to fix and Toyota place or a hybrid shop is your best bet.
    ps: does anyone remember symptoms of reversed polarity in a prius?
    #17 jack black, Jan 9, 2018
    Prodigyplace likes this.
  18. jack black
    225
    142
    I
    good advice, except for the 13.5V part.
  19. rjparker
    9,564
    5,872
    Texas Hill Country
    When it's on it should be at least 13.5 v. That says the inverter is charging it.
  20. jack black
    225
    142
    I
    assuming prius is in Ready state. it's not the case here.
