2010 Prius with bad headlight harness
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by rsttoole, Feb 9, 2015.
  1. rsttoole
    rsttoole Junior Member
    Boise, ID
    I purchased a 2010 Prius in October 2014 as a Toyota Certified used car. About a month later I lost my first low beam headlight on the passenger side. I replaced this one myself. A short time later I found out about T-SB-0204-12 which addresses this issue.
    I had my Prius into the dealer this morning and they confirmed that this TSB does in fact pertain to my car. The original warranty is for 3 years or 36,000 miles so they tell me that the car is out of warranty (31,000 miles but now 5 years old) . They also tell me that the certified used car warranty wont cover the replacement since the harness is still "working". History shows this to be a design problem with persistent failures.
    Any advice on how I can get Toyota to pony up and take responsibility for changing this harness out? What happens the next time one or both headlights fail on a dark stormy night.
    Any advice is much appreciated. The dealer wants $600+ to replace the harness.
    52,848
    have you read through the certified warranty?
  3. rsttoole
    Boise, ID
    The dealer called the warranty people (not sure who that was) and was told that it was not covered. I guess I need to read the fine print. Regardless however it seems like a design issue that Toyota should repair.
    52,848
    you can try asking the service manager to call toyota, sometimes they cover all or part of out of warranty repair, especially since there's a tsb.
