2010 Prius with possible clogged EGR
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Newpriusowner91, Jun 26, 2026.
  1. Newpriusowner91
    Newpriusowner91 New Member
    Arizona
    Hi all, I’m a new Prius owner as of last week. I bought it used from a small independent owned dealership. 2010 Prius with 186k miles on it. Second day of owning it the check engine light popped on. Went to auto zone and the code P0401 popped up. I contacted a few mechanics near me and both had no desire to clean the EGR or even look at it! I found a mechanic literally 2 minutes from my house who said he does do EGR cleanings and repairs and to drop the car off on Monday.
    I’m obviously worried what this will cost me. Google and a few Reddit peeps told me to clean it the range is $600-900 and a full repair is $1500 average. I’m not too happy but I love this car! I’ve only had it a week and I love it, I’m getting 44 miles to the gallon ( I drive around town that’s about it) I haven’t taken it in the highway yet because I’m worried about this EGR or whatever it could be causing the engine light to pop on.
    If the EGR is the reason for the light should I get it cleaned every 50k miles? I hope to keep this car for years. I have it paid off so at least whatever goes wrong I can fix and not worry about making monthly payments for a car that is old with a lot of miles on it.
    Naveed Shaek and bisco like this.
    52,857
    congrats and welcome! no warranty from the seller? you'll need a code reader for the engine light, could be as simple as a loose gas cap
  3. ChapmanF
    19,025
    Two conditions can contribute to low EGR flow and a P0401 code: clogging, and a rutted ski jump in the valve actuator. You might have either one or both. Whoever looks should check for both.
    Of course, the extra-simple causes are also worth checking, like something just plain stuck, or an issue in the electrical circuit (which would give P0403 if obvious enough for the car to detect it).
  4. 20113rdgen
    20113rdgen New Member
    New Zealand
    Second day? The guy trading it in likely scammed the dealer, who went on to scam you (deliberately or not)
    90% of the time you are better off cleaning it yourself to save the money. Only tricky(nightmare) part is the egr cooler bolts
    CR94 likes this.
  5. Mendel Leisk
    42,348
    One bolt in particular. More accurately, one nut-on-stud, highlighted in yellow:
    Make it easier on yourself, remove that nut, and the associated stud, in advance of the main job. It can be done without any other disassembly, and both the nut and stud can be left off permanently. This has the side benefit, of allowing the two studs at the rear of the cooler to remain installed, which in turn helps retain the rear gasket as you pull the cooler out, and retains/aligns the gasket during subsequent reinstall.
    At that same prelim nut/stud removal, it's good to "dress rehearsal" the similar nut/stud combo going through the EGR valve, and the bolt at the top EGR cooler bracket: remove them, add a thin/uniform skin of anti-seize (work into the threads with an old toothbrush or similar), and reinstall, slightly shy of torque value.
    Also, on the day of the main job, before doing anything else, drain two quarts (or litres) from the radiator bottom spigot, into a clean container (pour it back into reservoir when done). This'll drop the coolant level below the EGR components, avoid virtually all spill when cooler coolant lines are pulled off.
    Also, there's no need to disconnect throttle body coolant lines; the throttle body can be lifted off with them attached, tied to the inverter wiring harness.
    Then, no nightmares.
    ETC(SS) and Buzzhead like this.
  6. rjparker
    rjparker Tu Humilde Sirviente
    11,108
    6,969
    Texas Hill Country
    It's a $1000 to $1500 job for a reason; major disassembly of the whole wiper assembly followed by the "nightmare" of getting the egr cooler off for the first time in addition to the "relatively" easy egr valve.
    Even though there might be two or three contributing factors, any mechanic who just cleans the egr valve will fail to permanently clear the code. That is a "normal" egr cleaning on most cars; not yours.
    A dealer or a pro may refuse to "clean" it (you have already seen that) or will think its just a normal egr valve cleaning (could be your guy) or will want to buy new parts (maybe $500-$700) and charge 3 of 4 hours labor to tear it down and install the parts.
    Which is why Mendel and most people here say spend a few days fighting it yourself. Unless you are an experienced diy mechanic, you will also need to buy some tools as well. Never sounded good to me.
    Start by verifying your guy knows the egr cooler is very likely to be clogged and he knows it can take extra hours just to unclog it. Or do what the dealers, pros and I did, let the shop tear it down and buy new parts as necessary.
    Or if you have the option, return the car.
  7. Mendel Leisk
    42,348
    One thing, a 2010, with 186k miles, with presumably never addressed EGR clogging, and for sale, ticks all the boxes for head gasket failure. Don’t kid yourself, that an EGR cleaning means you’re out of the woods.
    douglasjre and 20113rdgen like this.
  8. rjparker
    11,108
    6,969
    Texas Hill Country
    I don't think he reported any symptoms of anything except a clogged or failed egr system.
    I would agree the potential for future repairs are always there with an early gen3 Prius.
  9. Mendel Leisk
    42,348
    Later model year gen 3 are near-equally vulnerable to head gasket failure. For latter part of 2014 (model year) and 2015, they did finally revise the piston rings, which alleviates excessive oil consumption, but the EGR system is largely unchanged, apart from some (likely ineffectual) intake manifold and EGR valve "tweaks".
  10. Paladain55
    Paladain55 Active Member
    414
    172
    The South
    probably sold as is so you have been scammed. But it takes like a couple seconds to unplug the egr valve electrical connector to drive it around for a period of time to make sure it doesn't have a blown head gasket. If you have no emissions thats the last you have to worry about it. Its a permanent mod lol
  11. Gloria&Suzanne
    Gloria&Suzanne Junior Member
    81
    Sacramento, CA
    I found out my 2013 Toyota Prius was having this problem when I simply unbolted the EGR pipe. To add insult to injury, my pcv valve went bad resulting in oil pooling in my air intake manifold, and that oil mixed with carbon deposits,lining the cylinder ports with sludge, and I had to replace the pcv valve. IMG_20260425_185436640.jpg IMG_20260428_001639446.jpg IMG_20260428_001628014.jpg IMG_20260428_001653402.jpg IMG_20260428_001700315.jpg IMG_20260419_162343569_HDR.jpg IMG_20260419_162338124.jpg IMG_20260425_185436640.jpg IMG_20260428_001639446.jpg IMG_20260428_001628014.jpg IMG_20260428_001653402.jpg IMG_20260428_001700315.jpg IMG_20260419_162343569_HDR.jpg IMG_20260419_162338124.jpg
  12. Mendel Leisk
    42,348
    The pcv valve may be fine. The intake manifold is always awash in oil and good amount probably flys right through, to the intake ports and combustion chambers. A quality oil catch can (or two...) can help. See top link in my signature. (on a phone turn it landscape to see signatures)
  13. rjparker
    11,108
    6,969
    Texas Hill Country
    Just don't let a pcv line catch can fillup or it can cause blown engine seals, especially sealant seams around the timing chain cover.
    Later Toyota engines raised the level of the pcv valve and incorporated a self draining catch can into the engine. The improved systems drain back to the oil pan.
    Good sintered metal filter catch cans will minimize intake manifold fluids but require attention the typical driver won't do. Many never check their oil much less inspect and empty an aftermarket catch can.
    Like many gen3 problems, avoiding oil burning reduces blow by and subsequent excessive carbon and intake fluid accumulations.
