2010 Prius won’t start. UO100 code
Discussion in 'Gen 3 Prius Technical Discussion' started by Datuna14, Apr 17, 2025.
  1. Datuna14
    Datuna14 Junior Member
    30
    San diego
    Hello everyone. my Prius was blowning fuse2 every day, replaced three times 10 amp fuse, all of them blowning. Then I installed 15 amp and second morning my car stopped with check hybrid system and all dash lights.
    checked everything, from battery 12 voltage to relay and fuses. Also fuel pump. I crank engine by hand so engine isn’t seized. Installed other ECM but doesn’t start still. Was check all harness from oxygen to ECM, visual inspection passed…
    I think inverter is damage?
    I hope someone could help
  2. ChapmanF
    19,038
    My father bought a used car once whose previous owner had done that. It became my job to remove the seats and carpet and replace all the melted wiring.
    If the specified rating of fuse keeps blowing, that is a sure indication of a problem that needs to be solved before putting another fuse in.
    Putting in a higher-rated fuse is simply going to add a bigger problem to the existing problem.
    It will be necessary now to find both the original problem that was blowing the 10-amp fuse, and carefully inspect for any further damage done by putting in the 15 amp.
    Datuna14 likes this.
  3. Datuna14
    30
    San diego
    I know it's late, but I still realize I'm in a bad situation. What's the alternative?
  4. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    Third planet from the Sun
    How did you get this code and when? Before the experiment with replacing the fuse or after installing 15A instead of 10A?
    And yes, the correct code is not UO100 but U0100.
  5. Datuna14
    30
    San diego
    Thanks for reply, this code U0100 is After, in “Hybrid System” and in current status. I am unable to enter Engine control unit…
    Before I had: P0102, P2239, p2237 and EGR trouble code, after replacing Fuse#2 those codes were in permanent only.
  6. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    P0102
    Mass air flow meter voltage less than 0.2 V for 3 seconds
    (1 trip detection logic)
    • Open or short in mass air flow meter sub-assembly circuit
    • Mass air flow meter sub-assembly
    • ECM
    • P2237
      Open in the circuit between terminals A1A+ and A1A- of the air fuel ratio sensor while engine is running
      (2 trip detection logic)
      • Open in air fuel ratio sensor (sensor 1) circuit
      • Air fuel ratio sensor (sensor 1)
      • ECM
    Given the nature of these DTC codes, it can be assumed that you have changed the fuse EFI NO.2.
    Therefore, it is important to understand what caused the fuse to burn out, and which consumer.
  7. Datuna14
    30
    San diego
    Today it says U0100, I should probably look for it in the cords and plugs, right?
  8. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    U0100 211 Problem with CAN communication between the ECM and power management control ECU (communication error between ECUs) CAN communication system
    U0100 212 Problem with CAN communication between the ECM and power management control ECU (signal transmission error)
    U0100 530 Problem with CAN communication between the ECM and power management control ECU (CAN communication system malfunction)
    Trouble Area - CAN communication system.
    If these errors occur, you must first make sure that there are no other errors, and then check for the presence or absence of error P2532-772.
    If DTC P2532-772 is stored, the vehicle will turn off.
  9. Datuna14
    30
    San diego
    When it comes to the case, I can't check anything on a professional level. I'll ask you a question like that and you won't bother me anymore. I'll take the whole CAN cords out of the donor car. Wouldn't that be a bad idea?
    I appreciate you taking the time to read my post.
  10. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    There is no separate CAN cable, it is an interconnected bus through which data is exchanged between different systems. Trying to rip one pair of wires out of a thick bundle of three dozen wires is pointless.
    Error P2532-772 "Ignition Switch Run Position Circuit High" is interesting because power should not be supplied without a command. When power is supplied, this indicates a faulty contact, and what can damage them? A short circuit and an attempt to install a higher fuse rating could fry the contacts and weld them.
    You need to find out everything that caused the fuse to burn out and try to eliminate the culprit, a cable, a relay, or some control unit.
  11. Datuna14
    30
    San diego
    Hey, I found it was EFi fuse wire, inside fuse box. So code U0100 lost communication was Fuel pump line. Now I am testing again EFI#2 with 10 amp fuse, if this fuse blowning again, what can I do best myself?
  12. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    If the fuse blows, you need to check the circuit from the fuse to those units that receive 12V power through this fuse.
  13. Datuna14
    30
    San diego
    Thank you very much for helping me. I am very hopeful. burned still EFI.2. It was 10 amp fuse. And “4” DTC messages: p0403, p0102, p0037 and p0031
    What do I do next?
    install new fuse with same amp and then start unplugging o2 upstream or downstream? And what exactly should I look for, can you explain?
  14. Eddie25
    Eddie25 Active Member
    503
    213
    MI
    double post
    #14 Eddie25, Apr 21, 2025
  15. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    This is a common job for an auto electrician. Checking the power supply circuits for short circuits.
    Mass Air Flow Meter (3), Oxygen Sensor (Bank 1 Sensor 2) (2), Air Fuel Ratio Sensor (Bank 1 Sensor 1) (2), EGR Valve Assembly (2, 5),
    Purge VSV (2), Canister Pump Module (5).
    This fuse supplies power to several units.
    The check procedure is to check for short circuits in the contacts of the units that should be supplied with 12V.
    This way you install a probable faulty unit with a short circuit that blows the fuse.
    You can disconnect all the connectors of these units, insert a fuse and, connecting the units in series, install the one that causes the problem of a blown fuse when turned on.
  16. Eddie25
    503
    213
    MI
    Those are all the things the EFI2 fuse goes to (EGR, A/F and O2 and MAF) so those codes are probably the result of the fuse blowing.
    The more data the better. Does the fuse blow while driving? Does it blow under load or could it happen with the car just sitting there in park? How much drive time and miles are you getting before it blows? Does it seem random? Was anything done to the car recently?
    What I would do is get one of those fused wire loops that installs in the fuse slot and allows you to measure current with a current clamp. I would start by getting a reading of that while car is on in park. If it's a high reading I would suspect something is pulling too much current and start unplugging those components. If it's low I would expect more like an intermittent short in which case I'd use a light bulb limiter or circuit breaker to allow me to start wiggling stuff and see if I can recreate it consistently.
    It would be difficult to walk you through exactly what to do and possibly dangerous if you don't have a pretty good idea of what you're doing already, so it might be best to take it to someone.
  17. Datuna14
    30
    San diego
    it happened during driving, about every 30-50 miles. I haven't done anything except change the oil, It started suddenly, one morning I was dropping my son off at school.
    I have some cheap multimeter and bulb tester, also bought autel sp100 today. I can only perform simple test like find continuity cable/line :)
    As I understand I have case for those 4 device EGR af o2 and MAF
  18. Datuna14
    30
    San diego
    I will tomorrow this test, thanks again!
  19. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    Please note that in addition to some unit, there may be a short circuit in the harness wire, which shorts to the body due to poor insulation or rubbing against an element of the body structure. It is better to disconnect all consumers of this line first and check if the wires are shorted to the body, and then connect the units sequentially to find the source of the problem.
    You have not five, but six consumers!
    #19 MAX2, Apr 21, 2025
  20. Datuna14
    30
    San diego
    Thanks for reminding me, I'll do my best and keep you updated.
