2010 Prius won’t start. UO100 code
Discussion in 'Gen 3 Prius Technical Discussion' started by Datuna14, Apr 17, 2025.
  1. Datuna14
    Datuna14 Junior Member
    30
    San diego
    Hello. Today I checked with amperage mode by tester. Removed EFi.2. Fuse and pushed probes inside. Amp was readings when “O2 B1S1” “MAF” and “EGR” were plugged. purge canister valve and B1S2 sensor had readings 0.0 amp.
    Total everything was 1.6-3.0 amp and It was changing quickly.
    As I understand it, this information doesn't help me at all, I think I should check the voltages in harness which is loaded on FUSE.2. Right?
  2. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    Third planet from the Sun
    Checking for a short circuit in a wire is performed with consumers disconnected.
    You use a multimeter in the current measurement mode, but it is necessary to use it in the resistance measurement mode. Measurement between the wire and the car body. Low resistance measured as zero ohms or 10 ohms is bad, high resistance of several megaohms is excellent.
  3. Eddie25
    Eddie25 Active Member
    503
    212
    MI
    If there is a short to ground it will be intermittent so in order to find it with continuity testing on a meter you would have to keep an eye on it while wiggling stuff around. I think a test light from battery + to the component side of the fuse (with the fuse out) might be an easier way to run the short to ground wiggle test. I don't think you have to unplug anything.
    The current reading shown is useful and tells me that nothing appears to be drawing excessive current in that condition. So I would be leaning towards a intermittent short of some. I would first want to do a visual check of anything associated with that B+ wire. Any signs of rodents? Does it feel like the fuse is more likely to blow over bumps/turns or does it ever happen while cruising? Then probably move to the wiggle test.
  4. Datuna14
    30
    San diego
    Did u meaning zero resistance is for good and high resistance bad? my tester works like this
  5. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    The fuse burns out, this indicates a short circuit. Either the wire shorts to the case (negative terminal 12V), or one of the consumers has internal damage and it causes a short circuit. When checking the resistance between the wire and the car body, high resistance means that the insulation is good, low resistance means that the insulation is bad and there is a short circuit to the case.
  6. Datuna14
    30
    San diego
    passed visual check. Ever
    Ok understand.
    For example, I removed the oxygen B1S1 plug. Find negative pin in harness, attach one probe in negative pins and other probe to chassis body, check resistance.. is that right?
    My other question, I've been thinking all day and I can't seem to find the answer.
    When car is turnoff, removed FUSE EFI.2. and here is 2 pins, one pins reads negative and when car turn on this pin becomes positive. Why it happens? I checked it other Prius and it’s same
  7. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    You need to disconnect all consumers of this fuse, not just one connector. Look at the diagram.
    If you disconnect only one connector, you will not understand why voltage appears on this wire.
    Positive 12V is supplied to one fuse contact, and a branching line goes from the second fuse contact to six consumers.
    Until you disconnect all six consumers, checking the wiring harness for a short circuit will not give the desired result.
  8. Datuna14
    30
    San diego
    Can u explain more details step by step for example? Thx a lot
  9. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    Watch this video.
    imagine that the fuse is a switch for a multi-lamp chandelier.
    Until you unscrew all the bulbs, the light will be on.
    Therefore, you need to disconnect all consumers from the fuse power supply. This can be done by disconnecting the connectors of the units and sensors that I indicated above in the message #19.
    Datuna14 likes this.
  10. Eddie25
    503
    212
    MI
    Remove fuse. Use test light from battery NEG (with car on) to figure out which side of the now empty fuse socket is the voltage source (light will glow) and which side is the component side (light won't glow). Now hook up the test light to battery POS and touch the test light to the component side. It shouldn't be glowing because it's a B+ line and doesn't have a connection to ground. Now you can wiggle stuff around and mess with stuff trying to get the light to glow which will tell you that you have a short to ground.
    Am I an expert? No. Have I tried this personally on a Prius? No.
    I don't quite get MAX's logic here (that video is for a parasitic draw, which is different). I don't think resistance checks are typically the go-to method to find an intermittent short to ground. If the short was easily identifiable by low resistance to ground then the fuse would be blowing right away each time. Since it's not, you'd still have to wiggle stuff around and watch the meter at the same time.
    I could be totally wrong, so you'll have to weight with your own knowledge about which technique to choose.
  11. Datuna14
    30
    San diego
    Thanks for explanation, I did everything like your method but found nothing, I have other Prius for the donor parts and I compared every parts and they are same. I am interesting that because my fuse keeps blowing in 30-55 miles, This range requires certification of evaporation system, when I monitoring I/M readiness in scanner, everything passes sertification/protocols except EVAP system, when EAVP has to go thru the fuse blows and all list of modules/protocols are erased. Sometimes it burned me the next morning when the car wasn't hot.Is there any logic in this or not? What do you think?
  12. Datuna14
    30
    San diego
    I am driving without O2 b1s1 sensor and monitoring if fuse blows, tomorrow I will unplug downstream O2 and evap solenoid (near intake) and canister vent module from back near the tank reservoir. Think that test will be helpful
  13. Eddie25
    503
    212
    MI
    If you think it's happening as a result of trying to run an EVAP certification then I would certainly be considering the canister pump module or purge valve as suspects based on my wiring diagram.
  14. Datuna14
    30
    San diego
    I have question for this test, If there is a short somewhere, will the bulb really light up?
  15. Eddie25
    503
    212
    MI
    If the wiring has a short to ground and the test light is hooked to battery POS then yes.
    If it's really blowing consistently when attempting to run an EVAP check then that's the lead you should follow. If I had a donor car I would swap the Charcoal Cannister, which I'm assuming has the 'Canister Pump Module' (as per the wiring diagram), but I have not confirmed this. Purge Valve is also on that circuit but seems less likely to fail in that manner.
  16. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    Also keep in mind that the probable cause may not even be the unit itself, but rather oxides in the unit connection connector, which create a parasitic chain in the overall consumption of this line.
  17. Datuna14
    30
    San diego
    Hello.. these days I was checking all parts that is loaded on fuse EFI.2.
    fuse doesn’t blows, then install all parts together and drove more then 200 miles and fuse is ok still. I don’t know what happens. It’s time to sell it I think)))!
  18. Eddie25
    503
    212
    MI
    Did it pass the EVAP check?
  19. Datuna14
    30
    San diego
    I checked it and “EVAP” didn’t pass yet. What does it means?
  20. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    The fuse doesn't blow, that's good.
    Are there any other problems?
