2010 Prius won’t start. UO100 code
Discussion in 'Gen 3 Prius Technical Discussion' started by Datuna14, Apr 17, 2025.
  1. Datuna14
    Datuna14 Junior Member
    30
    San diego
    No isn’t. It repaired itself)) really don’t know what was
  2. ASRDogman
    ASRDogman Senior Member
    8,067
    4,089
    It doesn't really repair itself. Possibly a shorted out wire, and moving them around will keep
    it from shorting out. At least for a while. No telling if it will return or not.
    Just make a note....
  3. Datuna14
    30
    San diego
    Hello. Doesn’t returning after 1500 miles. Also I am selling my car asap))))
  4. Datuna14
    30
    San diego
    Hello everyone. This is on a different topic, but I'll write it here.
    After engine swap for Prius V, shows message P0AA6 and A/C Doesn’t..
    I wanted to read INF subcodes from “think diagzone” scanner. After detected DTC P0AA6, in freeze frame category is like code 00000:00
    Is this subcode “00”
  5. rjparker
    rjparker Tu Humilde Sirviente
    11,121
    6,978
    Texas Hill Country
    Are you buying and selling cars?
    Assuming the ac does not work after the engine swap, your code usually means high voltage wiring to the ac compressor is partially shorted to ground, often due to coolant or moisture contamination.
    MAX2 likes this.
  6. ASRDogman
    8,067
    4,089
    I see, and passing the troubles on to some innocent person? I do hope you tell them
    about the issues....
    Datuna14 likes this.
  7. Datuna14
    30
    San diego
    Yea i am new in this job, fixing and selling. In my case I have same issue when change cylinder head gasket, without orange cable removing or compressor removing but P0AA6 popping. Then I cleaned everything but it’s still.
    Some years ago I changed engine for my Prius in LA, or was same issue P0AA6 and mechanic told me it’s A/C compressor issue Which is a coincidence, it just ended its life in the hands of a mechanic
  8. Datuna14
    30
    San diego
    hello
    The problem come back, when I install fuse 10amp immediately brake. I want to ask u wiring diagram, it’s more then 400 pages, pls share page for EFI#2 line with O2, EVAP and with other components to read da find short
  9. Datuna14
    30
    San diego
    In my case it was 40amp fuse with sand, installed in inverter. It’s ac compressor fuse
  10. Mendel Leisk
    42,355
  11. Datuna14
    30
    San diego
    Thanks a lot!
