2010 Prius won’t unlock with the 12v battery dead? And key fob metal key doesn’t open driver side.
Discussion in 'Gen 3 Prius Technical Discussion' started by GreenTea&SaltWater, Jun 1, 2021.
  1. GreenTea&SaltWater
    196
    58
    Los angeles
    My 2010 Prius battery is dead doors won’t unlock and metal key insertion won’t open the door. Also can’t open trunk anyway. Worst design ever?
    48,998
    Have you tried wd40 and pliers on the key?
  3. GreenTea&SaltWater
    196
    58
    Los angeles
    The key inserts and turns but it doesn’t unlock
  4. xliderider
    xliderider Senior Member
    7,849
    3,103
    Honolulu, HI
    This may sound obvious, but did you turn the key in both ccw and cw directions?
  5. Perkolator
    Perkolator Junior Member
    33
    Sacramento, CA
    Bummer. Cheers to fellow Prius owner with a dead 12v battery today! :ROFLMAO:
    Luckily my door was open, but I still had to figure out how to move all my junk in the cargo area through the 2nd row in order to flip up the floor enough to get my hand in there to open the cargo door latch. Fun times.
  6. Mendel Leisk
    38,257
    I seem to recall there’s a trick to popping the hood, through the front grill? Then you could get power to jump point.
    second making real sure the mechanical key is not gonna work.
  7. Samuel Williams Jr
    246
    Dayton NV
    My mechanical key won't unlock the door, I thought it was a feature? :)
  8. GreenTea&SaltWater
    196
    58
    Los angeles
    Yep tried both
  9. GreenTea&SaltWater
    196
    58
    Los angeles
    Wait there’s a way to pop open the trunk from inside? It was such a pain in the nice person moving all the cargo I had to get in the floor panel fold it up enough to get my skateboard out of there
  10. Perkolator
    33
    Sacramento, CA
    Yes, but you have to get under the cargo floor panel to access the cubby hole. Once you lift up the cover, there's a small access hole under the door where the lock assembly is located - there's a lever inside you move manually to release the latch.
    I'm just going to get the TrueStart battery from Toyota parts counter, about same price as an auto parts store aftermarket so I'd rather get what Toyota carries
  11. Grit
    Grit Senior Member
    6,114
    4,040
    Wilkes Land
    :ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO:
  12. Mendel Leisk
    38,257
    Yeah, OP’s dilemma (which even he’s forgotten lol) is everything’s locked.
    short of AAA slim Jim, somehow get to the hood release??
  13. Grit
    Grit Senior Member
    6,114
    4,040
    Wilkes Land
    it’s just like those 5 bumps below the parking light bulb. They’re not LEDs just ascetics :ROFLMAO:
  14. GreenTea&SaltWater
    196
    58
    Los angeles
    Whoever designed these Prius’s that can’t unlock if the battery is dead or can’t start the engine if the hybrid battery is dead or can’t even unlock with the mechanical key, is a goddamn idiot and I hope they’re fired by now
  15. Perkolator
    33
    Sacramento, CA
    Ha, you should see what people have to go through when the 12v battery dies on a Tesla :LOL:
    Samuel Williams Jr likes this.
  16. Samuel Williams Jr
    246
    Dayton NV
    Yep I have seen that. Door handle won't flip out? Freezing temps can have the same effect.
    My friends BMW M3 had the "Foot Sensor," go out, WTH? It was at least a 1200 dollar part that the dealer has to reset? It disables, let's see, the mirrors (if they are folded in, you can't fold them out). The turn signal's don't work and the head lights only work on High Beams. Are you kidding me?
    The Prii with some non, non functional metal key's? Is pretty lame by comparison? Don't let the 12 volt die and you don't have to worry about it. But a non functional metal key won't disable the car. :)
    The A-hole in charge of quality control of the Metal Key "Feature," probably got a promotion? :)
  17. ChapmanF
    15,111
    Using the metal key now and then to unlock the door probably helps make sure it will when you need it to.
    I've never had any trouble with mine.
  18. Prodigyplace
    Prodigyplace Senior Member
    11,696
    11,317
    Central Virginia
    That is why Toyota supplies 2 fobs with keys that mechanically unlock the doors. People buying used cars need to make sure they get 2 operating fins complete with mechanical keys that work. There is nothing Toyota could have done about your situation.
  19. Prodigyplace
    11,696
    11,317
    Central Virginia
    You mean the person that replaced the fob without a working mechanical key before they sold it to the dealer??
  20. Mendel Leisk
    38,257
    yeah there’s the rub: used purchase, metal key switched?
    Prodigyplace likes this.
