2010 Prius won’t unlock with the 12v battery dead? And key fob metal key doesn’t open driver side.
Discussion in 'Gen 3 Prius Technical Discussion' started by GreenTea&SaltWater, Jun 1, 2021.
  1. Samuel Williams Jr
    246
    Dayton NV
    Nope I mean the original design team. We got ours from relatives four years ago it's a 2005 and we have both fob's. My metal key does not work but I really don't know about my wife's key?
    It's not a Bimmer floor foot sensor? So I don't rally care that much. But I suppose it is something I should look into before I need it. :)
    51,944
    future reference, you can put 12v to the jump point and pop the trunk
  3. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    come on, you’ll put a kabawsh the “crawl of shame” posts.
  4. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    don’t forget about the people doing that intentionally and remind us about immoral and karma. I got that lecture here couple of times with selling undisclosed blown head gaskets and failing hv batteries to dealerships like carmax.
  5. ASRDogman
    ASRDogman Senior Member
    7,596
    3,916
    If you know someone with AAA they can come unlock the door.
    Or your local volunteer could do it?
    Since the key turns, both ways, the plastic piece the holds the rod to the key cylinder that unlocks the door,
    it's probably broken and the rod fell out. Many brands of cars have this happen, not just the Prius.
    You might be able to pull the top of the door away from the frame and slide a coat hanger, or something
    similar, and hook the door handle to open the door.
    Once the door is open, you can pop the hood and put a jumper at the fuze box and then you'll be able
    to pop the trunk.
  6. ASRDogman
    7,596
    3,916
    Sooooooo...... an update to if you were able to get the door open?? And by which way? :whistle:
  7. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    the op has another thread with a failing hv battery, waiting for an update on that also.
  8. ASRDogman
    7,596
    3,916
    HOW does he know it's failing of the 12v battery is dead?
    Any bets that is the problem?????
  9. xliderider
    xliderider Senior Member
    8,140
    3,276
    Honolulu, HI
    Same here, no problem the last time our 12v battery died. Opened the driver's door easily with the metal key.
  10. ASRDogman
    7,596
    3,916
    Update????
  11. Mendel Leisk
    41,463
    Unless OP’s metal key is not the right one.
  12. GreenTea&SaltWater
    199
    58
    Los angeles
    Still stranded in a Walmart parking lot in the middle of the desert… and it’s summer… going on 3 days at Walmart now.
  13. GreenTea&SaltWater
    199
    58
    Los angeles
    That’s gotta be it. I did buy it used
    Prodigyplace and Mendel Leisk like this.
  14. ASRDogman
    7,596
    3,916
    Why don't you contact the local police and ask them if they will open your door?
    Then you can jump the 12v Battery, or at least buy one from walfart and install it.
    BEFORe the hybrid battery dies.
  15. GreenTea&SaltWater
    199
    58
    Los angeles
    So I was able to open it with the mechanical key. The thing is the plastic was very fragile so when I tried turning it the first time it broke and turns out I couldn’t get enough leverage to fully turn it. So I used some pets for leverage and was able to open it
  16. Mendel Leisk
    41,463
    Wait a sec…
  17. ASRDogman
    7,596
    3,916
    Okay, you got it open, with a pet? Or you have pets? Or misspelled word? :)
    Maybe walfart will put a charger on it for you. And see if it holds a charge?
    Just keep the amps 5 or less.
  18. GreenTea&SaltWater
    199
    58
    Los angeles
    Lol I meant pliers. I bought a battery charger 3 amps for $20 from Walmart how long would that take to charge my battery?
  19. ASRDogman
    7,596
    3,916
    I figured that! :)
    If it's REALLY dead, overnight at least. If after a few hours it's not up to 12.5v, and holding,
    It's probably time for a battery(12v). You want to leave it on as long as you can because
    the hybrid doesn't charge it very fast. You would need several hour of driving to charge it.
    But it may be good enough to get you home and then you could charge it overnight(12+hours).
    Why was it dead? Was it completely dead? What was/is the voltage. did any lights come on when
    you tried to start it after getting the door open? How old is the battery? 5+ years, Probably should replace it.
    But since you have the charger, give that a try.
  20. GreenTea&SaltWater
    199
    58
    Los angeles
    My dumbass somehow thought a battery charger would magically charge it like a solar panel didn’t realize I have to plug it into a power outlet. I’m homeless so I don’t have that. The hybrid battery stopped working and it was running on gas engine for two days then the 2 days later the engine wouldn’t start but all the lights on the dashboard lit up then another 2 days later the 12v was completely dead
