2010 Prius won’t unlock with the 12v battery dead? And key fob metal key doesn’t open driver side.
Discussion in 'Gen 3 Prius Technical Discussion' started by GreenTea&SaltWater, Jun 1, 2021.
  1. Mendel Leisk
    41,114
    You’ll need to find a “home” for your car, for at least a day; maybe local garage, obviously with AC power. Maybe a PepBoys or similar, preferably one with compatible replacement batteries for sale and electronic load tester.
    Try charging first (could take 12 hours), and (presuming the charger can successfully run through a charging cycle).
    Then get the electronic load test done, verify it’s still got “life”.
    If not, replace.
    All of that might be too cumbersome in your scenario: go straight to replacement?
    Samuel Williams Jr likes this.
  2. Mendel Leisk
    41,114
    Your best purchase right now might be a set of jumper cables. With a Good Samaritan or two you’ll be able to get it started, get to a retailer that has the battery you need. Phone ahead.
  3. Grit
    Grit Senior Member
    6,573
    4,225
    Wilkes Land
    the op’ster has another thread saying he got the cel code to replace hybrid battery so your great tip alone may not resolve his issue, I mean issues. He’s got other threads with different issues. Wish I can get attention like that
  4. ASRDogman
    ASRDogman Senior Member
    7,482
    3,880
    Info we didn't have before. The hybrid battery starts the engine, and runs all the 12v item and charges
    the 12V.
    Seems like you have have more serious issues then the 12v battery.
    Maybe the inverter has failed??? I believe you'll need someone weith hybrid experience to look at it.
    I know you probably don't have the money, and I don't know how to help you, sorry.
  5. Prodigyplace
    12,486
    11,730
    Central Virginia
    Dogs, cats, rabbits, or goldfish?
  6. GreenTea&SaltWater
    199
    58
    Los angeles
    The battery is fine. I just had it double checked and charged at the Walmart who’s parking lot I’ve been sleeping in the past 5 days. It’s definitely something with the hybrid engine. I have 3 cells on the way to LA from JWAP. My friend is driving two hours into the desert to pick me up with triple AAA he’s on his way. I have a driveway I could do the repair in LA this week
    ASRDogman and Mendel Leisk like this.
  7. bisco
    51,669
    ah, another thread, no wonder i'm lost (n)
    GreenTea&SaltWater likes this.
  8. Mendel Leisk
    41,114
    Sounds like a plan. (y)
  9. Grit
    Grit Senior Member
    6,573
    4,225
    Wilkes Land
    No way! I actually like this, it’s like watching the tv show “Lost” which we re taken from one story line to another. There’s 13 different story lines going on at the same time, and then it commercials.
  10. GreenTea&SaltWater
    199
    58
    Los angeles
    I am in Los Angeles my friend came smart through what a legend
    bisco, ASRDogman and Mendel Leisk like this.
  11. bisco
    51,669
    that's a good friend (y)
  12. GreenTea&SaltWater
    199
    58
    Los angeles
    Goddamn it that auto swipe type function fookin sucks on iPhone. Earlier it was using my “pets” as leverage now my friend picking me up from the desert was “smart”. Anyways he took a day trip to the desert 2hrs away to pick me up and use his AAA membership to tow me 117 miles seriously a smart legend. Even helped me move stuff around my storage locker. I’m floored by how incredibly helpful some people can be. It’s inspiring man it makes me wanna be a better person and succeed in life so I could give back
    edit: woahh it autocorrected fookin to smart again why is it doing that??
  13. Stuart M Whitaker
    Stuart M Whitaker Junior Member
    Virginia
    I just found this thread two years on. Correlation is not causation: the fact that the 12v battery is dead has nothing to do with the fact that the metal key doesn't open the driver door. The only reason they even appear to be correlated is that people try to open the drivers door with the key when the battery has died. AAA pried open my door, I charged the battery, and yet the key still doesn't work. I suspect ASRDogman has the answer.
    ASRDogman likes this.
  14. alexk345
    alexk345 Junior Member
    46
    india
    I have same problem but my key worked before. I am calling unlock people They are charging 150 to open the door.
    I am mad. I was always thinking physical key will open. It seems it needs some battery
  15. ASRDogman
    7,482
    3,880
    ??? The correc physical key will work.
    You don't give much insite to what happened....
  16. alexk345
    46
    india
    My physical key do not work now. I put allen key in middle hole and bend clockwise. Car cant open
  17. ASRDogman
    7,482
    3,880
    So it is not turning? Are you sure it is the correct key? Have you ever used it
    to make sure it worked?
    Try spraying some wd-40 or other lube in it to hopefully free it up...
  18. alexk345
    46
    india
    I used the plier like the guy said i broke that small platic on the key. Still cant open.
    Damn.
  19. alexk345
    46
    india
    Its turning clockwise and anticlockwise. It seems like you still need battery for it to work. fob may not work with low battery but for key to work it seems it need battery. You still some voltage on battery for it to work it seems.
    Because a month ago i opened with same key without any effort.
    At first i was able to open half way and get stuck. Should have used metal hanger i pushed it back thought that will help. Now i cant even get that half and probably used last ounce of battery
    #59 alexk345, Apr 12, 2024
  20. ASRDogman
    7,482
    3,880
    you don't need the battery when using the key. It's for when the battery dies.
    Something has come loose in the door that is not allowing it to unlock the door.
