2010 Prius WONT MOVE! HELP!
Discussion in 'Gen 3 Prius Main Forum' started by Chris626, Jan 28, 2024.
  1. Chris626
    Chris626 Junior Member
    25
    Ca
    I was driving my 2010 Prius when suddenly I felt some pull to the passenger side and decided to turn off the main road. As I did I heard like a grinding sound coming seemingly from the road level below the engine bay. The car didn’t throw any dash lights but wouldn’t move afterward and would grind when put into any gear (drive or reverse) . The sound was similar to something turning but grinding against something else. The engine starts up fine and again no warning lights on the dash. My first thought was transmission or some part of the suspension. I didn’t see any noticeable leaking of oil or fluid and also didn’t see any broken pieces or metal fragments. Towing to the STEALER tomorrow but wanted to see if anyone had any thoughts.
    52,742
    I’m thinking cv joint or axle spline.
    How many miles on her?
  3. JC91006
    16,928
    8,637
    Why tow to dealer? You probably have a suspension or brake issue. Don’t need dealer for that.
    you can get a cheap diagnosis at Armstrong auto service in Rosemead
  4. Tombukt2
    Tombukt2 Senior Member
    13,779
    2,495
    Durham NC
    Your suspension and all of the underpinnings of your cars very much Yaris and Corolla It should be able to go to pretty much anybody to be diagnosed in this genre of repair The last place I would take anything is to the Toyota dealer personally that's generally not a smart move for people with an older car If you're forced into warranty work and all that because your car is new and that's what you need to do then that's what you have to do but after that there is absolutely no reason to be doing anything with the dealer unless you have a good in with a dealer or something I used to have this years ago with the local Toyota dealer and let me tell you they save me a bunch of money but I had a connection there I worked in the car industry and one hand wash the other and all that kind of nonsense so unless you've got something going on that's the last thing you want to be doing.
  5. Chris626
    25
    Ca
    200k + lol High mileage but she has a newly rebuilt engine
  6. Chris626
    25
    Ca
    Could it be as simple as a suspension issue if it wouldn’t move? Seems like it’d be more complex right?
  7. Chris626
    25
    Ca
    There is no doubt that a connect at the dealership is priceless! lol This dealership has at least been pretty fair the times that I’ve had to go there. Depending on the issue I might have them replace the wheel bearings as well on the front end
  8. PriusCamper
    PriusCamper Senior Member
    13,366
    5,402
    Pacific Northwest, USA
    You own a 14 year old car and Toyota Stealerships are warranty specialists for brand new cars. Even if it's an easy repair that doesn't cost much the dishonest people at the stealer will try to scare you or trick you into thinking your car can't be saved and you have to buy a new one that's not a hybrid because nobody is buying their non-hybrid / non-EV inventory anymore. Just have it towed to your tire shop or to a local mechanic a friend, family member or nextdoor.com recommends.
    Chris626 likes this.
  9. JC91006
    16,928
    8,637
    It could be anything. Your brakes could have locked up, if the glide pins are not lubricated. That’s why you always get a proper inspection and not guess at it
  10. Chris626
    25
    Ca
    I believe it! The dealership is where wallets go to die lol
    bisco and Danno5060 like this.
  11. Chris626
    25
    Ca
    It seems to be something more than the brakes locking up because it makes a feuding noise while in gear but not in motion. I hear you though it could be anything lol
  12. JC91006
    16,928
    8,637
    Could be just an axle problem. But I don’t think your issue is that big, transaxle failures are rare
    djasonw and Chris626 like this.
  13. ChapmanF
    18,920
    If it makes the noise while not in motion, that rules out a lot of things (hubs, brakes, axles ...).
  14. JC91006
    16,928
    8,637
    How long have you had this car? The 2015 models are usually the most reliable of the 3rd Gen cars. You have gone through a rebuilt engine and now possibly faced with another major problem.
  15. Chris626
    25
    Ca
    I’ve had it about 6 years. It’s a solid little car the rebuilt engine only cost me 1600
  16. JC91006
    16,928
    8,637
    If you find out what's wrong with your car, come back and let us know.
  17. PriusCamper
    13,366
    5,402
    Any chance you can get in touch with the person who rebuilt the engine 6 years ago? Your symptoms point to engine problems... Once you get warning lights on the dash you'll know more. Maybe it's just a bad pump or pulley wheel? In meantime, it's essential you confirm exact location of the noise. If it makes the noise when car is not moving that should be easy with an automotive stethoscope or just a stick or screwdriver held to your ear.
  18. bettergolf
    bettergolf Active Member
    493
    370
    Sanford NC
    Sound like the transmission grinding to me.
  19. Chris626
    25
    Ca
    I definitely will. It’s at the stealership so we’ll see what they say
  20. Chris626
    25
    Ca
    I definitely will if it needs it. I think it’s probably suspension related or transmission
