2010 Prius XW30 inverter failure (P3004 800)
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Oedipus, May 8, 2018.
  1. Oedipus
    Oedipus Junior Member
    Been reading along in this forum for a while. Never had anything to post since my car was running fine. Until now.
    2 weeks ago, the Prius wouldn’t start. After a short drive at noon, the wife needed to go somewhere but the thing didn’t move. The ready light came on but immediately disappeared, throwing in a “Check Hybrid System” error. Car was towed to the workshop where they diagnosed a P3004 detailcode 800 error. It means the inverter is toast. All testing procedures were followed and the onverter can apparently be repaired but must be opened. The kit costs roughly 800€ (about $1,000) without work. Total estimate 1.800€ ($2,200).
    A few things cross my mind now:
    - since the inverter fails rather rarely, I’d consider fitting a second hand one. Apparently the are are many serials around from 2010 inverters so the garage wasn’t too enthousiastic. Any experiences with this?
    - to those that experienced it before and decided to repair the inverter: was the car completely functional again, or did any of you have the same or other related problems later on?
    Thx for sharing. Seriously disappointed Toyota lover.
  2. BrickedKeyboard
    BrickedKeyboard Junior Member
    Houston
    Umm, ebay? Go look on ebay, I just did a search, they are literally a dime a dozen. There are hundreds of listings of used inverters. One seller is selling a lot of them that have been "remanufactured" (probably just cleaned up and verified to work) for $170. Since swapping the inverter is a pain, a better deal might be one that came from a 2010 with low miles - there are some for $300-400 that are supposedly pulled from wrecked Prii that have low miles on them.
    It's right there at the top of the engine bay, it's probably not that hard to swap if you get a bad one. I would consider just getting the car towed home and doing a DIY inverter swap. By far the cheapest option. There are youtube videos, it looks fairly easy.
    Oedipus likes this.
  3. Grit
    Grit Senior Member
    6,443
    4,185
    Wilkes Land
    What is the warranty on your prius inverter?
    51,103
    call toyota customer service and ask for goodwill warranty help. how many miles on her?
    Michelle Gaunt likes this.
  5. Asseks
    Asseks New Member
    Minsk, Belarus
    Hi guys. I'm a new here. I've had the same error with my Prius. Error is P3004-800.
    Any solutions? Would the replacement of the inverter help?
  6. Oedipus
    Warranty is 5 years or 150.000km on a Gen III (XW30). On the earlier models it was 8 years. There is an 8 year warranty on the battery (extendable until 12y if yearly maintained at Toyota dealer), but that is not the issue. Inverter is not covered.
    I did. They informed me that there is a repair kit available, for which I was quoted. They consider that goodwill since I don’t need to replace the entire inverter. Not my idea of goodwill.
    Mine has 110.000km (~70,000miles). We bought it in May 2016 ago as a TopCar select second hand car from the Toyota dealer. It was at that time 6 years and 2 months old and we had 12months TopCar warranty on it (bumper to bumper). The car failed when it was 10 months out of this warranty, now 8y and 3 months old.
    That is exactly what the Toyota dealer troubleshooted. This code means in my case the inverter fails.
    Update from today: troubleshooting by the book with Toyota tech service already learned there was a fix for my inverter model G92A0-47030. New today was that for this the inverter needs to be opened and a pretty big repair is needed, after which it needs to be resealed. So in addition to the repair kit, the labour is significant. I’m now on the lookout for a second hand inverter. Failures seem to be so rare there are plenty available for low prices (plus the inverter swap is a lot quicker in manhours). Any tips for reputed salvage yards or parts distributors are welcome... in Europe.
  7. Asseks
    Asseks New Member
    Minsk, Belarus
    It's weird, bcouz my the Toyota dealer exclude inverter. The dealer is checking wiring between HV battery and inverter.
    I'm thinking that the main reason of this error - inverter fails. And I wanna replace it and already found inverter from Auris 2016.
    let's wait the dealer test results.
  8. bisco
    51,103
    a more specific location may help, and even in the title to grab attention of local members.
  9. Asseks
    Asseks New Member
    Minsk, Belarus
    So, that was an inverter.Broken inverter was changed and error is gone. Now everything is great )
    #9 Asseks, May 28, 2018
    RMB likes this.
  10. Tim Jones
    Tim Jones Senior Member
    1,742
    562
    SE Texas
    2011 Nissan LEAF
    The inverter is warranted for 15 years. They can fail...... Did you get the recall letters recently?
  11. Stefan Milev
    Stefan Milev Junior Member
    Spain
    A little late for the party, but with the same error P3004-800. I swapped the inverter myself and the car is running fine.
    The reason for doing it myself was that Toyota in Spain didn't even know that the inverter fail is a common issue and there is a campaign
    about it. They didn't know what IGBT's are and what do they do, so I decided not to lose my time with them and just repair my car as I have always done until now.
    Swapping the inverter is not difficult at all. Just remember to check if the software on it is current.
    CR94 likes this.
