1. Wobblybike
    Wobblybike Junior Member
    23
    Los angeles
    Hello. I just checked my aux battery on my Prius 2010. My meter says 47ah and cca 225a. Is that still a good battery? My meter says yes but I don’t trust the numbers. On top of the battery it says ADF 325a. Hope to get an answer as I don’t want my daughter to break down. Thank you
  2. PriusCamper
    PriusCamper Senior Member
    13,388
    5,409
    Pacific Northwest, USA
    Those are pretty good looking numbers and can see why you'd be skeptical... What kind of 12v? What kind of meter?
    #2 PriusCamper, Jun 5, 2022
  3. mr_guy_mann
    mr_guy_mann Senior Member
    4,109
    2,011
    NJ-USA
    If you have concerns and want reliability then just replace the battery.
    Otherwise, if it's less than 4 years old, charge it, load test it, (maybe test key off draw for the car). Then decide if you want to replace it anyway.
  4. Mendel Leisk
    42,249
    What are you using, some sort of electronic load tester? 225 CCA is not good. Typically a healthy battery will read well above the rated CCA.
    What's the volts, when it's sat overnight?
  5. CR94
    CR94 Senior Member
    2,814
    1,235
    Northwestern S.C.
    I don't see how those can be remotely meaningful numbers. To confirm or measure a battery's ah rating, you have to drain it from fully charged down to a low voltage at a controlled rate at a controlled temperature. CCA stands for Cold Cranking Amperes, which is measured by definition at 0°F. CCA is irrelevant to booting up a Prius, which requires much less than 225 amperes, anyway.
  6. Mendel Leisk
    42,249
    The electronic load testers manage to test voltage and CCA, with the push of a button, and give a verdict. With my Solar BA5 the verdicts are Good, Good-but-Needs-Charging and Fail.
    A typical new battery, say rated at 325 CCA, will show maybe 350~400 CCA on these testers when in good condition. An ailing battery will have CCA below spec, and the verdict will typically be Fail.
    If you look on Amazon the current itteration of the Solar tester is BA9 I think. "Solar" is just the brand name, btw: it's not solar powered or whatever.
  7. Wobblybike
    23
    Los angeles
    Meter is Topdon 101
  8. Wobblybike
    23
    Los angeles
    Thank you everyone. I did a test again this am and saw that the CCA 223 and charge test showed 43. I bought a battery at Toyota for $270 and did my own install. Their cost for the battery and install would of been $398. I guess they getaway with it. Took me 10 mn. Thanks again. This is a great forum.
  9. Wobblybike
    23
    Los angeles
    My tester is a Topdon AB101. It said to replace the battery.
  10. ASRDogman
    ASRDogman Senior Member
    8,023
    4,072
    Toyota doesn't "getaway with it". A person chooses to have them do it, for whatever
    price it is. They do not force anyone to get the work done.
    Just Say No!
  11. Mendel Leisk
    42,249
    Check the CCA on the new one. IIRC they’re rated 325, and I’d wager you’ll see around 350, or more.
