2010 Revving and Misfiring
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by jas8908, Dec 21, 2019.
Tags:
  1. jas8908
    jas8908 Member
    42
    38
    dallas
    2010 Prius with 106k, zero oil burning (and full), no coolant loss (or smoke), added OCC about a year ago but no EGR/Cooler cleaning yet.
    My 2010 Prius just started revving, shaking and misfiring. It's constant and consistent. It will not stop unlike the brief startup noise.
    Techstream initially showed misfire on 4 with no codes. Then a misfire on 3 & 4. Changed the coilpack from 3 to 4 then showed a misfire on 2. Checked again (clearing codes every time) and got no misfire, then misfire back on 4. So I think the coilpacks are probably ruled out. From the data it seems to indicate its not a normal misfire that Techstream is programmed to recognize.
    At 106k its doubtful the HG is blown but possible. Also at this lower mileage and no oil used the EGR probably wont have that much buildup but I'll find out.
    This problem happened just one morning after running perfectly the years before.
    Anyone have any other ideas? Thanks.
  2. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    I would clean the cooler and go from there
  3. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    How’s the engine coolant level:whistle:?
    If lower than you remember, you might be in head gasket land:cool:.
    Good luck and keep us posted (y).
    SFO likes this.
  4. jas8908
    jas8908 Member
    42
    38
    dallas
    Thanks planning on cleaning the cooler and will let you know. Coolant level is good, thanks.
    Mendel Leisk and Raytheeagle like this.
  5. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    If you clean the cooler, swap the spark plugs since you’ll be taking the windshield wiper cowling off;).
    You’ll be there anyway and near the mileage to do so:).
    mjoo likes this.
  6. jas8908
    jas8908 Member
    42
    38
    dallas
    Pulled off the EGR system. I suspected the EGR valve might be stuck open. Does anyone know if the valve is closed when initially pulled? Mine appears open. Thanks egr valve.JPG
  7. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    On the many Prii I have worked on (over 12 gen3’s), the valve has always been closed;).
    That’s it’s default position when not magnetized, unless there’s something prohibiting that:cool:.
    I’d say a thorough cleaning is in order(y).
    SFO likes this.
  8. hotelprisoner
    hotelprisoner Member
    104
    87
    Ontario, Canada
    Technology
    The valve is spring loaded closed. The black cap can be removed, the magnet removed and the inside chamber can be cleaned. I would not let liquid into the pintle shaft or on the lower magnet bearing, but you could brake clean or OxiClean soak it to just below the top of that inside chamber. Hopefully that helps to unbind it assuming the springs haven’t failed under the magnet. I used some brass brushes on a drill to remove the gunk and clean the gasket interface areas.
    iPhone ?
    SFO likes this.
  9. hotelprisoner
    104
    87
    Ontario, Canada
    Technology
    iPhone ?
    SFO and Mendel Leisk like this.
  10. hotelprisoner
    104
    87
    Ontario, Canada
    Technology
    Keep this side clean and free of water or cleaner. There is some type of grease on the thread of the magnet, not sure what kind.
    That spring is what keeps the valve closed.
    iPhone ?
  11. ChapmanF
    19,016
    The EGR valve actuator is a stepper motor, with the valve's full range of motion being (IIRC) 111 steps, as the magnetic rotor spins on the threaded pintle shaft.
    There has been a little mystery on PC about whether the ECU knows what step the valve is on if it has been disassembled that way. I would assume it can just attempt to step in the 'close' direction more than 111 times and then say "ok, wherever I was, now I know where I am", and the spring construction also suggests that. But oddly enough, there was a recent thread (I doubt I'll be able to find it) where someone had disassembled and reassembled the valve, and afterward it seemed to be acting as if the positioning was off.
    Were there any EGR-related codes? The ECU does conduct self-tests now and then.
  12. jas8908
    jas8908 Member
    42
    38
    dallas
    Thanks Ray I do plan a thorough cleaning.
    Thanks for the images and great description Hotelprisoner. I had no idea what was below the valve so definitely will ensure the cleaning does not reach the lower springs.
    Thanks ChapmanF. There are zero codes but Techstream did show misfires in various cylinders at times (one time no misfires). The car has been undriveable. It shakes and shudders so much I don't even feel comfortable starting it longer than needed to test on Techstream. I did run through the Techstream steps for the EGR a while back. If I can get the valve free hopefully the system will recognize the valve is closed again.
    Here's one more image of the valve with some carbon scraped off. Seems like it's stuck open. 66.JPG
    Raytheeagle likes this.
  13. Mendel Leisk
    42,341
    I would suggest to clean the valve without doing any disassemble, ie: taking the black cap off. It's more difficult, but maybe safer, all things considered.
    I cleaned the best I could from both ends, and then gently pried up the flange, cleaned the contact zone.
    If it was was stuck open, would there be a warning light and code (besides the misfire code)?
    How's the cooler looking?
    #13 Mendel Leisk, Dec 24, 2019
  14. hotelprisoner
    104
    87
    Ontario, Canada
    Technology
    That carbon coking will foul the movement of the valve pintle between the inner chamber and where it exits the top. I’m not sure what is in here but there should be something that prevents flow of exhaust gas through the pintle shaft but still allows the shaft to move. Some have thought about applying a grease here which might just attract more crud. I used a little brake clean in there and it loosened everything to allow free movement. Lots of history of these binding open or closed.
    During reassembly, the magnet will try to unspin it self. What I did to ensure it’s all closed properly is to spin on the the black cap thus tightening down the magnet. I also used a micro screwdriver in one of the 2 little slots just under one side of the black cap to hold the magnet in the fully down position and prevent it from spinning while I secured the black cap.
    iPhone ?
  15. jas8908
    jas8908 Member
    42
    38
    dallas
    hotelprisoner: I'd prefer to take Mendel's view and not open unless I'm unable to close the valve. I can easily take things apart but sometimes they take a long time to get back together. :) I know some have said no Oxi to clean the valve. Did Oxi cause a problem with yours? I'd prefer Oxi since I can dip the end in it pretty easily.
    Mendel: Here are 2 images of both sides of the cooler. Seem comparable to most I've seen here. I'll use Ray's power washer idea to clean it.
  16. hotelprisoner
    104
    87
    Ontario, Canada
    Technology
    So my valve stays closed so no problem keeping cleaning solutions inside. I put a mild Oxi solution with hot water in there and let it sit for say 2 hours. Did the rest with brake clean and brass brushes. No issues.
    Edit: I should note that I for this one I actually unthreaded that spring so the valve naturally falls open and then used a c-clamp to hold a hockey puck over the valve opening so I could get both sides of the valve in the same soak. Maybe a little overkill, but it’s sparkling clean.
    I’ve read the concerns here with oxi-Clean vs aluminum which is why I chose to limit my soak time and go easy on the oxi. My goal was just to soak it enough to loosen the gunk and use brushes and brake clean to finish the job.
    iPhone ?
    #16 hotelprisoner, Dec 24, 2019
  17. jas8908
    jas8908 Member
    42
    38
    dallas
    Thanks hotelprisoner, did the Oxi soak!
    EGR is back on. Car runs great but stumbles upon throttle. I'd rather not put the rest of the cowl and under panel back on until I know its good. So I'll need to figure out maintenance mode to check EGR step levels. Is there a way to simulate driving with techstream? Thanks
  18. Mendel Leisk
    42,341
    Oxi is good on the cooler. On the valve should be cleanable with carb or brake cleaner. The cooler is stainless steel, but the valve is mostly aluminum and likely to tarnish. Might just be cosmetic, but I would avoid oxi for the valve.
  19. hotelprisoner
    104
    87
    Ontario, Canada
    Technology
    Techstream does have a test that allows you to take control of EGR and manually set the step. This is done through Engine and ECT - Active Test.
    The FSM states:
    A/C and all accessory switches off.
    Engine in Inspection Mode and coolant 75C or more.
    Shift lever in P or N.
    Do not leave EGR valve open for 10 seconds or greater.
    Return step to 0 when Active test complete.
    Do not open 30 steps or more during Active Test.
    iPad ?
  20. jas8908
    jas8908 Member
    42
    38
    dallas
    Thanks Hotelprisoner. Was able to successfully control the EGR valve through Techstream.
    Final Update: Problem is solved. Carbon deposits caused the EGR valve to stay open. Cleaned the EGR valve (also the cooler/pipe) and the car has been running great since.
    For others, you'll be able to tell its a stuck OPEN EGR valve when the car shakes/shudders/misfires on startup and becomes undriveable, I had misfires over multiple cylinders (sometimes none despite it running poorly). Thanks for everyone's help.
    Nor'easter and Mendel Leisk like this.
