2010 right rear speed sensor replacement
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by ctrapp, Apr 2, 2019.
  1. ctrapp
    ctrapp Junior Member
    Westmont, IL
    2002 Prius
    I own a 2010 hatchback with 116k miles, garage kept. I have seen a lot of posts about issues with rear speed sensor, VSC lights, etc. While driving the ABS, brake and traction control lights came on and braking was affected. The dealer replaced the right rear speed sensor and wire. The service staffer indicated that in the Midwest salt and corrosion could have been the cause. I think it was going for a while before failure and have several questions. I was concerned about my safety.
    It seems this is a common problem—is that true? Is it related to normal wear and tear or something that Toyota should do something about since it seemed to be a safety issue and affected the regenerative braking?
    Could this have been detected during normal maintenance before failure?
    Do i need to worry about other speed sensors having the same issue?
    Of course it was not under warranty and was an expensive repair. I am considering contacting Toyota customer relations about this and would like input if this is reasonable to ask for some compensation. Has anyone done this ?
    Thanks for any suggestions.
  2. Mendel Leisk
    42,056
    Just food for thought: the speed sensor is part of the bearing, and I think a speed sensor replacement would in fact be a bearing replacement.
  3. ctrapp
    Westmont, IL
    2002 Prius
    It looks like components included the hub &bearing assembly, wire &skid control wire and flange nut.
    Nov 2018 112k miles I had rear brake pads, shims and rotors done. Would anything have been detected then during inspection? No notes on m6 service record..
    52,544
    unlikely, it's not something you can see. otoh, who knows what the monkeys did back there.
