2010 Speedo Disappears!
Discussion in 'Gen 3 Prius Technical Discussion' started by Duncwarw, Jul 9, 2023.
  1. Duncwarw
    Duncwarw Junior Member
    50
    Capital Region, NY
    Hi folks!
    My daughter's speedometer display just disappears randomly while driving.
    I tried uploading a short video but it wasn't allowed for some reason so I'll try to describe....
    Driving along, the speedometer reading ONLY will just sort of go away while all other elements
    of the display remain on. It may stay that way for several minutes and then come back on.
    Again, it's random in that it doesn't happen when it's hot or cold or if you hit a bump. It just happens.
    If this has been discussed previously, forgive me if I missed it.
    I look forward to helpful advice.
  2. nicoj36
    nicoj36 Active Member
    518
    162
    Check for loose or defective fuse
  3. Duncwarw
    50
    Capital Region, NY
    Basics first, I'll give it a try.
    Thanks!
  4. Grit
    Grit Senior Member
    6,577
    4,230
    Wilkes Land
    Dimmer wheel
  5. Duncwarw
    50
    Capital Region, NY
    I read that elsewhere on this site and fiddled with the dimmer. It made no difference to the speedo.
    The issue doesn't seem to be related to the dimmer or the level of "brightness" outside.
    It's just the speedometer and it's simply off altogether when it happens.
