2010 sway bar links...looks like me needs new ones
Discussion in 'Gen 3 Prius Main Forum' started by Jeffrimerman, Apr 12, 2021.
  1. Jeffrimerman
    Jeffrimerman Member
    229
    45
    Pasadena
    I didn't even know what these were called but when I googled, a great youtube video came up showing how to change them. Both have the rubber boot opened up so looks like I need new ones. Could this be the source of my clunk sounds? When I'm parked in my garage I turn the steering wheel to the left and then rock it back and forth and hear a clunking. I'll have to have my brother look and listen when he's here. Also when driving my steering doesn't feel as tight.
    mikey_t likes this.
  2. Jeffrimerman
    Jeffrimerman Member
    229
    45
    Pasadena
    Here is the video, seems like one of the more simple jobs
  3. Jeffrimerman
    Jeffrimerman Member
    229
    45
    Pasadena
    I googled symptoms of sway bar links and this came up. Exactly the things I was noticing
    Some of the most common symptoms of a bad sway bar bushing or sway bar links going bad are:
    • Clunking noise.
    • Rattling noise.
    • Knocking uneven noise road.
    • Lack of stability when driving.
    • Noise going over speed bumps.
    • Poor handling when turning
  4. Team_Geek
    Team_Geek Member
    62
    31
    MN
    Hey a few more replies to yourself and you’ll have your problem solved! ;)
    I’d say you are on the right track. The sway bar ‘borrows’ spring from the other side of your suspension when you go around curves to help control body roll. The sway bar lets you have softer spring rates while giving you added stability in cornering situations.
    The sway bar itself connects via those linkages to each strut. If they wear out it will give the symptoms you’ve listed.
    They are generally pretty easy to replace with a jack and common hand tools.
    mr_guy_mann and Johnny Cakes like this.
  5. Mendel Leisk
    40,530
    How many miles?
  6. Paul E. Highway
    Paul E. Highway Active Member
    206
    129
    Hawaii
    I replaced the sway bar links on my 2010 at 149K and the clunk when entering a driveway or making a sharp turn at speed went away. Mine looked way worse than yours. Did the sway bar bushings a couple months later, they were shot as well. Slight improvement felt. Easy jobs!
  7. Mdv55
    Mdv55 Active Member
    246
    181
    Boston
    Sway bar links are the most likely and cheapest candidate to fail first when it comes to noisy suspensions.
  8. Mendel Leisk
    40,530
    What’s killing them? Speed bumps?
  9. ChapmanF
    17,247
    Probably turns. If you could just get people to drive straighter....
  10. Mdv55
    Mdv55 Active Member
    246
    181
    Boston
    Potholes and rough roads wear them out faster as well, especially if the car is loaded a lot.
    Paul E. Highway and Mendel Leisk like this.
  11. ChapmanF
    17,247
    Common-mode impulses like a speed bump just move both ends of the sway bar together, and aren't very stressful to the links.
    Something like a pothole struck by just one wheel will stress both links.
    Turning will naturally stress both links, because of the geometry. Their top ends attach to the strut bodies, at points that move as the strut rotates when steering.
    On the inside of the turn, that point moves closer to 'straightening' the link, so it pushes the sway bar end downward and the coil spring upward ... pre-compressing the coil on that side, and tending to lower the car's stance on that side.
    Meanwhile, on the outside of the turn, the point moves so as to further 'angle' the link, so it pulls that sway bar end upward and the coil spring downward ... pre-extending the coil on that side and tending to raise the stance on that side.
    Those effects on the stance tend to counterbalance the g forces wanting to lean the car outward. It also effectively makes the outside coil spring stiffer by 'borrowing spring' from the one on the inside, as Team_Geek put it in #4. That's got to be the neatest way I've ever seen it explained.
    So those links are under respectable stress whenever turning.
  12. ALS
    ALS Active Member
    590
    294
    Pittsburgh
    I replaced one last year at the dealer. It wasn't that bad cost wise. They put in an aftermarket one they picked up at a local parts store. Even the dealer said the cost of Toyota OEM part was ridiculous.
  13. Mendel Leisk
    40,530
    I’ve had sim experience with Honda dealerships; they’ll offer both OEM and aftermarket, for suspension, starters, what have you.
    ALS likes this.
  14. mr_guy_mann
    mr_guy_mann Senior Member
    3,952
    1,904
    NJ-USA
    It's a moving part- so the more it moves and the higher the loading (ie turning the car, potholes, etc) then the sooner it will wear out.
  15. mr_guy_mann
    3,952
    1,904
    NJ-USA
    Usually I find sway bar links (and sway bar frame bushings) show up best by standing next to one of the front doors. Push / pull sideways on the top of the door (easier if you can "grab" part of the rain channel with your fingers). The idea is to force the car to rock (and roll) some- which the sway bar tries to prevent. Sometimes you need someone on the ground to carefully get some fingers on various suspension parts while rocking in order to feel and verify the loose and noisy part.
  16. Jeffrimerman
    Jeffrimerman Member
    229
    45
    Pasadena
    Yup replaced the sway bar links and it drives better. I still hear some loose sounds and clunking but less. I'm sure I need to get to a couple more things to make it feel new ish again. It drives normal now. It's just sounds when stopping or when I'm in my garage I can turn the wheels left and right and hear some clunk. I made a new post asking but I should have just kept in this post. I'll use the link below to check these parts. Not sure if all issues will show up visually like the sway bar links did. I looked closer and the rubber was torn so for sure those were done. Tie rod ends, inner tie rods, and front lower ball joints. Do the control arms wear out at 120k miles or at all?
    Toyota Prius Steering & Suspension Replacement Kits | Toyota Prius Steering | Toyota Prius Suspension Kit at 1AAuto.com
  17. Team_Geek
    Team_Geek Member
    62
    31
    MN
    There are lower control arm bushings that could wear out. They control more up/down motion of the wheel vs the left/right you are hearing.
    If you have a friend that could turn the wheel while you listen to the location the noise is coming from (assuming you can hear it while stopped) that could help pinpoint the next set of parts to replace.
    It sounds like tie rod ends to me based on what you are describing. If you can jack up the front of the car then try to move the tire left right. If you get any movement or clunking it is one or both set of tie rod ends.
    There is also a chance it could be strut tower bearings but I’d save that for last since they are much more involved to replace. Usually way easier to just replace the entire strut assembly at that point.
  18. Mdv55
    Mdv55 Active Member
    246
    181
    Boston
    Did you replace the sway bar mount bushings or just the links?
  19. Jeffrimerman
    Jeffrimerman Member
    229
    45
    Pasadena
    Team Geek, that's exactly what I was thinking last night. When my brother comes over I'll do just that. I wish I had a stethoscope or one of those mechanics ones then I could hear exactly but I'm sure I can narrow it down with just ears. I'm going to have to google what a strut tower bearing is.
    I only replaced the sway bar links. I will get to the bottom of it =)
  20. Team_Geek
    Team_Geek Member
    62
    31
    MN
    Screwdriver on the part with your ear on the handle works ok for a poor man’s steth..
    You can usually feel the issue with your hand on the part when something is clunking on the suspension. Just have him turn the wheel a couple times first so you see where the parts move at so you don’t get pinched on anything.
    But if you can hear it from the drivers seat it will probably be pretty obvious when you get up in the fender well.
    Let us know what you find out. Good luck!
    Paul E. Highway likes this.
